#include <ossimU11ImageData.h>
| ossimU11ImageData (ossimSource *source, ossim_uint32 bands=1) | |
| ossimU11ImageData (ossimSource *source, ossim_uint32 bands, ossim_uint32 width, ossim_uint32 height) | |
| ossimU11ImageData (const ossimU11ImageData &rhs) | |
| void | fill (ossim_uint32 band, double value) |
| bool | isNull (ossim_uint32 offset) const |
| void | setNull (ossim_uint32 offset) |
| virtual ossimDataObjectStatus | validate () const |
| virtual void | getNormalizedFloat (ossim_uint32 offset, ossim_uint32 bandNumber, float &result) const |
| virtual void | setNormalizedFloat (ossim_uint32 offset, ossim_uint32 bandNumber, float input) |
| virtual void | convertToNormalizedFloat (ossimImageData *result) const |
| virtual void | convertToNormalizedDouble (ossimImageData *result) const |
| virtual void | unnormalizeInput (ossimImageData *normalizedInput) |
| virtual double | computeAverageBandValue (ossim_uint32 bandNumber=0) |
| virtual double | computeMeanSquaredError (double meanValue, ossim_uint32 bandNumber=0) |
| virtual void | setValue (long x, long y, double color) |
| virtual void | copyTileToNormalizedBuffer (double *buf) const |
| virtual void | copyNormalizedBufferToTile (double *buf) |
| virtual void | copyTileToNormalizedBuffer (ossim_uint32 band, double *buf) const |
| virtual void | copyTileToNormalizedBuffer (ossim_uint32 band, float *buf) const |
| virtual void | copyTileToNormalizedBuffer (float *buf) const |
| virtual void | copyNormalizedBufferToTile (float *buf) |
| virtual void | copyNormalizedBufferToTile (ossim_uint32 band, double *buf) |
| virtual void | copyNormalizedBufferToTile (ossim_uint32 band, float *buf) |
| virtual ossim_float64 | getMinNormalizedPix () const |
Public Member Functions inherited from ossimImageData | |
| ossimImageData (const ossimImageData &rhs) | |
| copy constructor More... | |
| ossimImageData () | |
| ossimImageData (ossimSource *source, ossimScalarType scalar, ossim_uint32 bands=1) | |
| Constructor. More... | |
| ossimImageData (ossimSource *source, ossimScalarType scalar, ossim_uint32 bands, ossim_uint32 width, ossim_uint32 height) | |
| virtual | ~ossimImageData () |
| virtual const ossimImageData & | operator= (const ossimImageData &rhs) |
| assignment operator= More... | |
| virtual ossim_uint32 | getWidth () const |
| virtual ossim_uint32 | getHeight () const |
| virtual ossimIrect | getImageRectangle () const |
| virtual void | getWidthHeight (ossim_uint32 &w, ossim_uint32 &h) |
| virtual void | setWidth (ossim_uint32 width) |
| virtual void | setHeight (ossim_uint32 height) |
| virtual void | setWidthHeight (ossim_uint32 w, ossim_uint32 h) |
| virtual void | setImageRectangleAndBands (const ossimIrect &rect, ossim_uint32 numberOfBands) |
| virtual void | setImageRectangle (const ossimIrect &rect) |
| virtual void | setOrigin (const ossimIpt &origin) |
| virtual void | assign (const ossimDataObject *data) |
| virtual void | assign (const ossimImageData *data) |
| virtual void | assignBand (const ossimImageData *data, ossim_uint32 source_band, ossim_uint32 output_band) |
| virtual ossim_uint32 | getHashId () const |
| Uses prime numbers as coefficients for this summation. More... | |
| virtual void | setNullPix (ossim_float64 null_pix) |
| virtual void | setNullPix (ossim_float64 null_pix, ossim_uint32 band) |
| virtual void | setNullPix (const ossim_float64 *nullPixArray, ossim_uint32 numberOfValues) |
| virtual void | setMinPix (ossim_float64 min_pix) |
| virtual void | setMinPix (ossim_float64 min_pix, ossim_uint32 band) |
| virtual void | setMinPix (const ossim_float64 *minPixArray, ossim_uint32 numberOfValues) |
| virtual void | setMaxPix (ossim_float64 max_pix) |
| virtual void | setMaxPix (ossim_float64 max_pix, ossim_uint32 band) |
| virtual void | setMaxPix (const ossim_float64 *maxPixArray, ossim_uint32 numberOfValues) |
| virtual const ossimIpt & | getOrigin () const |
| virtual void | computeMinMaxPix (std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const |
