#include <ossim/base/ossimGpt.h>#include <ossim/base/ossimEcefPoint.h>#include <ossim/base/ossimEcefVector.h>#include <ossim/base/ossimDms.h>#include <ossim/base/ossimDatum.h>#include <ossim/base/ossimDatumFactory.h>#include <ossim/base/ossimDatumFactoryRegistry.h>#include <ossim/base/ossimGeoidManager.h>#include <ossim/base/ossimEllipsoid.h>#include <ossim/base/ossimGeocent.h>#include <iostream>#include <sstream>Go to the source code of this file.
Functions | |
| std::ostream & | operator<< (std::ostream &os, const ossimGpt &pt) |
| std::istream & | operator>> (std::istream &is, ossimGpt &pt) |
| std::ostream& operator<< | ( | std::ostream & | os, |
| const ossimGpt & | pt | ||
Definition at line 73 of file ossimGpt.cpp.
References ossimGpt::print().
| std::istream& operator>> | ( | std::istream & | is, |
This method starts by doing a "makeNan" on aPt. So if anything goes wrong with the stream or parsing aPt could be all or partially nan.
| is | Input stream istream to formatted text. |
| aPt | osimGpt to be initialized from stream. |
Expected format: ( 30.00000000000000, -90.00000000000000, 0.00000000000000, WGE ) --—latitude-— --—longitude-— ---—height-— datum
Definition at line 122 of file ossimGpt.cpp.
References ossimString::contains(), ossimDatumFactoryRegistry::create(), ossimGpt::datum(), ossimString::erase(), ossimString::find(), ossimGpt::height(), ossimDatumFactoryRegistry::instance(), ossimDatumFactory::instance(), ossimGpt::latd(), ossimGpt::lond(), ossimGpt::makeNan(), ossim::nan(), ossimString::toFloat64(), and ossimString::trim().
