#include <ossimNitfStdidcTag.h>
Public Types | |
| enum | { ACQ_DATE_SIZE = 14, MISSION_SIZE = 14, PASS_SIZE = 2, OP_NUM_SIZE = 3, START_SEGMENT_SIZE = 2, REPRO_NUM_SIZE = 2, REPLAY_REGEN_SIZE = 3, BLANK_FILL_SIZE = 1, START_COLUMN_SIZE = 3, START_ROW_SIZE = 5, END_SEGMENT_SIZE = 2, END_COLUMN_SIZE = 3, END_ROW_SIZE = 5, COUNTRY_SIZE = 2, WAC_SIZE = 4, LOCATION_SIZE = 11, FIELD17_SIZE = 5, FIELD18_SIZE = 8 } |
| ossimNitfStdidcTag () | |
| virtual | ~ossimNitfStdidcTag () |
| virtual void | parseStream (std::istream &in) |
| virtual void | writeStream (std::ostream &out) |
| virtual void | clearFields () |
| void | setAcqDate (ossimString acqDate) |
| ossimString | getAcqDate () const |
| void | setMission (ossimString mission) |
| ossimString | getMission () const |
| void | setPass (ossimString pass) |
| ossimString | getPass () const |
| void | setOpNum (ossimString opNum) |
| ossimString | getOpNum () const |
| void | setStartSegment (ossimString startSegment) |
| ossimString | getStartSegment () const |
| void | setReproNum (ossimString reproNum) |
| ossimString | getReproNum () const |
| void | setReplayRegen (ossimString replayRegen) |
| ossimString | getReplayRegen () const |
| void | setBlankFill (ossimString blankFill) |
| ossimString | getBlankFill () const |
| void | setStartColumn (ossimString startColumn) |
| ossimString | getStartColumn () const |
| void | setStartRow (ossimString startRow) |
| ossimString | getStartRow () const |
| void | setEndSegment (ossimString endSegment) |
| ossimString | getEndSegment () const |
| void | setEndColumn (ossimString endColumn) |
| ossimString | getEndColumn () const |
| void | setEndRow (ossimString endRow) |
| ossimString | getEndRow () const |
| void | setCountry (ossimString country) |
| ossimString | getCountry () const |
| void | setWac (ossimString wac) |
| ossimString | getWac () const |
| void | setLocation (ossimString location) |
| ossimString | getLocation () const |
| void | setField17 (ossimString field17) |
| ossimString | getField17 () const |
| void | setField18 (ossimString field18) |
| ossimString | getField18 () const |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| destructor More... | |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Definition at line 19 of file ossimNitfStdidcTag.h.
| anonymous enum |
Definition at line 23 of file ossimNitfStdidcTag.h.
| ossimNitfStdidcTag::ossimNitfStdidcTag | ( | ) |
Definition at line 40 of file ossimNitfStdidcTag.cpp.
References clearFields().
Definition at line 46 of file ossimNitfStdidcTag.cpp.
Definition at line 96 of file ossimNitfStdidcTag.cpp.
References ACQ_DATE_SIZE, BLANK_FILL_SIZE, COUNTRY_SIZE, END_COLUMN_SIZE, END_ROW_SIZE, END_SEGMENT_SIZE, FIELD17_SIZE, FIELD18_SIZE, LOCATION_SIZE, MISSION_SIZE, OP_NUM_SIZE, PASS_SIZE, REPLAY_REGEN_SIZE, REPRO_NUM_SIZE, START_COLUMN_SIZE, START_ROW_SIZE, START_SEGMENT_SIZE, theAcqDate, theBlankFill, theCountry, theEndColumn, theEndRow, theEndSegment, theField17, theField18, theLocation, theMission, theOpNum, thePass, theReplayRegen, theReproNum, theStartColumn, theStartRow, theStartSegment, theWac, and WAC_SIZE.
Referenced by ossimNitfStdidcTag(), and parseStream().
| ossimString ossimNitfStdidcTag::getAcqDate | ( | ) | const |
Definition at line 137 of file ossimNitfStdidcTag.cpp.
References theAcqDate.
| ossimString ossimNitfStdidcTag::getBlankFill | ( | ) | const |
Definition at line 214 of file ossimNitfStdidcTag.cpp.
References theBlankFill.
| ossimString ossimNitfStdidcTag::getCountry | ( | ) | const |
Definition at line 280 of file ossimNitfStdidcTag.cpp.
References theCountry.
| ossimString ossimNitfStdidcTag::getEndColumn | ( | ) | const |
Definition at line 258 of file ossimNitfStdidcTag.cpp.