| If the minBands and maxBands are empty or not equal to the imageData's current number of bands it will erase the contents, resize, and then replace the values in the passed in array with this objects min max values. More... | |
| virtual void | computeMinMaxNulPix (std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands, std::vector< ossim_float64 > &nulBands) const |
| Scans tile for min, max, nulls. More... | |
| virtual const ossim_float64 * | getNullPix () const |
| virtual const ossim_float64 * | getMinPix () const |
| virtual const ossim_float64 * | getMaxPix () const |
| virtual ossim_float64 | getNullPix (ossim_uint32 band) const |
| virtual ossim_float64 | getMinPix (ossim_uint32 band) const |
| virtual ossim_float64 | getMaxPix (ossim_uint32 band) const |
| virtual ossimString | getScalarTypeAsString () const |
| virtual ossim_uint32 | getNumberOfBands () const |
| virtual void | setNumberOfBands (ossim_uint32 bands, bool reallocate=false) |
| virtual ossim_float64 | getPix (const ossimIpt &position, ossim_uint32 band=0) const |
| Will return the pixel at location position. More... | |
| virtual ossim_float64 | getPix (ossim_uint32 offset, ossim_uint32 band=0) const |
| Will return the pixel at offset and band number. More... | |
| void | fill (ossim_uint32 band, ossim_float64 value) |
| will fill the entire band with the value. More... | |
| void | fill (ossim_float64 value) |
| will fill all bands with the passed in value. More... | |
| void | createTestTile () |
| Creates a step wedge for testing only. More... | |
| bool | isNull (ossim_uint32 offset, ossim_uint32 band) const |
| void | setNull (ossim_uint32 offset, ossim_uint32 band) |
| bool | isNull (const ossimIpt &pt) const |
| void | setNull (const ossimIpt &pt) |
| bool | isNull (const ossimIpt &pt, ossim_uint32 band) const |
| void | setNull (const ossimIpt &pt, ossim_uint32 band) |
| virtual bool | isValidBand (ossim_uint32 band) const |
| virtual ossimRefPtr< ossimImageData > | newNormalizedFloat () const |
| Will take this tile and normalize it to a newly allocated floating point tile. More... | |
| virtual ossimImageData * | newNormalizedDouble () const |
| Will take this tile and normalize it to a newly allocated double point tile. More... | |
| template<class T > | |
| void | copyTileToFloatBuffer (T, ossim_float32 *buf) const |
| virtual ossim_float64 | computeAverageBandValue (ossim_uint32 bandNumber=0) const |
| This will compute the average value for the band. More... | |
| virtual ossim_float64 | computeMeanSquaredError (ossim_float64 meanValue, ossim_uint32 bandNumber=0) const |
| This will call the compute average band value and then use that in the calculation of: More... | |
| virtual void | populateHistogram (ossimRefPtr< ossimMultiBandHistogram > histo) |
| virtual void | setHistogram (ossimRefPtr< ossimMultiResLevelHistogram > histo) |
| ossimRefPtr< ossimMultiResLevelHistogram > | getHistogram () |
| virtual bool | hasAlpha () const |
| virtual const ossim_uint8 * | getAlphaBuf () const |
| virtual ossim_uint8 * | getAlphaBuf () |
| virtual const void * | getBuf () const |
| virtual const ossim_uint8 * | getUcharBuf () const |
| virtual const ossim_uint16 * | getUshortBuf () const |
| virtual const ossim_sint16 * | getSshortBuf () const |
| virtual const ossim_float32 * | getFloatBuf () const |
| virtual const ossim_float64 * | getDoubleBuf () const |
| virtual void * | getBuf () |
| virtual ossim_uint8 * | getUcharBuf () |
| virtual ossim_uint16 * | getUshortBuf () |
| virtual ossim_sint16 * | getSshortBuf () |
| virtual ossim_float32 * | getFloatBuf () |
| virtual ossim_float64 * | getDoubleBuf () |
| virtual const void * | getBuf (ossim_uint32 band) const |
| virtual const ossim_uint8 * | getUcharBuf (ossim_uint32 band) const |
| virtual const ossim_uint16 * | getUshortBuf (ossim_uint32 band) const |
| virtual const ossim_sint16 * | getSshortBuf (ossim_uint32 band) const |
