#include <stdio.h>#include <ossim/vpfutil/machine.h>#include <ossim/ossimConfig.h>#include <ossim/vpfutil/vpfio.h>#include <ossim/vpfutil/values.h>#include <math.h>Go to the source code of this file.
Classes | |
| union | null_field |
| struct | header_cell |
| struct | column_type |
| struct | index_cell |
| struct | vpf_table_type |
| struct | coordinate_type |
| struct | double_coordinate_type |
| struct | tri_coordinate_type |
| struct | double_tri_coordinate_type |
| union | key_field |
| struct | id_triplet_type |
Macros | |
| #define | TRUE 1 |
| #define | FALSE 0 |
| #define | LEAST_SIGNIFICANT 0 |
| #define | MOST_SIGNIFICANT 1 |
| #define | MACHINE_BYTE_ORDER (vpfutilMachineByteOrder()) |
| #define | RAM 0 |
| #define | DISK 1 |
| #define | EITHER 2 |
| #define | COMPUTE 3 |
| #define | CLOSED 0 |
| #define | OPENED 1 |
| #define | TYPE0(cell) ((cell>>6)&(3)) |
| #define | TYPE1(cell) ((cell>>4)&(3)) |
| #define | TYPE2(cell) ((cell>>2)&(3)) |
| #define | TYPE3(cell) ((cell)&(3)) |
| #define | SETTYPE0(cell, value) cell = (((cell)&(~(3<<6)))|(((3)&(value))<<6)) |
| #define | SETTYPE1(cell, value) cell = (((cell)&(~(3<<4)))|(((3)&(value))<<4)) |
| #define | SETTYPE2(cell, value) cell = (((cell)&(~(3<<2)))|(((3)&(value))<<2)) |
| #define | SETTYPE3(cell, value) cell = (((cell)&(~(3)))|(((3)&(value)))) |
| #define | ASSIGN_KEY(tYPE, kEY, loc, val) |
| #define | VARIABLE_STRING_NULL_LENGTH 10 |
| #define | NULLCHAR ' ' |
| #define | NULLTEXT " " |
| #define | NULLSHORT -MAXSHORT |
| #define | NULLINT -MAXLONG |
| #define | NULLDATE " " |
| #define | NULLFLOAT ((float) quiet_nan (0)) |
| #define | NULLDOUBLE ((double) quiet_nan (0)) |
Typedefs | |
| typedef char | date_type[21] |
| typedef struct header_cell * | header_type |
| typedef column_type * | row_type |
| typedef struct index_cell * | index_type |
Enumerations | |
| enum | storage_type { ram, disk, either, compute } |
| enum | file_mode { Read, Write } |
| enum | ddef_state_type { idle_state, name_state, type_state, tuple_state, count_state } |
Variables | |
| FILE * | errorfp |
| #define ASSIGN_KEY | ( | tYPE, | |
| kEY, | |||
| loc, | |||
| val | |||
Definition at line 157 of file vpftable.h.
| #define CLOSED 0 |
Definition at line 82 of file vpftable.h.
Referenced by ossimVpfTable::closeTable(), ossimVpfTable::getColumnValueAsString(), ossimVpfTable::goToRow(), ossimVpfTable::isClosed(), ossimVpfTable::print(), and ossimVpfTable::reset().
| #define COMPUTE 3 |
Definition at line 78 of file vpftable.h.
| #define DISK 1 |
Definition at line 76 of file vpftable.h.
Referenced by ossimVpfDatabaseHeader::open().
| #define EITHER 2 |
Definition at line 77 of file vpftable.h.
| #define FALSE 0 |
Definition at line 30 of file vpftable.h.
| #define LEAST_SIGNIFICANT 0 |
Definition at line 34 of file vpftable.h.
| #define MACHINE_BYTE_ORDER (vpfutilMachineByteOrder()) |
Definition at line 39 of file vpftable.h.
| #define MOST_SIGNIFICANT 1 |
Definition at line 35 of file vpftable.h.
| #define NULLCHAR ' ' |
Definition at line 194 of file vpftable.h.
| #define NULLDATE " " |
Definition at line 198 of file vpftable.h.
| #define NULLDOUBLE ((double) quiet_nan (0)) |
Definition at line 201 of file vpftable.h.
| #define NULLFLOAT ((float) quiet_nan (0)) |
Definition at line 200 of file vpftable.h.
| #define NULLINT -MAXLONG |
Definition at line 197 of file vpftable.h.
| #define NULLSHORT -MAXSHORT |
Definition at line 196 of file vpftable.h.
| #define NULLTEXT " " |
Definition at line 195 of file vpftable.h.
| #define OPENED 1 |
Definition at line 83 of file vpftable.h.
Referenced by ossimVpfTable::getColumnValues().
| #define RAM 0 |
Definition at line 75 of file vpftable.h.
| #define SETTYPE0 | ( | cell, | |
| value | |||
| ) | cell = (((cell)&(~(3<<6)))|(((3)&(value))<<6)) |
Definition at line 150 of file vpftable.h.
| #define SETTYPE1 | ( | cell, | |
| value | |||
| ) | cell = (((cell)&(~(3<<4)))|(((3)&(value))<<4)) |
Definition at line 151 of file vpftable.h.
| #define SETTYPE2 | ( | cell, | |
| value | |||
| ) | cell = (((cell)&(~(3<<2)))|(((3)&(value))<<2)) |
Definition at line 152 of file vpftable.h.
| #define SETTYPE3 | ( | cell, | |
| value | |||
| ) | cell = (((cell)&(~(3)))|(((3)&(value)))) |
Definition at line 153 of file vpftable.h.
| #define TRUE 1 |
Definition at line 27 of file vpftable.h.
