Factory for ossimOpenCvObject. More...
#include <ossimOpenCvObjectFactory.h>
| virtual | ~ossimOpenCvObjectFactory () |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| createObject that takes a class name (eg. More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates an object given a keyword list and prefix. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Adds ossimLasWriter to the typeList. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimOpenCvObjectFactory * | instance () |
| static method to return instance (the only one) of this class. More... | |
| ossimOpenCvObjectFactory () | |
| hidden from use default constructor More... | |
| ossimOpenCvObjectFactory (const ossimOpenCvObjectFactory &) | |
| hidden from use copy constructor More... | |
| const ossimOpenCvObjectFactory & | operator= (const ossimOpenCvObjectFactory &) |
Static Protected Attributes | |
| static ossimOpenCvObjectFactory * | theInstance = 0 |
| static instance of this class More... | |
Definition at line 22 of file ossimOpenCvObjectFactory.h.
virtual destructor
Definition at line 28 of file ossimOpenCvObjectFactory.cpp.
References theInstance.
protected |
Definition at line 79 of file ossimOpenCvObjectFactory.cpp.
Referenced by instance().
protected |
Definition at line 83 of file ossimOpenCvObjectFactory.cpp.
| typeName | (class, eg. "ossimTieMeasurementGenerator"). |
Implements ossimObjectFactory.
Definition at line 43 of file ossimOpenCvObjectFactory.cpp.
Referenced by createObject().
| kwl | The keyword list. |
| prefix | the keyword list prefix. |
Definition at line 56 of file ossimOpenCvObjectFactory.cpp.
References createObject(), ossimKeywordlist::find(), and ossimObject::loadState().
| typeList | List to add to. |
Definition at line 74 of file ossimOpenCvObjectFactory.cpp.
static |
Definition at line 33 of file ossimOpenCvObjectFactory.cpp.
References ossimOpenCvObjectFactory(), and theInstance.
Referenced by ossimSharedLibraryFinalize(), and ossimSharedLibraryInitialize().
protected |
Definition at line 87 of file ossimOpenCvObjectFactory.cpp.
staticprotected |
Definition at line 66 of file ossimOpenCvObjectFactory.h.
Referenced by instance(), and ~ossimOpenCvObjectFactory().