| virtual const ossim_float32 * | getFloatBuf (ossim_uint32 band) const |
| virtual const ossim_float64 * | getDoubleBuf (ossim_uint32 band) const |
| virtual void * | getBuf (ossim_uint32 band) |
| virtual ossim_uint8 * | getUcharBuf (ossim_uint32 band) |
| virtual ossim_uint16 * | getUshortBuf (ossim_uint32 band) |
| virtual ossim_sint16 * | getSshortBuf (ossim_uint32 band) |
| virtual ossim_float32 * | getFloatBuf (ossim_uint32 band) |
| virtual ossim_float64 * | getDoubleBuf (ossim_uint32 band) |
| virtual ossim_uint32 | getSize () const |
| Returns the total number of pixels in a tile for all bands. More... | |
| virtual ossim_uint32 | getSizePerBand () const |
| Returns the number of pixels in a single band in a tile. More... | |
| virtual ossim_uint32 | getSizePerBandInBytes () const |
| Returns the number of bytes in single band of the tile. More... | |
| virtual ossim_uint32 | getDataSizeInBytes () const |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the total number of bytes for all bands. More... | |
| virtual void | makeBlank () |
| Initializes data to null pixel values. More... | |
| Initialize the data buffer. More... | |
| virtual bool | write (const ossimFilename &f) const |
| Writes tile to stream. More... | |
| virtual void | copyTileBandToNormalizedBuffer (ossim_uint32 band, ossim_float64 *buf) const |
| Will copy this tiles specified band number to the normalized buffer. More... | |
| virtual void | copyTileBandToNormalizedBuffer (ossim_uint32 band, ossim_float32 *buf) const |
| virtual bool | isWithin (ossim_int32 x, ossim_int32 y) |
| virtual void | setValue (ossim_int32 x, ossim_int32 y, ossim_float64 color) |
| virtual void | loadBand (const void *src, const ossimIrect &src_rect, ossim_uint32 band) |
| virtual void | loadBand (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossim_uint32 band) |
| virtual void | loadTile (const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type) |
| virtual void | loadTileWithAlpha (const void *src, const ossimIrect &src_rect, ossimInterleaveType il_type) |
| virtual void | loadTile (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type) |
| virtual void | nullTileAlpha (const ossim_uint8 *src, const ossimIrect &src_rect, bool mutliplyAlphaFlag=false) |
| virtual void | nullTileAlpha (const ossim_uint8 *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, bool multiplyAlphaFlag=false) |
| virtual void | loadTile (const ossimImageData *src) |
| Will load a tile of different types. More... | |
| virtual void | loadTileFrom1Band (const ossimImageData *data) |
| virtual void | loadTileFrom1Band (const void *src, const ossimIrect &src_rect) |
| virtual void | loadShortBand (const void *src, const ossimIrect &src_rect, ossim_uint32 band, bool swap_bytes=false) |
| Specialized to load a tile from a short (16 bit scalar type) buffer. More... | |
| virtual void | unloadBand (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, ossimInterleaveType il_type=OSSIM_BSQ, OverwriteBandRule ow_type=NULL_RULE) const |
| This routine is designed for overwriting a selected band of the destination buffer 'dest' by an independent selected band of the source buffer according to a user-selected rule, defined by OverwriteBandRule. More... | |
| virtual void | unloadBand (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type=OSSIM_BSQ, OverwriteBandRule ow_type=NULL_RULE) const |
| virtual void | unloadBand (void *dest, const ossimIrect &dest_rect, ossim_uint32 src_band) const |
| virtual void | unloadBand (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossim_uint32 src_band) const |
| virtual void | unloadTile (void *dest, const ossimIrect &dest_rect, ossimInterleaveType il_type) const |
| virtual void | unloadTile (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossimInterleaveType il_type) const |
| virtual void | unloadTileToBipAlpha (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| virtual bool | isPointWithin (const ossimIpt &point) const |
