#include <ossimTempFilename.h>
| ossimTempFilename (const ossimString &tempDir="", const ossimString &prefix="", const ossimString &extension="", bool autodelete=true, bool useWildcardDelete=true) | |
| void | generateRandomFile () |
| void | generateRandomDir () |
| ~ossimTempFilename () | |
Public Member Functions inherited from ossimFilename | |
| ossimFilename () | |
| ossimFilename (const ossimFilename &src) | |
| ossimFilename (const ossimString &src) | |
| ossimFilename (const std::string &src) | |
| ossimFilename (const char *src) | |
| const ossimFilename & | operator= (const ossimFilename &f) |
| template<class Iter > | |
| ossimFilename (Iter s, Iter e) | |
| bool | operator== (const ossimFilename &rhs) const |
| bool | operator== (const ossimString &rhs) const |
| bool | operator== (const char *rhs) const |
| bool | setTimes (ossimLocalTm *accessTime, ossimLocalTm *modTime, ossimLocalTm *createTime) const |
| Writes f to the output stream os. More... | |
| bool | getTimes (ossimLocalTm *accessTime, ossimLocalTm *modTime, ossimLocalTm *createTime) const |
| ossim_int64 | lastAccessed () const |
| Time in seconds since last accessed. More... | |
| bool | touch () const |
| ossimFilename | expand () const |
| Method to do file name expansion. More... | |
| bool | exists () const |
| bool | isFile () const |
| bool | isDir () const |
| bool | isReadable () const |
| bool | isUrl () const |
| bool | isWriteable () const |
| bool | isExecutable () const |
| ossim_int64 | fileSize () const |
| ossimString | ext () const |
| ossimFilename | path () const |
| ossimFilename | drive () const |
| ossimFilename | file () const |
| ossimFilename | fileNoExtension () const |
| ossimFilename | noExtension () const |
| ossimFilename & | setExtension (const ossimString &e) |
| Sets the extension of a file name. More... | |
| ossimFilename & | setDrive (const ossimString &d) |
| Sets the file path and drive. More... | |
| ossimFilename & | setPath (const ossimString &p) |
| ossimFilename & | setFile (const ossimString &f) |
| void | split (ossimString &drivePart, ossimString &pathPart, ossimString &filePart, ossimString &extPart) const |
| void | merge (const ossimString &drivePart, const ossimString &pathPart, const ossimString &filePart, const ossimString &extPart) |
| ossimFilename | dirCat (const ossimFilename &file) const |
| bool | createDirectory (bool recurseFlag=true, int perm=0775) const |
| bool | rename (const ossimFilename &destFile, bool overwriteDestinationFlag=true) const |
| bool | remove () const |
| bool | wildcardRemove () const |
| bool | copyFileTo (const ossimFilename &outputFile) const |
| Copies this file to output file. More... | |
| bool | isRelative () const |
| Checks whether file name is relative or absolute. More... | |
| bool | needsExpansion () const |
| Method to check if expansion is needed. More... | |
| char | getPathSeparator () const |
| ossimFilename & | appendTimestamp () |
| Convenience method to append a generic timestamp to the base-name portion of the filename. More... | |
| ossimFilename & | append (const ossimString &append_this_to_filename) |
| Convenience method to append a string to the base-name portion of the filename. More... | |
| std::string | native () const |
Public Member Functions inherited from ossimString | |
| ossimString () | |
| ossimString (const std::string &s) | |
| constructor that takes a std::string More... | |
| ossimString (const char *aString) | |
| constructor that takes char* NOTE: std::string construtor throws exception given null pointer; hence, the null check. More... | |
| ossimString (const ossimString &aString) | |
| copy constructor More... | |
| ossimString (std::string::size_type n, char c) | |
| constructor - constructs with n copies of c More... | |
| ossimString (char aChar) | |
| constructor - constructs with 1 c. More... | |
| ossimString (Iter startIter, Iter endIter) | |
| ~ossimString () | |
| destructor More... | |
| bool | contains (char aChar) const |
| bool | contains (const ossimString &aString) const |
| bool | contains (const char *aString) const |
| operator const std::string & () const | |
| Type conversion operator to a const std::string&. More... | |
| operator std::string & () | |
| Type conversion operator to a std::string&. More... | |
| operator const char * () const | |
| Type conversion operator to a const char*. More... | |
| const char * | chars () const |
| For backward compatibility. More... | |
| operator bool () const | |
| const ossimString & | operator= (const std::string &s) |
| const ossimString & | operator= (const char *s) |
| const ossimString & | operator= (char c) |
| const ossimString & | operator= (const ossimString &s) |
| const ossimString & | operator+= (const ossimString &s) |
| const ossimString & | operator+= (const std::string &s) |
| const ossimString & | operator+= (const char *s) |
| const ossimString & | operator+= (char c) |
