Utility class provides the server interface to ossimTool-derived functionality via TCP sockets Results are returned either as streamed text (for non-image responses such as image info) or streamed binary file representing imagery or vector products. More...
#include <ossimToolServer.h>
| ossimToolServer () | |
| ~ossimToolServer () | |
| void | startListening (const char *portid) |
Private Member Functions | |
| void | initSocket (const char *portid) |
| bool | processOssimRequest (struct sockaddr_in &cli_addr) |
| bool | runCommand (ossimString &command) |
| void | writeSocket (const char *buf, int bufsize) |
| bool | sendFile (const ossimFilename &fname) |
| void | error (const char *msg) |
| bool | acknowledgeRcvd () |
Static Private Member Functions | |
| static void | sigchld_handler (int s) |
Private Attributes | |
| int | m_svrsockfd |
| int | m_clisockfd |
| char * | m_buffer |
Clients interfacing to this class should know the commands available (or execute the command "help" and view the text response).
Definition at line 21 of file ossimToolServer.h.
| ossimToolServer::ossimToolServer | ( | ) |
Definition at line 53 of file ossimToolServer.cpp.
| ossimToolServer::~ossimToolServer | ( | ) |
private |
Definition at line 291 of file ossimToolServer.cpp.
References _DEBUG_, error(), m_buffer, m_clisockfd, and n.
Referenced by runCommand(), and sendFile().
private |
Definition at line 207 of file ossimToolServer.cpp.
Referenced by acknowledgeRcvd(), initSocket(), processOssimRequest(), runCommand(), sendFile(), startListening(), and writeSocket().
private |
Definition at line 141 of file ossimToolServer.cpp.
References error(), m_svrsockfd, OINFO, and sigchld_handler().
Referenced by startListening().
private |
Definition at line 434 of file ossimToolServer.cpp.
References _DEBUG_, error(), m_buffer, m_clisockfd, MAX_BUF_LEN, n, runCommand(), and ossimString::trim().
private |
Definition at line 304 of file ossimToolServer.cpp.
References acknowledgeRcvd(), ossimString::after(), ossimString::before(), ossimToolFactoryBase::createTool(), ossimString::empty(), error(), ossimTool::execute(), ossimRefPtr< T >::get(), ossimToolFactoryBase::getCapabilities(), ossimChipProcTool::getProductFilename(), ossimTool::helpRequested(), ossimTool::initialize(), ossimToolRegistry::instance(), ossimTool::isChipProcessor(), m_buffer, m_clisockfd, MAX_BUF_LEN, n, sendFile(), ossimString::trim(), ossimRefPtr< T >::valid(), writeSocket(), and x.
Referenced by processOssimRequest().
private |
Definition at line 230 of file ossimToolServer.cpp.
References _DEBUG_, acknowledgeRcvd(), ossimString::chars(), error(), ossimFilename::file(), m_buffer, MAX_BUF_LEN, n, and writeSocket().
Referenced by runCommand().
staticprivate |
Definition at line 199 of file ossimToolServer.cpp.
Referenced by initSocket().
| void ossimToolServer::startListening | ( | const char * | portid | ) |
Definition at line 65 of file ossimToolServer.cpp.
References error(), FORK_PROCESS, initSocket(), m_buffer, m_clisockfd, m_svrsockfd, n, OINFO, and processOssimRequest().
private |
Definition at line 213 of file ossimToolServer.cpp.
References error(), m_clisockfd, and n.
private |
Definition at line 41 of file ossimToolServer.h.
Referenced by acknowledgeRcvd(), processOssimRequest(), runCommand(), sendFile(), and startListening().
private |
Definition at line 40 of file ossimToolServer.h.
Referenced by acknowledgeRcvd(), processOssimRequest(), runCommand(), startListening(), and writeSocket().
private |
Definition at line 39 of file ossimToolServer.h.
Referenced by initSocket(), startListening(), and ~ossimToolServer().
