#include <ossimPointCloudImageHandlerFactory.h>
| ossimPointCloudImageHandlerFactory () | |
| virtual | ~ossimPointCloudImageHandlerFactory () |
| virtual ossimImageHandler * | open (const ossimFilename &fileName, bool openOverview=true) const |
| virtual ossimImageHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getSupportedExtensions (ossimImageHandlerFactoryBase::UniqueStringList &extensionList) const |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (const ossimFilename &file) const |
| Open overview that takes a file name. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual void | getImageHandlersBySuffix (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &ext) const |
| virtual void | getImageHandlersByMimeType (ossimImageHandlerFactoryBase::ImageHandlerList &result, const ossimString &mimeType) const |
Public Member Functions inherited from ossimImageHandlerFactoryBase | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString, bool openOverview=true) const |
| Open method that takes a stream. More... | |
| virtual ossimRefPtr< ossimImageHandler > | open (std::shared_ptr< ossim::ImageHandlerState > state) const |
| virtual ossimRefPtr< ossimImageHandler > | openOverview (std::shared_ptr< ossim::istream > &str, const ossimString &connectionString) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimPointCloudImageHandlerFactory * | instance () |
Static Private Attributes | |
| static ossimPointCloudImageHandlerFactory * | m_instance = 0 |
Public Types inherited from ossimImageHandlerFactoryBase | |
| typedef UniqueList< ossimString > | UniqueStringList |
| typedef std::vector< ossimRefPtr< ossimImageHandler > > | ImageHandlerList |
Definition at line 13 of file ossimPointCloudImageHandlerFactory.h.
inline |
Definition at line 18 of file ossimPointCloudImageHandlerFactory.cpp.
References m_instance.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 84 of file ossimPointCloudImageHandlerFactory.cpp.
References STATIC_TYPE_NAME.
Creates and object given a keyword list.
Definition at line 123 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), STATIC_TYPE_NAME, and ossimKeywordNames::TYPE_KW.
Reimplemented from ossimImageHandlerFactoryBase.
Definition at line 109 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimString::begin(), ossimString::end(), and getImageHandlersBySuffix().
Definition at line 100 of file ossimPointCloudImageHandlerFactory.cpp.
Referenced by getImageHandlersByMimeType().
Implements ossimImageHandlerFactoryBase.
Definition at line 94 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimImageHandlerFactoryBase::UniqueList< T >::push_back().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 157 of file ossimPointCloudImageHandlerFactory.cpp.
static |
Definition at line 23 of file ossimPointCloudImageHandlerFactory.cpp.
References m_instance, and ossimPointCloudImageHandlerFactory().
Definition at line 33 of file ossimPointCloudImageHandlerFactory.cpp.
References ossimString::downcase(), ossimString::empty(), ossimFilename::exists(), ossimFilename::ext(), ossimFilename::setExtension(), and ossimString::trim().
Definition at line 62 of file ossimPointCloudImageHandlerFactory.cpp.
This default implementation returns a null ref pointer. Derived factories that have overview readers should override.
| file | File to open. |
Definition at line 77 of file ossimPointCloudImageHandlerFactory.cpp.
staticprivate |
Definition at line 42 of file ossimPointCloudImageHandlerFactory.h.
Referenced by instance(), and ~ossimPointCloudImageHandlerFactory().
