#include <ossimRpfLocationSection.h>
| ossimRpfComponentLocationRecord () | |
| ossimRpfComponentLocationRecord (const ossimRpfComponentLocationRecord &record) | |
| copy constructor More... | |
| const ossimRpfComponentLocationRecord & | operator= (const ossimRpfComponentLocationRecord &rhs) |
| assignment operator More... | |
| std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| print method that outputs a key/value type format adding prefix to keys. More... | |
| ossimErrorCode | parseStream (std::istream &in, ossimByteOrder endianOrder) |
| void | writeStream (std::ostream &out) |
| Write method. More... | |
Public Attributes | |
| ossim_uint16 | m_componentId |
| ossim_uint32 | m_componentLength |
| ossim_uint32 | m_componentLocation |
Friends | |
| std::ostream & | operator<< (std::ostream &out, const ossimRpfComponentLocationRecord &data) |
Definition at line 24 of file ossimRpfLocationSection.h.
| ossimRpfComponentLocationRecord::ossimRpfComponentLocationRecord | ( | ) |
default constructor
Definition at line 31 of file ossimRpfLocationSection.cpp.
| ossimRpfComponentLocationRecord::ossimRpfComponentLocationRecord | ( | const ossimRpfComponentLocationRecord & | record | ) |
copy constructor
Definition at line 38 of file ossimRpfLocationSection.cpp.
| const ossimRpfComponentLocationRecord & ossimRpfComponentLocationRecord::operator= | ( | const ossimRpfComponentLocationRecord & | rhs | ) |
assignment operator
Definition at line 46 of file ossimRpfLocationSection.cpp.
References m_componentId, m_componentLength, and m_componentLocation.
| ossimErrorCode ossimRpfComponentLocationRecord::parseStream | ( | std::istream & | in, |
| ossimByteOrder | endianOrder | ||
Definition at line 77 of file ossimRpfLocationSection.cpp.
References ossim::byteOrder(), m_componentId, m_componentLength, m_componentLocation, ossimErrorCodes::OSSIM_ERROR, ossimErrorCodes::OSSIM_OK, and ossimEndian::swap().
| std::ostream & ossimRpfComponentLocationRecord::print | ( | std::ostream & | out, |
| const std::string & | prefix = std::string() |
| ) | const |
| out | String to output to. |
| prefix | This will be prepended to key. e.g. Where prefix = "nitf." and key is "file_name" key becomes: "nitf.file_name:" |
Definition at line 58 of file ossimRpfLocationSection.cpp.
References ossimLookUpTable::getEntryString(), ossimRpfComponentIdLut::instance(), m_componentId, m_componentLength, and m_componentLocation.
Referenced by operator<<().
| void ossimRpfComponentLocationRecord::writeStream | ( | std::ostream & | out | ) |
Write method.
| out | Stream to write to. |
Definition at line 103 of file ossimRpfLocationSection.cpp.
References ossim::byteOrder(), m_componentId, m_componentLength, m_componentLocation, OSSIM_BIG_ENDIAN, and ossimEndian::swap().
friend |
Definition at line 26 of file ossimRpfLocationSection.cpp.
| ossim_uint16 ossimRpfComponentLocationRecord::m_componentId |
The component is a 2-Byte unsigned value which identitfies a level-2 component. The table can be found in MIL-STD-2411-1 in section 5.1.1 and in ossimRpfConstants.h.
Definition at line 65 of file ossimRpfLocationSection.h.
Referenced by operator=(), parseStream(), print(), and writeStream().
| ossim_uint32 ossimRpfComponentLocationRecord::m_componentLength |
Is a 4 byte unsigned integer indicating the length in bytes of the component.
Definition at line 71 of file ossimRpfLocationSection.h.
| ossim_uint32 ossimRpfComponentLocationRecord::m_componentLocation |
Is a 4 byte value defining the absolute address (byte number) of the first byte of the component measured from the beginning of the RPF Frame file.
Definition at line 78 of file ossimRpfLocationSection.h.
Referenced by ossimRpfFrame::fillSubFrameBuffer(), ossimRpfHeader::getNewAttributeSectionSubheader(), ossimRpfHeader::getNewBoundaryRectSectSubheader(), ossimRpfHeader::getNewBoundaryRectTable(), ossimRpfHeader::getNewColorGrayscaleSubheader(), ossimRpfHeader::getNewCompressionSection(), ossimRpfHeader::getNewCompressionSectionSubheader(), ossimRpfHeader::getNewCoverageSection(), ossimRpfHeader::getNewFileIndexSubsection(), ossimRpfHeader::getNewFrameFileIndexSectionSubheader(), ossimRpfHeader::getNewImageDescriptionSubheader(), ossimRpfHeader::getNewImageDisplayParameterSubheader(), ossimRpfHeader::getNewMaskSubsection(), operator=(), parseStream(), ossimRpfFrame::populateColorGrayscaleSection(), ossimRpfFrame::populateMasks(), ossimRpfFrame::populateReplaceUpdateTable(), print(), and writeStream().