| const ossimString & | append (const ossimString &s) |
| const ossimString & | append (const std::string &s) |
| const ossimString & | append (const char *s) |
| const char & | at (std::string::size_type n) const |
| Provides access to the data contained in the string. More... | |
| char & | at (std::string::size_type n) |
| const ossimString & | append (std::string::size_type n, char c) |
| Append n copies of c to *this. More... | |
| ossimString | operator+ (const ossimString &s) const |
| ossimString | operator+ (const std::string &s) const |
| ossimString | operator+ (const char *s) const |
| ossimString | operator+ (char c) const |
| Test if this ossimString is equal to another ossimString. More... | |
| Test if this ossimString is equal to a C sting. More... | |
| bool | operator!= (const ossimString &rhs) const |
| Test if this ossimString is not equal to another ossimString. More... | |
| bool | operator!= (const char *rhs) const |
| Test if this ossimString is not equal to a C sting. More... | |
| bool | operator< (const ossimString &rhs) const |
| bool | operator<= (const ossimString &rhs) const |
| bool | operator> (const ossimString &rhs) const |
| bool | operator>= (const ossimString &rhs) const |
| char & | operator[] (std::string::size_type i) |
| const char & | operator[] (std::string::size_type i) const |
| std::string & | insert (std::string::size_type pos, const char *s) |
| If pos > size(), throws out_of_range. More... | |
| void | push_back (char c) |
| Equivalent to insert(end(), c). More... | |
| std::string | substr (std::string::size_type pos=0, std::string::size_type n=std::string::npos) const |
| Equivalent to basic_string(*this, pos, n). More... | |
| ossimString | trim (const ossimString &valueToTrim=ossimString(" \\)) const |
| this will strip lead and trailing character passed in. More... | |
| ossimString & | trim (const ossimString &valueToTrim=ossimString(" \\)) |
| ossimString | beforePos (std::string::size_type pos) const |
| ossimString | afterPos (std::string::size_type pos) const |
| ossimString | substitute (const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) const |
| Substitutes searchKey string with replacementValue and returns a string. More... | |
| ossimString & | gsub (const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false) |
| Substitutes searchKey string with replacementValue and returns a reference to *this. More... | |
| std::vector< ossimString > | explode (const ossimString &delimeter) const |
| ossimString | expandEnvironmentVariable () const |
| If the variable "$(env_var_name)" is found in the string, where "env_var_name" is any system environment variable resolvable by the getenv() function, the variable is expanded in place and the result returned. More... | |
| ossimString & | upcase () |
| Upcases this string. More... | |
| ossimString | upcase () const |
| ossimString & | downcase () |
| Downcases this string. More... | |
| ossimString | downcase () const |
| const char * | c_str () const |
| Returns a pointer to a null-terminated array of characters representing the string's contents. More... | |
| const char * | data () const |
| Returns a pointer to an array of characters (not necessarily null-terminated) representing the string's contents. More... | |
| std::string::size_type | size () const |
| std::string::size_type | length () const |
| bool | empty () const |
| const std::string & | string () const |
| std::string & | string () |
| std::string::iterator | begin () |
| std::string::iterator | end () |
| std::string::const_iterator | begin () const |
| std::string::const_iterator | end () const |
| void | clear () |
| Erases the entire container. More... | |
| std::string::iterator | erase (std::string::iterator p) |
| Erases the character at position p. More... | |
| std::string::iterator | erase (std::string::iterator first, std::string::iterator last) |
| Erases the range [first, last). More... | |
| std::string & | erase (std::string::size_type pos=0, std::string::size_type n=std::string::npos) |
| Erases a range. More... | |
| std::string::size_type | find (const std::string &s, std::string::size_type pos=0) const |
| Searches for s as a substring of *this, beginning at character pos of *this. More... | |
| std::string::size_type | find (const char *s, std::string::size_type pos, std::string::size_type n) const |
| Searches for the first n characters of s as a substring of *this, beginning at character pos of *this. More... | |
| std::string::size_type | find (const char *s, std::string::size_type pos=0) const |
| Searches for a null-terminated character array as a substring of *this, beginning at character pos of *this. More... | |
| std::string::size_type | find (char c, std::string::size_type pos=0) const |
| Searches for the character c, beginning at character position pos. More... | |
| std::string::size_type | rfind (const std::string &s, std::string::size_type pos=0) const |
