#include <ossimAnnotationMultiLineObject.h>
| ossimAnnotationMultiLineObject () | |
| ossimAnnotationMultiLineObject (const std::vector< ossimPolyLine > &lineList, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimAnnotationMultiLineObject (const ossimPolyLine &lineList, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimAnnotationMultiLineObject (const ossimAnnotationMultiLineObject &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| virtual void | computeBoundingRect () |
| virtual const vector< ossimPolyLine > & | getPolyLineList () const |
| virtual vector< ossimPolyLine > & | getPolyLineList () |
| virtual void | setPolyLine (const ossimPolyLine &line) |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| Saves the current state of this object. More... | |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
Protected Attributes | |
| vector< ossimPolyLine > | thePolyLineList |
| ossimDrect | theBoundingRect |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 15 of file ossimAnnotationMultiLineObject.h.
| ossimAnnotationMultiLineObject::ossimAnnotationMultiLineObject | ( | ) |
Referenced by getNewClippedObject().
inline |
Definition at line 19 of file ossimAnnotationMultiLineObject.h.
References ossimAnnotationObject::computeBoundingRect().
inline |
Definition at line 30 of file ossimAnnotationMultiLineObject.h.
inline |
Definition at line 42 of file ossimAnnotationMultiLineObject.h.
Implements ossimAnnotationObject.
Definition at line 87 of file ossimAnnotationMultiLineObject.cpp.
References theBoundingRect, thePolyLineList, x, and y.
Referenced by ossimGeoAnnotationPolyLineObject::applyScale().
Definition at line 156 of file ossimAnnotationMultiLineObject.cpp.
References ossimDrect::combine(), ossimDrect::hasNans(), ossimDrect::makeNan(), theBoundingRect, and thePolyLineList.
Referenced by ossimGeoAnnotationPolyLineObject::computeBoundingRect(), and ossimGeoAnnotationPolyLineObject::transform().
Definition at line 18 of file ossimAnnotationMultiLineObject.cpp.
References ossimRgbImage::drawLine(), ossimRgbImage::getImageData(), ossimImageData::getImageRectangle(), ossimDrect::intersects(), ossimDrect::lr(), ossimRgbImage::setDrawColor(), ossimRgbImage::setThickness(), ossimAnnotationObject::theBlue, theBoundingRect, ossimAnnotationObject::theGreen, thePolyLineList, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeoAnnotationPolyLineObject::draw().
inlinevirtual |
Definition at line 49 of file ossimAnnotationMultiLineObject.h.
inlinevirtual |
Definition at line 60 of file ossimAnnotationMultiLineObject.h.
Referenced by ossimGeoAnnotationPolyLineObject::getBoundingRect().
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 105 of file ossimAnnotationMultiLineObject.cpp.
References intersects(), ossimDrect::lr(), ossimAnnotationMultiLineObject(), ossimAnnotationObject::theBlue, ossimAnnotationObject::theGreen, thePolyLineList, ossimAnnotationObject::theRed, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeoAnnotationPolyLineObject::getNewClippedObject().
inlinevirtual |
Definition at line 67 of file ossimAnnotationMultiLineObject.h.
Referenced by ossimGeoAnnotationPolyLineObject::transform().
inlinevirtual |
Definition at line 72 of file ossimAnnotationMultiLineObject.h.
Definition at line 73 of file ossimAnnotationMultiLineObject.cpp.
References thePolyLineList.
Referenced by getNewClippedObject(), and ossimGeoAnnotationPolyLineObject::intersects().
This method allows you to pick an object. It will return true or false if the point falls somewhere on an object. Look at derived classes for further information.
Reimplemented from ossimAnnotationObject.
Definition at line 142 of file ossimAnnotationMultiLineObject.cpp.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 181 of file ossimAnnotationMultiLineObject.cpp.
References ossimAnnotationObject::print(), and thePolyLineList.
Referenced by ossimGeoAnnotationPolyLineObject::print().
inlinevirtual |
Definition at line 76 of file ossimAnnotationMultiLineObject.h.
protected |
Definition at line 83 of file ossimAnnotationMultiLineObject.h.
Referenced by applyScale(), computeBoundingRect(), and draw().
protected |
Definition at line 82 of file ossimAnnotationMultiLineObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getNewClippedObject(), intersects(), isPointWithin(), and print().
