Go to the source code of this file.
| set_type | read_thematic_index (char *tablename, char *value) |
| ThematicIndex | open_thematic_index (char *tablename) |
| set_type | search_thematic_index (ThematicIndex *themindex, char *value) |
| void | close_thematic_index (ThematicIndex *themindex) |
| set_type | read_gazetteer_index (char *vpfname, char *query_str) |
| set_type | search_gazetteer_index (ThematicIndex *idx, char *query_str) |
| ossim_int32 | read_gazetteer_index_directory (ThematicIndexDirectory **gid, ThematicIndexHeader *gi, FILE *idx_fp) |
| ossim_int32 | write_thematic_index_header (ThematicIndexHeader h, FILE *fp) |
| ossim_int32 | read_thematic_index_header (ThematicIndexHeader *h, FILE *fp) |
| ossim_int32 | write_thematic_index_directory (ThematicIndexHeader h, ThematicIndexDirectory *d, ossim_int32 size, FILE *fp) |
| ossim_int32 | write_gazetteer_index_directory (ThematicIndexHeader h, ThematicIndexDirectory *d, ossim_int32 size, FILE *fp) |
| ossim_int32 | create_thematic_index (char indextype, char *tablename, char *idxname, char *columnname, char *idx_set) |
| ossim_int32 | create_gazetteer_index (char *tablename, char *idx_fname, char *columnname, char *idx_set) |
◆ DIRECTORY_SIZE
◆ MAX_ID
| #define MAX_ID 32767 /* Threshold between S and I ids */ |
◆ THEMATIC_INDEX_HEADER_SIZE
| #define THEMATIC_INDEX_HEADER_SIZE 60 |
◆ close_thematic_index()
◆ create_gazetteer_index()
| ossim_int32 create_gazetteer_index |
char * |
tablename, |
char * |
idx_fname, |
char * |
columnname, |
char * |
idx_set |
◆ create_thematic_index()
| ossim_int32 create_thematic_index |
char |
indextype, |
char * |
tablename, |
char * |
idxname, |
char * |
columnname, |
char * |
idx_set |
◆ open_thematic_index()
◆ read_gazetteer_index()
| set_type read_gazetteer_index |
char * |
vpfname, |
char * |
query_str |
◆ read_gazetteer_index_directory()
◆ read_thematic_index()
| set_type read_thematic_index |
char * |
tablename, |
char * |
value |
◆ read_thematic_index_header()
◆ search_gazetteer_index()
◆ search_thematic_index()
◆ write_gazetteer_index_directory()
◆ write_thematic_index_directory()
◆ write_thematic_index_header()
