#include <ossimNitfUnknownTag.h>
| ossimNitfUnknownTag () | |
| virtual | ~ossimNitfUnknownTag () |
| destructor More... | |
| virtual void | parseStream (std::istream &in) |
| Parse method. More... | |
| virtual void | writeStream (std::ostream &out) |
| Write method. More... | |
| virtual void | clearFields () |
| Clears all string fields within the record to some default nothingness. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual void | setTagLength (ossim_uint32 length) |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
| bool | tagDataIsAscii () const |
| bool | tagDataIsXml () const |
Protected Attributes | |
| char * | m_tagData |
| Holds entire tag data(theTagLength) plus one byte for null terminator. More... | |
Protected Attributes inherited from ossimNitfRegisteredTag | |
| std::string | m_tagName |
| ossim_uint32 | m_tagLength |
Definition at line 21 of file ossimNitfUnknownTag.h.
| ossimNitfUnknownTag::ossimNitfUnknownTag | ( | ) |
default constructor
Definition at line 26 of file ossimNitfUnknownTag.cpp.
destructor
Definition at line 31 of file ossimNitfUnknownTag.cpp.
References m_tagData.
Definition at line 65 of file ossimNitfUnknownTag.cpp.
Parse method.
| in | Stream to parse. This will read the entire tag length into an array. |
Definition at line 40 of file ossimNitfUnknownTag.cpp.
References m_tagData, and ossimNitfRegisteredTag::m_tagLength.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 74 of file ossimNitfUnknownTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), m_tagData, tagDataIsAscii(), and tagDataIsXml().
| length | Length of tag. |
Definition at line 115 of file ossimNitfUnknownTag.cpp.
protected |
Definition at line 125 of file ossimNitfUnknownTag.cpp.
Referenced by print().
protected |
Definition at line 101 of file ossimNitfUnknownTag.cpp.
References ossimString::length(), m_tagData, ossimNitfRegisteredTag::m_tagLength, and ossimString::substr().
Write method.
| out | Stream to write to. |
Definition at line 57 of file ossimNitfUnknownTag.cpp.
protected |
Definition at line 79 of file ossimNitfUnknownTag.h.
Referenced by clearFields(), parseStream(), print(), setTagLength(), tagDataIsAscii(), tagDataIsXml(), writeStream(), and ~ossimNitfUnknownTag().