| virtual bool | isPointWithin (ossim_int32 x, ossim_int32 y) const |
| virtual void | stretchMinMax () |
| Performs linear stretch on tile data from min/max to limits of scalar type. More... | |
| virtual void | computeAlphaChannel () |
| Computes the alpha channel. More... | |
| virtual void | copyLine (const void *src, ossim_int32 lineNumber, ossim_int32 lineStartSample, ossim_int32 lineStopSample, ossimInterleaveType lineInterleave) |
| Method to copy a single line to the tile. More... | |
| void | setIndexedFlag (bool flag) |
| Sets the indexed flag. More... | |
| bool | getIndexedFlag () const |
| ossim_float64 | percentFull () const |
| Returns the percentage (0-100) of data buffer containing non-null (valid) entries. More... | |
| virtual bool | isEqualTo (const ossimDataObject &rhs, bool deepTest=false) const |
| void | computeMinMaxPix (T, vector< ossim_float64 > &minBands, vector< ossim_float64 > &maxBands) const |
| void | computeMinMaxNulPix (T, vector< ossim_float64 > &minBands, vector< ossim_float64 > &maxBands, vector< ossim_float64 > &nulBands) const |
Public Member Functions inherited from ossimRectilinearDataObject | |
| ossimRectilinearDataObject () | |
| ossimRectilinearDataObject (const ossimRectilinearDataObject &rhs) | |
| ossimRectilinearDataObject (ossim_uint32 numberOfSpatialComponents, ossimSource *owner, ossim_uint32 numberOfDataComponents, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL) | |
| ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 length, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL) | |
| This is a helper constructor that allows one to instantiate a one dimensional Spatial component with N number of data components. More... | |
| ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 width, ossim_uint32 height, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL) | |
| This is a helper constructor that allows one to instantiate a two dimensional Spatial component (WidthxHeight) with N number of data components. More... | |
| ossimRectilinearDataObject (ossimSource *owner, ossim_uint32 numberOfDataComponents, ossim_uint32 width, ossim_uint32 height, ossim_uint32 depth, ossimScalarType scalarType=OSSIM_SCALAR_UNKNOWN, ossimDataObjectStatus status=OSSIM_NULL) | |
| This is a helper constructor that allows one to instantiate a two dimensional Spatial component (WidthxHeightxDepth) with N number of data components. More... | |
| virtual | ~ossimRectilinearDataObject () |
| virtual void | setNumberOfDataComponents (ossim_uint32 n) |
| How many components make up this data object. More... | |
| virtual void | setSpatialExtents (ossim_uint32 *extents, ossim_uint32 size) |
| virtual void | setScalarType (ossimScalarType type) |
| See ossimScalarType in ossimConstants for a full list. More... | |
| virtual ossim_uint32 | getNumberOfDataComponents () const |
| virtual ossim_uint32 | getNumberOfSpatialComponents () const |
| virtual const ossim_uint32 * | getSpatialExtents () const |
| virtual ossimScalarType | getScalarType () const |
| virtual ossim_uint32 | getScalarSizeInBytes () const |
| virtual void | assign (const ossimRectilinearDataObject *data) |
| virtual ossim_uint32 | computeSpatialProduct () const |
| virtual const ossimRectilinearDataObject & | operator= (const ossimRectilinearDataObject &rhs) |
Public Member Functions inherited from ossimDataObject | |
| ossimDataObject (ossimSource *source=0, ossimDataObjectStatus status=OSSIM_STATUS_UNKNOWN) | |
| ossimDataObject (const ossimDataObject &rhs) | |
| virtual | ~ossimDataObject () |
| virtual void | setOwner (ossimSource *aSource) |
| Sets the owner of this Data object. More... | |
| virtual ossimSource * | getOwner () |
| virtual const ossimSource * | getOwner () const |
| virtual void | setDataObjectStatus (ossimDataObjectStatus status) const |
| Full list found in ossimConstants.h. More... | |
| virtual ossimDataObjectStatus | getDataObjectStatus () const |
| virtual ossimString | getDataObjectStatusString () const |