| Searches backward for s as a substring of *this, beginning at character position min(pos, size()). More... | |
| std::string::size_type | rfind (const char *s, std::string::size_type pos, std::string::size_type n) const |
| Searches backward for the first n characters of s as a substring of *this, beginning at character position min(pos, size()). More... | |
| std::string::size_type | rfind (const char *s, std::string::size_type pos=0) const |
| Searches backward for a null-terminated character array as a substring of *this, beginning at character min(pos, size()). More... | |
| std::string::size_type | rfind (char c, std::string::size_type pos=0) const |
| Searches backward for the character c, beginning at character position min(pos, size(). More... | |
| std::string::size_type | find_first_of (char c, std::string::size_type pos=0) const |
| Equivalent to find(c, pos). More... | |
| std::string::size_type | find_first_not_of (char c, std::string::size_type pos=0) const |
| Returns the smallest character position N such that pos <= N < size(), and such that (*this)[N] does not compare equal to c. More... | |
| std::string::size_type | find_first_of (const char *s, std::string::size_type pos=0) const |
| Equivalent to find_first_of(s, pos, traits::length(s)). More... | |
| std::string::size_type | find_first_not_of (const char *s, std::string::size_type pos=0) const |
Equivalent to find_first_not_of(s, pos, traits::length(s)). More... | |
| std::string::size_type | find_last_of (char c, std::string::size_type pos=std::string::npos) const |
| Equivalent to rfind(c, pos). More... | |
| std::string & | assign (std::string::size_type n, char c) |
| Erases the existing characters and replaces them by n copies of c. More... | |
| std::string & | replace (std::string::size_type pos, std::string::size_type n, const std::string &s) |
| Replaces a substring of *this with the string s. More... | |
| std::string & | replace (std::string::iterator first, std::string::iterator last, const std::string &s) |
| brief Equivalent to insert(erase(first, last), s.begin(), s.end()). More... | |
| std::string & | replace (std::string::size_type pos, std::string::size_type n, const std::string &s, std::string::size_type pos1, std::string::size_type n1) |
| Replaces a substring of *this with a substring of s. More... | |
| void | reserve (std::string::size_type n) |
| Requests that the string's capacity be changed. More... | |
| ossimString | before (const ossimString &str, std::string::size_type pos=0) const |
| METHOD: before(str, pos) Returns string beginning at pos and ending one before the token str If string not found or pos out of range the whole string will be returned. More... | |
| ossimString | after (const ossimString &str, std::string::size_type pos=0) const |
| METHOD: after(str, pos) Returns string immediately after the token str. More... | |
| char * | stringDup () const |
| bool | toBool () const |
| String to numeric methods. More... | |
| ossim_uint8 | toUInt8 () const |
| int | toInt () const |
| ossim_int16 | toInt16 () const |
| ossim_uint16 | toUInt16 () const |
| ossim_int32 | toInt32 () const |
| ossim_uint32 | toUInt32 () const |
| ossim_int64 | toInt64 () const |
| ossim_uint64 | toUInt64 () const |
| ossim_int64 | memoryUnitToInt64 () const |
| This takes a string and will test for numeric followed by a unit type: More... | |
| long | toLong () const |
| toLong's deprecated, please use the toInts... More... | |
| unsigned long | toULong () const |
| ossim_float32 | toFloat32 () const |
| ossim_float64 | toFloat64 () const |
| double | toDouble () const |
| void | split (std::vector< ossimString > &result, const ossimString &separatorList, bool skipBlankFields=false) const |
| Splits this string into a vector of strings (fields) using the delimiter list specified. More... | |
| std::vector< ossimString > | split (const ossimString &separatorList, bool skipBlankFields=false) const |
| const ossimString & | join (const std::vector< ossimString > &stringList, const ossimString &separator) |
| ossimString | beforeRegExp (const char *regularExpressionPattern) const |
| Returns from start of string up to but not including found pattern. More... | |
| ossimString | fromRegExp (const char *regularExpressionPattern) const |
| Returns from position of found pattern to end of string. More... | |
| ossimString | afterRegExp (const char *regularExpressionPattern) const |
| Returns from position after found pattern to end of string. More... | |
| ossimString | match (const char *regularExpressionPattern) const |
| Returns from found pattern to end of pattern. More... | |
| ossimString | replaceAllThatMatch (const char *regularExpressionPattern, const char *value="") const |
| ossimString | replaceStrThatMatch (const char *regularExpressionPattern, const char *value="") const |
| ossimString | urlEncode () const |
| ossimString | getOssimId () const |