References theEndColumn.
| ossimString ossimNitfStdidcTag::getEndRow | ( | ) | const |
Definition at line 269 of file ossimNitfStdidcTag.cpp.
References theEndRow.
| ossimString ossimNitfStdidcTag::getEndSegment | ( | ) | const |
Definition at line 247 of file ossimNitfStdidcTag.cpp.
References theEndSegment.
| ossimString ossimNitfStdidcTag::getField17 | ( | ) | const |
Definition at line 313 of file ossimNitfStdidcTag.cpp.
References theField17.
| ossimString ossimNitfStdidcTag::getField18 | ( | ) | const |
Definition at line 324 of file ossimNitfStdidcTag.cpp.
References theField18.
| ossimString ossimNitfStdidcTag::getLocation | ( | ) | const |
Definition at line 302 of file ossimNitfStdidcTag.cpp.
References theLocation.
| ossimString ossimNitfStdidcTag::getMission | ( | ) | const |
Definition at line 148 of file ossimNitfStdidcTag.cpp.
References theMission.
| ossimString ossimNitfStdidcTag::getOpNum | ( | ) | const |
Definition at line 170 of file ossimNitfStdidcTag.cpp.
References theOpNum.
| ossimString ossimNitfStdidcTag::getPass | ( | ) | const |
Definition at line 159 of file ossimNitfStdidcTag.cpp.
References thePass.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 370 of file ossimNitfStdidcTag.cpp.
Definition at line 446 of file ossimNitfStdidcTag.cpp.
References ossimNitfRegisteredTag::getPropertyNames().
| ossimString ossimNitfStdidcTag::getReplayRegen | ( | ) | const |
Definition at line 203 of file ossimNitfStdidcTag.cpp.
References theReplayRegen.
| ossimString ossimNitfStdidcTag::getReproNum | ( | ) | const |
Definition at line 192 of file ossimNitfStdidcTag.cpp.
References theReproNum.
| ossimString ossimNitfStdidcTag::getStartColumn | ( | ) | const |
Definition at line 225 of file ossimNitfStdidcTag.cpp.
References theStartColumn.
Referenced by ossimImageGeometryFactory::createTransformFromNitf().
| ossimString ossimNitfStdidcTag::getStartRow | ( | ) | const |
Definition at line 236 of file ossimNitfStdidcTag.cpp.
References theStartRow.
| ossimString ossimNitfStdidcTag::getStartSegment | ( | ) | const |
Definition at line 181 of file ossimNitfStdidcTag.cpp.
References theStartSegment.
| ossimString ossimNitfStdidcTag::getWac | ( | ) | const |
Definition at line 291 of file ossimNitfStdidcTag.cpp.
References theWac.
Definition at line 50 of file ossimNitfStdidcTag.cpp.
References ACQ_DATE_SIZE, BLANK_FILL_SIZE, clearFields(), COUNTRY_SIZE, END_COLUMN_SIZE, END_ROW_SIZE, END_SEGMENT_SIZE, FIELD17_SIZE, FIELD18_SIZE, LOCATION_SIZE, MISSION_SIZE, OP_NUM_SIZE, PASS_SIZE, REPLAY_REGEN_SIZE, REPRO_NUM_SIZE, START_COLUMN_SIZE, START_ROW_SIZE, START_SEGMENT_SIZE, theAcqDate, theBlankFill, theCountry, theEndColumn, theEndRow, theEndSegment, theField17, theField18, theLocation, theMission, theOpNum, thePass, theReplayRegen, theReproNum, theStartColumn, theStartRow, theStartSegment, theWac, and WAC_SIZE.
| out | Stream to output to. |
| prefix | Prefix added to key like "image0."; |
Definition at line 335 of file ossimNitfStdidcTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theAcqDate, theCountry, theEndColumn, theEndRow, theEndSegment, theLocation, theMission, theOpNum, thePass, theReplayRegen, theReproNum, theStartColumn, theStartRow, theStartSegment, and theWac.
| void ossimNitfStdidcTag::setAcqDate | ( | ossimString | acqDate | ) |
Definition at line 142 of file ossimNitfStdidcTag.cpp.
References ACQ_DATE_SIZE, ossimString::c_str(), ossimString::length(), min, and theAcqDate.
| void ossimNitfStdidcTag::setBlankFill | ( | ossimString | blankFill | ) |
Definition at line 219 of file ossimNitfStdidcTag.cpp.
