#include <math.h>#include <ossim/projection/ossimPolyconicProjection.h>#include <ossim/base/ossimKeywordNames.h>Go to the source code of this file.
Macros | |
| #define | PI_OVER_2 ( M_PI / 2.0) |
| #define | TWO_PI (2.0 * M_PI) |
| #define | POLY_COEFF_TIMES_SIN(coeff, x, latit) (coeff * (sin (x * latit))) |
| #define | POLY_M(c0lat, c1s2lat, c2s4lat, c3s6lat) (Poly_a*(c0lat - c1s2lat + c2s4lat - c3s6lat)) |
| #define | FLOAT_EQ(x, v, epsilon) (((v - epsilon) < x) && (x < (v + epsilon))) |
| #define | FOURTY_ONE (41.0 * M_PI / 180.0) /* 41 degrees in radians */ |
| #define | POLY_NO_ERROR 0x0000 |
| #define | POLY_LAT_ERROR 0x0001 |
| #define | POLY_LON_ERROR 0x0002 |
| #define | POLY_EASTING_ERROR 0x0004 |
| #define | POLY_NORTHING_ERROR 0x0008 |
| #define | POLY_ORIGIN_LAT_ERROR 0x0010 |
| #define | POLY_CENT_MER_ERROR 0x0020 |
| #define | POLY_A_ERROR 0x0040 |
| #define | POLY_B_ERROR 0x0080 |
| #define | POLY_A_LESS_B_ERROR 0x0100 |
| #define | POLY_LON_WARNING 0x0200 |
Definition at line 31 of file ossimPolyconicProjection.cpp.
Referenced by ossimPolyconicProjection::Convert_Polyconic_To_Geodetic().
| #define FOURTY_ONE (41.0 * M_PI / 180.0) /* 41 degrees in radians */ |
Definition at line 32 of file ossimPolyconicProjection.cpp.
Referenced by ossimPolyconicProjection::Set_Polyconic_Parameters().
| #define PI_OVER_2 ( M_PI / 2.0) |
Definition at line 24 of file ossimPolyconicProjection.cpp.
| #define POLY_A_ERROR 0x0040 |
Definition at line 41 of file ossimPolyconicProjection.cpp.
| #define POLY_A_LESS_B_ERROR 0x0100 |
Definition at line 43 of file ossimPolyconicProjection.cpp.
| #define POLY_B_ERROR 0x0080 |
Definition at line 42 of file ossimPolyconicProjection.cpp.
| #define POLY_CENT_MER_ERROR 0x0020 |
Definition at line 40 of file ossimPolyconicProjection.cpp.
Definition at line 29 of file ossimPolyconicProjection.cpp.
Referenced by ossimPolyconicProjection::Convert_Geodetic_To_Polyconic(), ossimPolyconicProjection::Convert_Polyconic_To_Geodetic(), and ossimPolyconicProjection::Set_Polyconic_Parameters().
| #define POLY_EASTING_ERROR 0x0004 |
Definition at line 37 of file ossimPolyconicProjection.cpp.
| #define POLY_LAT_ERROR 0x0001 |
Definition at line 35 of file ossimPolyconicProjection.cpp.
| #define POLY_LON_ERROR 0x0002 |
Definition at line 36 of file ossimPolyconicProjection.cpp.
| #define POLY_LON_WARNING 0x0200 |
Definition at line 44 of file ossimPolyconicProjection.cpp.
Referenced by ossimPolyconicProjection::Convert_Geodetic_To_Polyconic().
| #define POLY_M | ( | c0lat, | |
| c1s2lat, | |||
| c2s4lat, | |||
| c3s6lat | |||
| ) | (Poly_a*(c0lat - c1s2lat + c2s4lat - c3s6lat)) |
Definition at line 30 of file ossimPolyconicProjection.cpp.
| #define POLY_NO_ERROR 0x0000 |
Definition at line 34 of file ossimPolyconicProjection.cpp.
| #define POLY_NORTHING_ERROR 0x0008 |
Definition at line 38 of file ossimPolyconicProjection.cpp.
| #define POLY_ORIGIN_LAT_ERROR 0x0010 |
Definition at line 39 of file ossimPolyconicProjection.cpp.
| #define TWO_PI (2.0 * M_PI) |
Definition at line 27 of file ossimPolyconicProjection.cpp.
