#include <ossimDatumFactoryRegistry.h>
| ~ossimDatumFactoryRegistry () | |
| destructor More... | |
| void | registerFactory (ossimDatumFactoryInterface *factory) |
| Method to add factory to registry. More... | |
| virtual const ossimDatum * | create (const ossimString &code) const |
| create method More... | |
| virtual const ossimDatum * | create (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getList (std::vector< ossimString > &list) const |
| getList method to return a combined list of all datums from registered datum factories. More... | |
Public Member Functions inherited from ossimDatumFactoryInterface | |
| ossimDatumFactoryInterface () | |
| virtual | ~ossimDatumFactoryInterface () |
| static ossimDatumFactoryRegistry * | instance () |
| instance method More... | |
| hidden from use default constructor More... | |
Protected Attributes | |
| std::mutex | theFactoryListMutex |
| Single static instance of this class. More... | |
| std::vector< ossimDatumFactoryInterface * > | theFactoryList |
Definition at line 24 of file ossimDatumFactoryRegistry.h.
| ossimDatumFactoryRegistry::~ossimDatumFactoryRegistry | ( | ) |
protected |
Definition at line 93 of file ossimDatumFactoryRegistry.cpp.
References ossimEpsgDatumFactory::instance(), ossimDatumFactory::instance(), and registerFactory().
create method
Implements pure virtual ossimDatumFactoryInterface::create.
Implements ossimDatumFactoryInterface.
Definition at line 45 of file ossimDatumFactoryRegistry.cpp.
References theFactoryList.
Referenced by ossimFgdcXmlDoc::createOssimDatum(), ossimEpsgProjectionDatabase::findProjection(), ossimMapProjection::loadState(), operator>>(), ossimStatePlaneProjectionInfo::ossimStatePlaneProjectionInfo(), and ossimInfo::printDatums().
Definition at line 65 of file ossimDatumFactoryRegistry.cpp.
| list | The list to add to. |
Definition at line 82 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimInfo::printDatums().
static |
instance method
Definition at line 24 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimFgdcXmlDoc::createOssimDatum(), ossimEpsgProjectionDatabase::findProjection(), ossimInit::initializeDefaultFactories(), ossimMapProjection::loadState(), operator>>(), ossimStatePlaneProjectionInfo::ossimStatePlaneProjectionInfo(), and ossimInfo::printDatums().
| void ossimDatumFactoryRegistry::registerFactory | ( | ossimDatumFactoryInterface * | factory | ) |
| factory | Factory to register. |
Definition at line 36 of file ossimDatumFactoryRegistry.cpp.
Referenced by ossimDatumFactoryRegistry().
protected |
Definition at line 71 of file ossimDatumFactoryRegistry.h.
Referenced by create(), getList(), and registerFactory().
mutableprotected |
Definition at line 70 of file ossimDatumFactoryRegistry.h.
