#include <ossimTraceManager.h>
| void | setTracePattern (const ossimString &pattern) |
| Sets "thePattern" to "pattern", then calls setTraceFlags(true). More... | |
| void | addTrace (ossimTrace *traceObj) |
| void | removeTrace (ossimTrace *traceObj) |
| static ossimTraceManager * | instance () |
| ossimTraceManager () | |
| Protected default constructor. More... | |
Private Member Functions | |
| void | setTraceFlags (bool flag) |
| Loops through "theTraceList" and sets any trace object's enable flag to flag if it matches regular expression of "thePattern". More... | |
Private Attributes | |
| ossimString | thePattern |
| The regular expression pattern like "ossimDynamic|ossimGdal". More... | |
| std::vector< ossimTrace * > | theTraceList |
| The list of trace objects. More... | |
Static Private Attributes | |
| static ossimTraceManager * | theInstance = 0 |
| The instance of this manager. More... | |
Definition at line 22 of file ossimTraceManager.h.
protected |
Definition at line 24 of file ossimTraceManager.cpp.
References theInstance.
Referenced by instance().
| void ossimTraceManager::addTrace | ( | ossimTrace * | traceObj | ) |
| traceObj | ossimTrace* to add to "theTraceList". |
Definition at line 45 of file ossimTraceManager.cpp.
References ossimString::c_str(), ossimRegExp::compile(), ossimRegExp::find(), ossimTrace::getTraceName(), ossimTrace::setTraceFlag(), ossimString::size(), thePattern, and theTraceList.
Referenced by ossimTrace::ossimTrace().
static |
Definition at line 29 of file ossimTraceManager.cpp.
References ossimTraceManager(), and theInstance.
Referenced by ossimTrace::ossimTrace(), and ossimTrace::~ossimTrace().
| void ossimTraceManager::removeTrace | ( | ossimTrace * | traceObj | ) |
| traceObj | ossimTrace* to remove from "theTraceList". |
Definition at line 80 of file ossimTraceManager.cpp.
References theTraceList.
Referenced by ossimTrace::~ossimTrace().
private |
For trace objects not matching "thePattern" no action is taken.
Definition at line 92 of file ossimTraceManager.cpp.
References ossimString::c_str(), ossimRegExp::compile(), ossimRegExp::find(), thePattern, and theTraceList.
Referenced by setTracePattern().
| void ossimTraceManager::setTracePattern | ( | const ossimString & | pattern | ) |
| pattern | Regular expression to enable trace for. |
Definition at line 39 of file ossimTraceManager.cpp.
References setTraceFlags(), and thePattern.
staticprivate |
Definition at line 60 of file ossimTraceManager.h.
Referenced by instance(), and ossimTraceManager().
private |
Definition at line 63 of file ossimTraceManager.h.
Referenced by addTrace(), setTraceFlags(), and setTracePattern().
private |
Definition at line 66 of file ossimTraceManager.h.
Referenced by addTrace(), removeTrace(), and setTraceFlags().
