#include <ossimFftw3Factory.h>
| virtual | ~ossimFftw3Factory () |
| virtual ossimObject * | createObject (const ossimString &name) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimImageSourceFactoryBase | |
| virtual ossimImageSource * | createImageSource (const ossimString &name) const |
| virtual ossimImageSource * | createImageSource (const ossimKeywordlist &kwl, const char *prefix=0) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimFftw3Factory * | instance () |
| ossimFftw3Factory () | |
| ossimFftw3Factory (const ossimFftw3Factory &) | |
| const ossimFftw3Factory & | operator= (ossimFftw3Factory &) |
Protected Member Functions inherited from ossimImageSourceFactoryBase | |
| ossimImageSourceFactoryBase () | |
| ossimImageSourceFactoryBase (const ossimImageSourceFactoryBase &) | |
| const ossimImageSourceFactoryBase & | operator= (const ossimImageSourceFactoryBase &) |
Static Protected Attributes | |
| static ossimFftw3Factory * | theInstance =NULL |
Definition at line 12 of file ossimFftw3Factory.h.
Definition at line 20 of file ossimFftw3Factory.cpp.
References ossimImageSourceFactoryRegistry::instance(), theInstance, and ossimImageSourceFactoryRegistry::unregisterFactory().
protected |
Definition at line 101 of file ossimFftw3Factory.cpp.
Referenced by instance().
protected |
Definition at line 105 of file ossimFftw3Factory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 35 of file ossimFftw3Factory.cpp.
References STATIC_TYPE_NAME.
Creates and object given a keyword list.
Definition at line 45 of file ossimFftw3Factory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 95 of file ossimFftw3Factory.cpp.
static |
Definition at line 25 of file ossimFftw3Factory.cpp.
References ossimFftw3Factory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
Definition at line 109 of file ossimFftw3Factory.cpp.
staticprotected |
Definition at line 27 of file ossimFftw3Factory.h.
Referenced by instance(), and ~ossimFftw3Factory().