| virtual ossim_uint32 | getObjectSizeInBytes () const |
| virtual bool | isInitialize () const |
| This is to be overriden in the derived classes so they can check If their data is null. More... | |
| virtual const ossimDataObject * | operator= (const ossimDataObject *rhs) |
| virtual const ossimDataObject & | operator= (const ossimDataObject &rhs) |
| virtual bool | operator== (const ossimDataObject &rhs) const |
| virtual bool | operator!= (const ossimDataObject &rhs) const |
| ossimObject () | |
| virtual | ~ossimU11ImageData () |
| ossimU11ImageData () | |
Protected Member Functions inherited from ossimImageData | |
| void | copyLineTemplate (T dummyTemplate, const void *src, ossim_int32 lineNumber, ossim_int32 lineStartSample, ossim_int32 lineStopSample, ossimInterleaveType lineInterleave) |
| Templated copy line method. More... | |
| void | stretchMinMax (T dummyTemplate) |
| Templated stretch method. More... | |
| void | computeAlphaChannel (T dummyTemplate) |
| Templated compute alpha channel. More... | |
| ossimDataObjectStatus | validate (T dummyTemplate) const |
| Templated validate method. More... | |
| void | makeBlank (T dummyTemplate) |
| Templated makeBlank method. More... | |
| ossim_float64 | computeMeanSquaredError (T dummyTemplate, ossim_float64 meanValue, ossim_uint32 bandNumber) const |
| Templated computeMeanSquaredError method. More... | |
| ossim_float64 | computeAverageBandValue (T dummyTemplate, ossim_uint32 bandNumber) const |
| Templated computeAverageBandValue method. More... | |
| void | loadTileFromBip (const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBipAlpha (const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBil (const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBsq (const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBip (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | loadTileFromBil (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | loadTileFromBsq (const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | unloadTileToBip (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadTileToBil (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadTileToBsq (void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| virtual void | unloadBandToBsq (void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, OverwriteBandRule ow_type=NULL_RULE) const |
| Called from public unloadBand() routines that have an OverwriteBandRule interface. More... | |
| void | copyTileToNormalizedBuffer (T dummyTemplate, ossim_float64 *buf) const |
| Copies entire tile to buf passed in. More... | |
| void | copyTileToNormalizedBuffer (T dummyTemplate, ossim_float32 *buf) const |
| void | copyTileToNormalizedBuffer (T dummyTemplate, ossim_uint32 band, ossim_float64 *buf) const |
| void | copyTileToNormalizedBuffer (T dummyTemplate, ossim_uint32 band, ossim_float32 *buf) const |
| void | copyNormalizedBufferToTile (T dummyTemplate, ossim_float64 *buf) |
| Copies buf passed in to tile. More... | |
| void | copyNormalizedBufferToTile (T dummyTemplate, ossim_float32 *buf) |
| void | copyNormalizedBufferToTile (T dummyTemplate, ossim_uint32 band, ossim_float64 *buf) |
| void | copyNormalizedBufferToTile (T dummyTemplate, ossim_uint32 band, ossim_float32 *buf) |
| void | computeMinMaxPix (T dummyValue, std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands) const |
| void | computeMinMaxNulPix (T dummyValue, std::vector< ossim_float64 > &minBands, std::vector< ossim_float64 > &maxBands, std::vector< ossim_float64 > &nulBands) const |
| void | loadBandTemplate (T, const void *src, const ossimIrect &src_rect, ossim_uint32 band) |
| void | loadBandTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, ossim_uint32 band) |
| void | nullTileAlphaTemplate (T, const ossim_uint8 *src, const ossimIrect &src_rect, const ossimIrect &clip_rect, bool multiplyAlphaFlag=false) |