| If OSSIM_ID_ENABLED returns the OSSIM_ID which currently is the expanded cvs. More... | |
| void | generate (bool createAsDirectoryFlag) |
Protected Member Functions inherited from ossimFilename | |
| void | converPathSeparator () |
| Converts slashes of this to internal '/' format. More... | |
Protected Attributes | |
| ossimString | theTempDir |
| ossimString | thePrefix |
| ossimString | theExtension |
| bool | theAutoDeleteFlag |
| bool | theWildCardDeleteFlag |
Protected Attributes inherited from ossimString | |
| std::string | m_str |
Public Types inherited from ossimFilename | |
| enum | AccessModes { OSSIM_READ_WRITE = 6, OSSIM_READ = 4, OSSIM_WRITE = 2, OSSIM_EXE = 1, OSSIM_EXIST = 0 } |
Public Types inherited from ossimString | |
| typedef std::string::const_iterator | const_iterator |
| typedef std::string::iterator | iterator |
| typedef std::string::size_type | size_type |
Static Public Member Functions inherited from ossimFilename | |
| static bool | remove (const ossimFilename &pathname) |
| Removes pathname from filesystem if supported by platform. More... | |
| static bool | wildcardRemove (const ossimFilename &pathname) |
| Will use a wildcard remove. More... | |
Static Public Member Functions inherited from ossimString | |
| static ossimString | upcase (const ossimString &aString) |
| static ossimString | downcase (const ossimString &aString) |
| static bool | toBool (const ossimString &aString) |
| static ossim_uint8 | toUInt8 (const ossimString &aString) |
| static int | toInt (const ossimString &aString) |
| static ossim_int16 | toInt16 (const ossimString &aString) |
| static ossim_uint16 | toUInt16 (const ossimString &aString) |
| static ossim_int32 | toInt32 (const ossimString &aString) |
| static ossim_uint32 | toUInt32 (const ossimString &aString) |
| static ossim_int64 | toInt64 (const ossimString &aString) |
| static ossim_uint64 | toUInt64 (const ossimString &aString) |
| static ossim_int64 | memoryUnitToInt64 (const ossimString &aString) |
| static long | toLong (const ossimString &aString) |
| static unsigned long | toULong (const ossimString &aString) |
| static ossim_float32 | toFloat32 (const ossimString &aString) |
| static ossim_float64 | toFloat64 (const ossimString &aString) |
| static double | toDouble (const ossimString &aString) |
| static ossimString | toString (bool aValue) |
| Numeric to string methods. More... | |
| static ossimString | toString (ossim_int16 aValue) |
| static ossimString | toString (ossim_uint16 aValue) |
| static ossimString | toString (ossim_int32 aValue) |
| static ossimString | toString (ossim_uint32 aValue) |
| static ossimString | toString (ossim_int64 aValue) |
| static ossimString | toString (ossim_uint64 aValue) |
| static ossimString | toString (ossim_float32 aValue, ossim_int32 precision=8, bool fixed=false) |
| static ossimString | toString (ossim_float64 aValue, ossim_int32 precision=15, bool fixed=false) |
| static ossimString | stripLeading (const ossimString &value, char characterToStrip) |
Static Public Attributes inherited from ossimFilename | |
| static const ossimFilename | NIL =("") |
| This was taken from Wx widgets for performing touch and access date stamps. More... | |
Static Protected Attributes inherited from ossimFilename | |
| static const char | OSSIM_NATIVE_PATH_SEPARATOR = '/' |
| static const char | OSSIM_FILENAME_PATH_SEPARATOR = '/' |
Definition at line 18 of file ossimTempFilename.h.
| ossimTempFilename::ossimTempFilename | ( | const ossimString & | tempDir = "", |
| const ossimString & | prefix = "", |
| const ossimString & | extension = "", |
| bool | autodelete = true, |
| bool | useWildcardDelete = true |
Definition at line 20 of file ossimTempFilename.cpp.
| ossimTempFilename::~ossimTempFilename | ( | ) |
Definition at line 33 of file ossimTempFilename.cpp.
References theAutoDeleteFlag, theWildCardDeleteFlag, and ossimFilename::wildcardRemove().
protected |
Definition at line 62 of file ossimTempFilename.cpp.
References ossimString::c_str(), ossimFilename::createDirectory(), ossimFilename::dirCat(), ossimFilename::exists(), ossimEnvironmentUtility::getEnvironmentVariable(), ossimEnvironmentUtility::instance(), ossimFilename::ossimFilename(), ossimFilename::setExtension(), theExtension, thePrefix, theTempDir, and ossimString::toString().
Referenced by generateRandomDir(), and generateRandomFile().
| void ossimTempFilename::generateRandomDir | ( | ) |
Definition at line 57 of file ossimTempFilename.cpp.
References generate().
| void ossimTempFilename::generateRandomFile | ( | ) |
Definition at line 52 of file ossimTempFilename.cpp.
protected |
Definition at line 36 of file ossimTempFilename.h.
Referenced by ~ossimTempFilename().
protected |
Definition at line 35 of file ossimTempFilename.h.
Referenced by generate().
protected |
Definition at line 34 of file ossimTempFilename.h.
protected |
Definition at line 33 of file ossimTempFilename.h.
protected |
Definition at line 37 of file ossimTempFilename.h.
