#include <CurlHeaderCache.h>
Public Types | |
| typedef std::shared_ptr< CurlHeaderCacheNode > | Node_t |
| typedef std::string | Key_t |
| typedef ossim_int64 | TimeIndex_t |
| typedef std::map< Key_t, Node_t > | CacheType |
| typedef std::map< TimeIndex_t, Key_t > | CacheTimeIndexType |
| CurlHeaderCache () | |
| virtual | ~CurlHeaderCache () |
| bool | getCachedFilesize (const Key_t &key, ossim_int64 &filesize) const |
| void | addHeader (const Key_t &key, Node_t &node) |
| void | setMaxCacheEntries (ossim_int64 maxEntries) |
| void | touchEntry (const Key_t &key) |
| static std::shared_ptr< CurlHeaderCache > | instance () |
| void | shrinkEntries () |
| void | touchEntryProtected (const Key_t &key) |
Protected Attributes | |
| std::mutex | m_mutex |
| CacheType | m_cache |
| CacheTimeIndexType | m_cacheTime |
| ossim_int64 | m_maxCacheEntries |
Static Protected Attributes | |
| static std::shared_ptr< CurlHeaderCache > | m_instance |
Definition at line 27 of file CurlHeaderCache.h.
| typedef std::map<TimeIndex_t, Key_t > ossim::CurlHeaderCache::CacheTimeIndexType |
Definition at line 34 of file CurlHeaderCache.h.
| typedef std::map<Key_t, Node_t > ossim::CurlHeaderCache::CacheType |
Definition at line 33 of file CurlHeaderCache.h.
| typedef std::string ossim::CurlHeaderCache::Key_t |
Definition at line 31 of file CurlHeaderCache.h.
| typedef std::shared_ptr<CurlHeaderCacheNode> ossim::CurlHeaderCache::Node_t |
Definition at line 30 of file CurlHeaderCache.h.
Definition at line 32 of file CurlHeaderCache.h.
| ossim::CurlHeaderCache::CurlHeaderCache | ( | ) |
Definition at line 7 of file CurlHeaderCache.cpp.
Definition at line 13 of file CurlHeaderCache.cpp.
Definition at line 49 of file CurlHeaderCache.cpp.
References ossimTimer::instance(), and ossimTimer::tick().
| bool ossim::CurlHeaderCache::getCachedFilesize | ( | const Key_t & | key, |
| ossim_int64 & | filesize | ||
| ) | const |
Definition at line 28 of file CurlHeaderCache.cpp.
References touchEntryProtected().
static |
Definition at line 18 of file CurlHeaderCache.cpp.
| void ossim::CurlHeaderCache::setMaxCacheEntries | ( | ossim_int64 | maxEntries | ) |
protected |
Definition at line 96 of file CurlHeaderCache.cpp.
| void ossim::CurlHeaderCache::touchEntry | ( | const Key_t & | key | ) |
Definition at line 71 of file CurlHeaderCache.cpp.
protected |
Definition at line 81 of file CurlHeaderCache.cpp.
Referenced by getCachedFilesize().
protected |
Definition at line 52 of file CurlHeaderCache.h.
protected |
Definition at line 53 of file CurlHeaderCache.h.
staticprotected |
Definition at line 49 of file CurlHeaderCache.h.
protected |
Definition at line 54 of file CurlHeaderCache.h.
mutableprotected |
Definition at line 50 of file CurlHeaderCache.h.
