| std::ostream & | ossim_hdf5::print (H5::H5File *file, std::ostream &out) |
| | Print method. More...
| void | ossim_hdf5::printIterative (H5::H5File *file, const std::string &groupName, const std::string &prefix, ossim_uint32 &recursedCount, std::ostream &out) |
| | Iterative print method. More...
| void | ossim_hdf5::printObject (H5::H5File *file, const std::string &objectName, const std::string &prefix, std::ostream &out) |
| | Prints an object. More...
| void | ossim_hdf5::printEnumType (H5::DataSet &dataset, H5::EnumType &dataType, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::printIntType (H5::DataSet &dataset, H5::IntType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::printFloatType (H5::DataSet &dataset, H5::FloatType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::printArrayType (H5::DataSet &dataset, H5::ArrayType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::printStrType (H5::DataSet &dataset, H5::StrType &dataType, const char *dataPtr, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::printCompound (H5::DataSet &dataset, const std::string &prefix, std::ostream &out) |
| | Prints a compound object. More...
| bool | ossim_hdf5::getGroupAttributeValue (H5::H5File *file, const std::string &group, const std::string &key, std::string &value) |
| | Gets string value for attribute key. More...
| bool | ossim_hdf5::getDatasetAttributeValue (H5::H5File *file, const std::string &objectName, const std::string &key, std::string &value) |
| void | ossim_hdf5::printAttribute (const H5::Attribute &attr, const std::string &prefix, std::ostream &out) |
| void | ossim_hdf5::combine (const std::string &left, const std::string &right, char separator, std::string &result) |
| void | ossim_hdf5::getDatasetNames (H5::H5File *file, std::vector< std::string > &names) |
| std::string | ossim_hdf5::getDatatypeClassType (ossim_int32 type) |
| bool | ossim_hdf5::isLoadableAsImage (H5::H5File *file, const std::string &datasetName) |
| void | ossim_hdf5::iterateGroupForDatasetNames (H5::H5File *file, const std::string &group, std::vector< std::string > &names, ossim_uint32 &recursedCount) |
| void | ossim_hdf5::getExtents (const H5::DataSet *dataset, std::vector< ossim_uint32 > &extents) |
| ossimScalarType | ossim_hdf5::getScalarType (const H5::DataSet *dataset) |
| ossimScalarType | ossim_hdf5::getScalarType (ossim_int32 typeClass, size_t size, bool isSigned) |
| | Gets scalar type from args. More...
| ossimByteOrder | ossim_hdf5::getByteOrder (const H5::AbstractDs *dataset) |
| ossimByteOrder | ossim_hdf5::getByteOrder (const H5::DataType *dataType) |
| bool | ossim_hdf5::getValidBoundingRect (H5::DataSet &dataset, const std::string &name, ossimIrect &rect) |
| | Gets the valid bounding rect of the dataset excluding nulls on front and back. More...
| ossimRefPtr< ossimProjection > | ossim_hdf5::getBilinearProjection (H5::DataSet &latDataSet, H5::DataSet &lonDataSet, const ossimIrect &validRect) |
| | Gets bilinear projection from Latitude, Longitude layer. More...
| bool | ossim_hdf5::crossesDateline (H5::DataSet &dataset, const ossimIrect &validRect) |
| | Checks for dateline cross. More...
| bool | ossim_hdf5::crossesDateline (const std::vector< ossim_float32 > &lineBuffer) |