| void | loadTileFromBipTemplate (T, const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBipAlphaTemplate (T, const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBipTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | loadTileFromBipAlphaTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | loadTileFromBilTemplate (T, const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBilTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | loadTileFromBsqTemplate (T, const void *src, const ossimIrect &src_rect) |
| void | loadTileFromBsqTemplate (T, const void *src, const ossimIrect &src_rect, const ossimIrect &clip_rect) |
| void | unloadTileToBipTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadTileToBipAlphaTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadTileToBilTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadTileToBsqTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect) const |
| void | unloadBandTemplate (T, void *dest, const ossimIrect &dest_rect, const ossimIrect &clip_rect, ossim_uint32 band) const |
| void | unloadBandToBsqTemplate (T, void *dest, ossim_uint32 src_band, ossim_uint32 dest_band, const ossimIrect &dest_rect, const ossimIrect &clip_rect, OverwriteBandRule ow_type=NULL_RULE) const |
| void | createTestTile (T) |
| Creates a test tile for scalar type for testing only. More... | |
| virtual void | initializeDefaults () |
| initializeDefaults() Resizes and sets min/max/null arrays to number of bands and some default value for scalar type. More... | |
| virtual void | initializeMinDefault () |
| initializeMinDefault() Resizes theMinPixelValue array to number of bands and initializes to the default min for scalar type. More... | |
| virtual void | initializeMaxDefault () |
| initializeMaxDefault() Resizes theMaxPixelValue array to number of bands and initializes to the default max for scalar type. More... | |
| virtual void | initializeNullDefault () |
| initializeNullDefault() Resizes theNullPixelValue array to number of bands and initializes to the default null for scalar type. More... | |
| bool | hasSameDimensionsAs (ossimImageData *data) const |
Static Private Attributes | |
| static const ossimNormalizedU11RemapTable | m_remapTable |
Definition at line 30 of file ossimU11ImageData.h.
| ossimU11ImageData::ossimU11ImageData | ( | ossimSource * | source, |
| ossim_uint32 | bands = 1 |
Definition at line 40 of file ossimU11ImageData.cpp.
| ossim_uint32 | bands, | ||
| ossim_uint32 | width, | ||
| ossim_uint32 | height | ||
Definition at line 49 of file ossimU11ImageData.cpp.
| ossimU11ImageData::ossimU11ImageData | ( | const ossimU11ImageData & | rhs | ) |
Definition at line 62 of file ossimU11ImageData.cpp.
protectedvirtual |
Definition at line 67 of file ossimU11ImageData.cpp.
protected |
Definition at line 33 of file ossimU11ImageData.cpp.
References ossimRectilinearDataObject::m_scalarType, and OSSIM_USHORT11.
Referenced by dup().
Definition at line 286 of file ossimU11ImageData.cpp.
References ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), and isNull().
It will then do a SUM[(Mean - Actual)^2]/width*height.
This is the average variance from the passed in mean. Basically think of the mean as a completely grey image and we would like to see how this image varies from the passed in mean.
Definition at line 255 of file ossimU11ImageData.cpp.
References ossimImageData::getHeight(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), and isNull().
Will use the memory that you pass in to normalize this data object.
Reimplemented from ossimImageData.
Definition at line 170 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, and size.
Definition at line 134 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimImageData::getWidth(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, and size.
Copies buf passed in to tile. Data is unnormalized to the tile's scalar type. The "buf" passed to method is assumed to be at least as big as the tiles: "getSize() * sizeof(double)"
Definition at line 439 of file ossimU11ImageData.cpp.
