#include <ossimAnnotationMultiPolyObject.h>
| ossimAnnotationMultiPolyObject () | |
| ossimAnnotationMultiPolyObject (const vector< ossimPolygon > &multiPoly, bool enableFill, unsigned char r, unsigned char g, unsigned char b, long thickness) | |
| ossimAnnotationMultiPolyObject (const ossimAnnotationMultiPolyObject &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual void | clear () |
| virtual void | addPolygon (ossim_uint32 polygonIndex, const ossimPolygon &poly) |
| virtual void | addPoint (ossim_uint32 polygonIndex, const ossimDpt &pt) |
| virtual void | setMultiPolygon (const vector< ossimPolygon > &multiPoly) |
| virtual void | computeBoundingRect () |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| const std::vector< ossimPolygon > & | getMultiPolygon () const |
| std::vector< ossimPolygon > & | getMultiPolygon () |
| void | setFillFlag (bool flag) |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| Saves the current state of this object. More... | |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
| virtual | ~ossimAnnotationMultiPolyObject () |
Protected Attributes | |
| vector< ossimPolygon > | theMultiPolygon |
| ossimDrect | theBoundingRect |
| bool | theFillEnabled |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 16 of file ossimAnnotationMultiPolyObject.h.
| ossimAnnotationMultiPolyObject::ossimAnnotationMultiPolyObject | ( | ) |
Definition at line 18 of file ossimAnnotationMultiPolyObject.cpp.
Referenced by getNewClippedObject().
| ossimAnnotationMultiPolyObject::ossimAnnotationMultiPolyObject | ( | const vector< ossimPolygon > & | multiPoly, |
| bool | enableFill, | ||
| unsigned char | r, | ||
| unsigned char | g, | ||
| unsigned char | b, | ||
| long | thickness | ||
Definition at line 25 of file ossimAnnotationMultiPolyObject.cpp.
References computeBoundingRect(), and theMultiPolygon.
inline |
Definition at line 27 of file ossimAnnotationMultiPolyObject.h.
protectedvirtual |
Definition at line 38 of file ossimAnnotationMultiPolyObject.cpp.
inlinevirtual |
Definition at line 55 of file ossimAnnotationMultiPolyObject.h.
inlinevirtual |
Definition at line 47 of file ossimAnnotationMultiPolyObject.h.
Referenced by ossimGeoAnnotationMultiPolyObject::transform().
Implements ossimAnnotationObject.
Definition at line 42 of file ossimAnnotationMultiPolyObject.cpp.
References theBoundingRect, theMultiPolygon, x, and y.
Definition at line 268 of file ossimAnnotationMultiPolyObject.cpp.
References theMultiPolygon.
Definition at line 273 of file ossimAnnotationMultiPolyObject.cpp.
References ossimDrect::combine(), ossimDrect::hasNans(), ossimDrect::height(), ossimDrect::makeNan(), theBoundingRect, theMultiPolygon, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimGeoAnnotationMultiPolyObject::computeBoundingRect(), ossimAnnotationMultiPolyObject(), and ossimGeoAnnotationMultiPolyObject::transform().
Definition at line 143 of file ossimAnnotationMultiPolyObject.cpp.
References ossimPolygon::clipToRect(), ossimRgbImage::drawFilledPolygon(), ossimRgbImage::drawLine(), ossimRgbImage::getImageData(), ossimImageData::getImageRectangle(), ossimPolygon::getNumberOfVertices(), ossimPolygon::getVertexCount(), ossimDrect::hasNans(), ossimDrect::intersects(), ossimDrect::lr(), ossimRgbImage::setDrawColor(), ossimRgbImage::setThickness(), ossimAnnotationObject::theBlue, theBoundingRect, theFillEnabled, ossimAnnotationObject::theGreen, theMultiPolygon, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeoAnnotationMultiPolyObject::draw().
inlinevirtual |
Definition at line 34 of file ossimAnnotationMultiPolyObject.h.
Definition at line 263 of file ossimAnnotationMultiPolyObject.cpp.
References theBoundingRect.
Referenced by ossimGeoAnnotationMultiPolyObject::computeBoundingRect(), and ossimGeoAnnotationMultiPolyObject::getBoundingRect().
inline |
Definition at line 72 of file ossimAnnotationMultiPolyObject.h.
inline |
Definition at line 73 of file ossimAnnotationMultiPolyObject.h.
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 74 of file ossimAnnotationMultiPolyObject.cpp.
References ossimPolyLine::clipToRect(), ossimDrect::intersects(), ossimDrect::lr(), ossimAnnotationMultiPolyObject(), ossimAnnotationObject::theBlue, theBoundingRect, theFillEnabled, ossimAnnotationObject::theGreen, theMultiPolygon, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDpt::x, and ossimDpt::y.
Definition at line 53 of file ossimAnnotationMultiPolyObject.cpp.
References ossimDrect::hasNans(), ossimDrect::intersects(), theBoundingRect, and theMultiPolygon.
This method allows you to pick an object. It will return true or false if the point falls somewhere on an object. Look at derived classes for further information.
Reimplemented from ossimAnnotationObject.
Definition at line 312 of file ossimAnnotationMultiPolyObject.cpp.
Referenced by ossimGeoAnnotationMultiPolyObject::isPointWithin().
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 246 of file ossimAnnotationMultiPolyObject.cpp.
References ossimObject::getClassName(), ossimAnnotationObject::print(), theFillEnabled, and theMultiPolygon.
inline |
Definition at line 74 of file ossimAnnotationMultiPolyObject.h.
Referenced by ossimGeoAnnotationMultiPolyObject::setFillFlag().
inlinevirtual |
Definition at line 64 of file ossimAnnotationMultiPolyObject.h.
References ossimAnnotationObject::computeBoundingRect().
protected |
Definition at line 81 of file ossimAnnotationMultiPolyObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getBoundingRect(), getNewClippedObject(), and intersects().
protected |
Definition at line 82 of file ossimAnnotationMultiPolyObject.h.
Referenced by draw(), getNewClippedObject(), and print().
protected |
Definition at line 80 of file ossimAnnotationMultiPolyObject.h.
Referenced by applyScale(), clear(), computeBoundingRect(), draw(), getNewClippedObject(), intersects(), isPointWithin(), ossimAnnotationMultiPolyObject(), and print().