| #define TYPE0 | ( | cell | ) | ((cell>>6)&(3)) |
Definition at line 143 of file vpftable.h.
| #define TYPE1 | ( | cell | ) | ((cell>>4)&(3)) |
Definition at line 144 of file vpftable.h.
| #define TYPE2 | ( | cell | ) | ((cell>>2)&(3)) |
Definition at line 145 of file vpftable.h.
| #define TYPE3 | ( | cell | ) | ((cell)&(3)) |
Definition at line 146 of file vpftable.h.
| #define VARIABLE_STRING_NULL_LENGTH 10 |
Definition at line 193 of file vpftable.h.
| typedef char date_type[21] |
Definition at line 47 of file vpftable.h.
| typedef struct header_cell * header_type |
| typedef struct index_cell * index_type |
| typedef column_type* row_type |
Definition at line 93 of file vpftable.h.
| enum ddef_state_type |
| Enumerator | |
| idle_state | |
| name_state | |
| type_state | |
| tuple_state | |
| count_state | |
Definition at line 219 of file vpftable.h.
| enum file_mode |
| Enumerator | |
| Read | |
| Write | |
Definition at line 80 of file vpftable.h.
| enum storage_type |
| Enumerator | |
| ram | |
| disk | |
| either | |
| compute | |
Definition at line 74 of file vpftable.h.
| row_type create_row | ( | vpf_table_type | table | ) |
| void free_row | ( | row_type | row, |
| vpf_table_type | table | ||
Referenced by ossimVpfAnnotationFeatureInfo::buildPointFeature(), ossimVpfAnnotationFeatureInfo::buildTxtFeature(), ossimVpfTable::getColumnValueAsString(), ossimVpfTable::getColumnValues(), ossimVpfLibrary::getExtent(), ossimVpfBoundingRecordTable::openTable(), ossimVpfTable::print(), ossimVpfAnnotationFeatureInfo::readEdge(), ossimVpfAnnotationFeatureInfo::readGeoPolygon(), ossimVpfAnnotationFeatureInfo::readRngId(), ossimVpfAnnotationFeatureInfo::readStartEdgeId(), ossimVpfAnnotationFeatureInfo::readTableCellAsInt(), ossimVpfFeatureClassSchema::setFeatureClassMapping(), and ossimVpfLibrary::setTileNames().
| char get_char | ( | ossim_int32 * | ind, |
| char * | src | ||
| ossim_int32 get_number | ( | ossim_int32 * | ind, |
| char * | src, | ||
| char | delemit | ||
| row_type get_row | ( | ossim_int32 | row_number, |
| char* get_string | ( | ossim_int32 * | ind, |
| char * | src, | ||
| char | delimit | ||
| void* get_table_element | ( | ossim_int32 | field_number, |
| row_type | row, | ||
| vpf_table_type | table, | ||
| void * | value, | ||
| ossim_int32 * | count | ||
| ossim_int32 index_length | ( | ossim_int32 | row_number, |
| ossim_int32 index_pos | ( | ossim_int32 | row_number, |
Referenced by ossimVpfTable::goToRow(), and ossimVpfTable::reset().
| int is_vpf_null_double | ( | double | num | ) |
Referenced by ossimVpfTable::getColumnValueAsString(), and ossimVpfTable::print().
| int is_vpf_null_float | ( | float | num | ) |
| ossim_int32 is_vpf_table | ( | const char * | fname | ) |
Referenced by ossimVpfDatabaseHeader::open(), and ossimVpfTable::openTable().
| void* named_table_element | ( | char * | field_name, |
| ossim_int32 | row_number, | ||
| void nullify_table_element | ( | ossim_int32 | field, |
| ossim_int32 parse_data_def | ( | vpf_table_type * | table | ) |
| ossim_int32 put_table_element | ( | ossim_int32 | field, |
| ossim_int32 | count | ||
| row_type read_next_row | ( | vpf_table_type | table | ) |
| row_type read_row | ( | ossim_int32 | row_number, |
Referenced by ossimVpfAnnotationFeatureInfo::buildPointFeature(), ossimVpfAnnotationFeatureInfo::buildTxtFeature(), ossimVpfTable::getColumnValueAsString(), ossimVpfLibrary::getExtent(), ossimVpfBoundingRecordTable::openTable(), ossimVpfAnnotationFeatureInfo::readEdge(), ossimVpfAnnotationFeatureInfo::readGeoPolygon(), ossimVpfAnnotationFeatureInfo::readRngId(), ossimVpfAnnotationFeatureInfo::readStartEdgeId(), ossimVpfAnnotationFeatureInfo::readTableCellAsInt(), ossimVpfFeatureClassSchema::setFeatureClassMapping(), and ossimVpfLibrary::setTileNames().
| char* read_text_defstr | ( | FILE * | infile, |
| FILE * | outerr | ||
| void swap_eight | ( | char * | , |
| char * | |||
| void swap_four | ( | char * | , |
| char * | |||
| void swap_two | ( | char * | , |
| char * | |||
| void* table_element | ( | ossim_int32 | field_number, |
| ossim_int32 table_pos | ( | const char * | field_name, |
| void vpf_close_table | ( | vpf_table_type * | table | ) |
Referenced by ossimVpfTable::closeTable().
| void vpf_dump_doc_table | ( | char * | tablename, |
| char * | outname | ||
| void vpf_dump_table | ( | char * | tablename, |
| vpf_table_type vpf_open_table | ( | const char * | tablename, |
| storage_type | storage, | ||
| const char * | mode, | ||
| char * | defstr | ||
| int vpfutilMachineByteOrder | ( | ) |
| ossim_int32 write_next_row | ( | row_type | row, |
| vpf_table_type * | table | ||
| FILE* errorfp |
