#include <ossimRadialDecentLensDistortion.h>
| ossimRadialDecentLensDistortion () | |
| ossimRadialDecentLensDistortion (const ossimDpt &calibratedPrincipalPoint, const NEWMAT::ColumnVector &radialDistortionParameters, const NEWMAT::ColumnVector &decentDistortionParameters) | |
| ossimRadialDecentLensDistortion (const ossimRadialDecentLensDistortion ©) | |
| ossimRadialDecentLensDistortion (const ossimKeywordlist &kwl, const char *prefix) | |
| virtual | ~ossimRadialDecentLensDistortion () |
| virtual void | forward (const ossimDpt &undistorted_point_in, ossimDpt &distorted_point_out) const |
| virtual void | forward (ossimDpt &modify_this) const |
| void | setPrincipalPoint (const ossimDpt pp) |
| void | setRadialDistortionParams (const NEWMAT::ColumnVector ¶ms) |
| void | setDecentDistortionParams (const NEWMAT::ColumnVector ¶ms) |
Public Member Functions inherited from ossim2dTo2dTransform | |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) const |
| virtual void | inverse (ossimDpt &modify_this) const |
| virtual const ossim2dTo2dTransform & | operator= (const ossim2dTo2dTransform &rhs) |
| virtual ossimDpt | getOrigin () const |
| void | setConvergenceThreshold (const double &new_threshold) |
| void | setMaxIterations (int new_max_iters) |
| void | setDxDy (const ossimDpt &dxdy) |
| ossimObject () | |
Static Public Attributes | |
| static const char * | PRINCIPAL_POINT_X_KW = "principal_point_x" |
| static const char * | PRINCIPAL_POINT_Y_KW = "principal_point_y" |
| static const char * | RADIAL_DISTORTION_COEFF_KW = "radial_distortion_coeff_K" |
| static const char * | DECENT_DISTORTION_COEFF_KW = "decent_distortion_coeff_P" |
| virtual double | deltaR (double radius) const |
Protected Member Functions inherited from ossim2dTo2dTransform | |
| ossim2dTo2dTransform () | |
| virtual | ~ossim2dTo2dTransform () |
Protected Attributes | |
| ossimDpt | theCalibratedPrincipalPoint |
| NEWMAT::ColumnVector | theRadialDistortionParameters |
| NEWMAT::ColumnVector | theDecentDistortionParameters |
Protected Attributes inherited from ossim2dTo2dTransform | |
| double | theConvergenceThreshold |
| int | theMaxIterations |
| ossimDpt | theDxDy |
Definition at line 48 of file ossimRadialDecentLensDistortion.h.
inline |
Definition at line 52 of file ossimRadialDecentLensDistortion.h.
inline |
Definition at line 54 of file ossimRadialDecentLensDistortion.h.
inline |
Definition at line 62 of file ossimRadialDecentLensDistortion.h.
| ossimRadialDecentLensDistortion::ossimRadialDecentLensDistortion | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix | ||
Definition at line 34 of file ossimRadialDecentLensDistortion.cpp.
inlinevirtual |
Definition at line 70 of file ossimRadialDecentLensDistortion.h.
protectedvirtual |
default implementation Will solve the polynomial:
k0 + k1*r^2 + k2*r^4 + k3*r^6 + k4*r^8
Definition at line 142 of file ossimRadialDecentLensDistortion.cpp.
References theRadialDistortionParameters.
Referenced by forward().
Implementation of base class 2D-to-2D transformation. The "forward" transformation is defined here as going from an undistorted ideal point to a distorted real point, i.e., adding distortion.
Also available (implemented in the base class) are: inverse(distorted_point_in, undistorted_pt_out) inverse(undistort_this_pt)
Implements ossim2dTo2dTransform.
Definition at line 156 of file ossimRadialDecentLensDistortion.cpp.
References deltaR(), ossim::square(), theCalibratedPrincipalPoint, theDecentDistortionParameters, ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Reimplemented from ossim2dTo2dTransform.
Definition at line 84 of file ossimRadialDecentLensDistortion.h.
Definition at line 43 of file ossimRadialDecentLensDistortion.cpp.
References ossimString::c_str(), DECENT_DISTORTION_COEFF_KW, ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), PRINCIPAL_POINT_X_KW, PRINCIPAL_POINT_Y_KW, RADIAL_DISTORTION_COEFF_KW, theCalibratedPrincipalPoint, theDecentDistortionParameters, theRadialDistortionParameters, ossimString::toDouble(), ossimString::toString(), ossimDpt::x, and ossimDpt::y.
Dumps contents of object to ostream.
Definition at line 186 of file ossimRadialDecentLensDistortion.cpp.
References theCalibratedPrincipalPoint, theDecentDistortionParameters, and theRadialDistortionParameters.
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 97 of file ossimRadialDecentLensDistortion.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), DECENT_DISTORTION_COEFF_KW, PRINCIPAL_POINT_X_KW, PRINCIPAL_POINT_Y_KW, RADIAL_DISTORTION_COEFF_KW, ossim2dTo2dTransform::saveState(), theCalibratedPrincipalPoint, theDecentDistortionParameters, theRadialDistortionParameters, ossimString::toString(), ossimDpt::x, and ossimDpt::y.
inline |
Definition at line 153 of file ossimRadialDecentLensDistortion.h.
inline |
Set methods provide alternative initialization scheme to loadState:
Definition at line 141 of file ossimRadialDecentLensDistortion.h.
inline |
Definition at line 147 of file ossimRadialDecentLensDistortion.h.
static |
Definition at line 120 of file ossimRadialDecentLensDistortion.h.
Referenced by loadState(), and saveState().
static |
Definition at line 117 of file ossimRadialDecentLensDistortion.h.
static |
Definition at line 118 of file ossimRadialDecentLensDistortion.h.
static |
Definition at line 119 of file ossimRadialDecentLensDistortion.h.
protected |
Definition at line 130 of file ossimRadialDecentLensDistortion.h.
Referenced by forward(), loadState(), print(), and saveState().
protected |
Definition at line 132 of file ossimRadialDecentLensDistortion.h.
protected |
Definition at line 131 of file ossimRadialDecentLensDistortion.h.
Referenced by deltaR(), loadState(), print(), and saveState().
