#include <ossimRpfPathnameRecord.h>
| ossimRpfPathnameRecord () | |
| ossimRpfPathnameRecord (const ossimRpfPathnameRecord &obj) | |
| copy constructor More... | |
| const ossimRpfPathnameRecord & | operator= (const ossimRpfPathnameRecord &rhs) |
| assignment operator More... | |
| void | clearFields () |
| ossimErrorCode | parseStream (std::istream &in, ossimByteOrder byteOrder) |
| void | writeStream (std::ostream &out) |
| Write method. More... | |
| ossimString | getPathname () const |
| void | setPathName (const ossimString &path) |
| Set the pathname and length from string size. More... | |
Private Attributes | |
| ossim_uint16 | m_length |
| ossimString | m_pathname |
Friends | |
| std::ostream & | operator<< (std::ostream &out, const ossimRpfPathnameRecord &data) |
Definition at line 19 of file ossimRpfPathnameRecord.h.
| ossimRpfPathnameRecord::ossimRpfPathnameRecord | ( | ) |
| ossimRpfPathnameRecord::ossimRpfPathnameRecord | ( | const ossimRpfPathnameRecord & | obj | ) |
| void ossimRpfPathnameRecord::clearFields | ( | ) |
Definition at line 46 of file ossimRpfPathnameRecord.cpp.
References m_length, and m_pathname.
Referenced by parseStream().
| ossimString ossimRpfPathnameRecord::getPathname | ( | ) | const |
| const ossimRpfPathnameRecord & ossimRpfPathnameRecord::operator= | ( | const ossimRpfPathnameRecord & | rhs | ) |
assignment operator
Definition at line 36 of file ossimRpfPathnameRecord.cpp.
| ossimErrorCode ossimRpfPathnameRecord::parseStream | ( | std::istream & | in, |
| ossimByteOrder | byteOrder | ||
Definition at line 52 of file ossimRpfPathnameRecord.cpp.
References ossim::byteOrder(), clearFields(), ossimEndian::getSystemEndianType(), m_length, m_pathname, ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, and ossimEndian::swap().
| std::ostream & ossimRpfPathnameRecord::print | ( | std::ostream & | out | ) | const |
Definition at line 104 of file ossimRpfPathnameRecord.cpp.
Referenced by operator<<().
| void ossimRpfPathnameRecord::setPathName | ( | const ossimString & | path | ) |
| path | Path like: ./N03E030 |
Definition at line 116 of file ossimRpfPathnameRecord.cpp.
References m_length, m_pathname, and ossimString::size().
| void ossimRpfPathnameRecord::writeStream | ( | std::ostream & | out | ) |
Write method.
| out | Stream to write to. |
Definition at line 81 of file ossimRpfPathnameRecord.cpp.
References ossimString::c_str(), ossimEndian::getSystemEndianType(), m_length, m_pathname, OSSIM_BIG_ENDIAN, ossimString::size(), and ossimEndian::swap().
friend |
Definition at line 17 of file ossimRpfPathnameRecord.cpp.
private |
Definition at line 56 of file ossimRpfPathnameRecord.h.
Referenced by clearFields(), operator=(), parseStream(), print(), setPathName(), and writeStream().
private |
Definition at line 57 of file ossimRpfPathnameRecord.h.
Referenced by clearFields(), getPathname(), operator=(), parseStream(), print(), setPathName(), and writeStream().