References ossimObject::getClassName(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimNormalizedU11RemapTable::pixFromNorm(), and size.
Definition at line 556 of file ossimU11ImageData.cpp.
Will copy the normalized buffer to this tiles specified band. If band is out of range then nothing is done and returns.
Definition at line 468 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimObject::getClassName(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), ossimNormalizedU11RemapTable::pixFromNorm(), and size.
Definition at line 586 of file ossimU11ImageData.cpp.
Copies entire tile to buf passed in. Data put in buf is normalized. The "buf" passed to method is assumed to be at least as big as: "getSize() * sizeof(double)"
Definition at line 379 of file ossimU11ImageData.cpp.
References ossimObject::getClassName(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimErrorCodes::OSSIM_ERROR, ossimSetError(), and size.
Will copy this tiles specified band number to the normalized buffer. if the band is out of range then nothing is done and returns.
Definition at line 410 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimObject::getClassName(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), ossimErrorCodes::OSSIM_ERROR, ossimSetError(), and size.
Definition at line 528 of file ossimU11ImageData.cpp.
Definition at line 498 of file ossimU11ImageData.cpp.
Definition at line 71 of file ossimU11ImageData.cpp.
References ossimU11ImageData().
| void ossimU11ImageData::fill | ( | ossim_uint32 | band, |
| double | value | ||
Definition at line 336 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), OSSIM_STATUS_UNKNOWN, and ossimDataObject::setDataObjectStatus().
inlinevirtual |
Definition at line 183 of file ossimU11ImageData.h.
References m_remapTable.
will go to the band and offset and compute the normalized float and return it back to the caller through the result argument.
Definition at line 109 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getUshortBuf(), ossimImageData::isValidBand(), m_remapTable, ossimNormalizedU11RemapTable::normFromPix(), and OSSIM_NULL.
| bool ossimU11ImageData::isNull | ( | ossim_uint32 | offset | ) | const |
Definition at line 353 of file ossimU11ImageData.cpp.
References ossimImageData::getNumberOfBands(), ossimImageData::getUshortBuf(), and ossimImageData::m_nullPixelValue.
Referenced by computeAverageBandValue(), and computeMeanSquaredError().
This will assign to this object a normalized value by unnormalizing to its native type.
Definition at line 121 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getUshortBuf(), ossimImageData::isValidBand(), m_remapTable, OSSIM_NULL, and ossimNormalizedU11RemapTable::pixFromNorm().
| void ossimU11ImageData::setNull | ( | ossim_uint32 | offset | ) |
Definition at line 368 of file ossimU11ImageData.cpp.
Definition at line 314 of file ossimU11ImageData.cpp.
References ossimImageData::getUshortBuf(), ossimImageData::isWithin(), ossimRectilinearDataObject::m_dataBuffer, ossimRectilinearDataObject::m_numberOfDataComponents, ossimImageData::m_origin, ossimRectilinearDataObject::m_spatialExtents, ossimIpt::x, x, ossimIpt::y, and y.
Will take the normalized input and convert it to this tile's data type. Example: if this tile is of type UCHAR and its input is of type NORALIZED_FLOAT it will unnormalize the data by doing:
minPix + normalizedInput*(maxPix-minPix)
on a per band basis.
Definition at line 206 of file ossimU11ImageData.cpp.
References ossimImageData::getBuf(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimRectilinearDataObject::m_numberOfDataComponents, m_remapTable, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, and size.
Definition at line 76 of file ossimU11ImageData.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimImageData::getSize(), ossimImageData::getSizePerBand(), ossimImageData::getUshortBuf(), ossimRectilinearDataObject::m_dataBuffer, OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, OSSIM_PARTIAL, and ossimDataObject::setDataObjectStatus().
staticprivate |
Definition at line 178 of file ossimU11ImageData.h.
Referenced by convertToNormalizedDouble(), convertToNormalizedFloat(), copyNormalizedBufferToTile(), copyTileToNormalizedBuffer(), getMinNormalizedPix(), getNormalizedFloat(), setNormalizedFloat(), and unnormalizeInput().