References BLANK_FILL_SIZE, ossimString::c_str(), ossimString::length(), min, and theBlankFill.
| void ossimNitfStdidcTag::setCountry | ( | ossimString | country | ) |
Definition at line 285 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), COUNTRY_SIZE, ossimString::length(), min, and theCountry.
| void ossimNitfStdidcTag::setEndColumn | ( | ossimString | endColumn | ) |
Definition at line 263 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), END_COLUMN_SIZE, ossimString::length(), min, and theEndColumn.
| void ossimNitfStdidcTag::setEndRow | ( | ossimString | endRow | ) |
Definition at line 274 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), END_ROW_SIZE, ossimString::length(), min, and theEndRow.
| void ossimNitfStdidcTag::setEndSegment | ( | ossimString | endSegment | ) |
Definition at line 252 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), END_SEGMENT_SIZE, ossimString::length(), min, and theEndSegment.
| void ossimNitfStdidcTag::setField17 | ( | ossimString | field17 | ) |
Definition at line 318 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), FIELD17_SIZE, ossimString::length(), min, and theField17.
| void ossimNitfStdidcTag::setField18 | ( | ossimString | field18 | ) |
Definition at line 329 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), FIELD18_SIZE, ossimString::length(), min, and theField18.
| void ossimNitfStdidcTag::setLocation | ( | ossimString | location | ) |
Definition at line 307 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), LOCATION_SIZE, min, and theLocation.
| void ossimNitfStdidcTag::setMission | ( | ossimString | mission | ) |
Definition at line 153 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, MISSION_SIZE, and theMission.
| void ossimNitfStdidcTag::setOpNum | ( | ossimString | opNum | ) |
Definition at line 175 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, OP_NUM_SIZE, and theOpNum.
| void ossimNitfStdidcTag::setPass | ( | ossimString | pass | ) |
Definition at line 164 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, PASS_SIZE, and thePass.
Definition at line 365 of file ossimNitfStdidcTag.cpp.
References ossimNitfRegisteredTag::setProperty().
| void ossimNitfStdidcTag::setReplayRegen | ( | ossimString | replayRegen | ) |
Definition at line 208 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, REPLAY_REGEN_SIZE, and theReplayRegen.
| void ossimNitfStdidcTag::setReproNum | ( | ossimString | reproNum | ) |
Definition at line 197 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, REPRO_NUM_SIZE, and theReproNum.
| void ossimNitfStdidcTag::setStartColumn | ( | ossimString | startColumn | ) |
Definition at line 230 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, START_COLUMN_SIZE, and theStartColumn.
| void ossimNitfStdidcTag::setStartRow | ( | ossimString | startRow | ) |
Definition at line 241 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, START_ROW_SIZE, and theStartRow.
| void ossimNitfStdidcTag::setStartSegment | ( | ossimString | startSegment | ) |
Definition at line 186 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, START_SEGMENT_SIZE, and theStartSegment.
| void ossimNitfStdidcTag::setWac | ( | ossimString | wac | ) |
Definition at line 296 of file ossimNitfStdidcTag.cpp.
References ossimString::c_str(), ossimString::length(), min, theWac, and WAC_SIZE.
Definition at line 74 of file ossimNitfStdidcTag.cpp.
protected |
FIELD: ACQDATE.
Definition at line 113 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getAcqDate(), parseStream(), print(), setAcqDate(), and writeStream().
protected |
FIELD: BLANKFILL.
Definition at line 148 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getBlankFill(), parseStream(), setBlankFill(), and writeStream().
protected |
FIELD: COUNTRY.
Definition at line 178 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getCountry(), parseStream(), print(), setCountry(), and writeStream().
protected |
FIELD: ENDCOLUMN.
Definition at line 168 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getEndColumn(), parseStream(), print(), setEndColumn(), and writeStream().
protected |
FIELD: ENDROW.
Definition at line 173 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getEndRow(), parseStream(), print(), setEndRow(), and writeStream().
protected |
FIELD: ENDSEGMENT.
Definition at line 163 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getEndSegment(), parseStream(), print(), setEndSegment(), and writeStream().
protected |
FIELD: FIELD17.
Definition at line 193 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getField17(), parseStream(), setField17(), and writeStream().
protected |
FIELD: FIELD18.
Definition at line 198 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getField18(), parseStream(), setField18(), and writeStream().
protected |
FIELD: LOCATION.
Definition at line 188 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getLocation(), parseStream(), print(), setLocation(), and writeStream().
protected |
FIELD: MISSION.
Definition at line 118 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getMission(), parseStream(), print(), setMission(), and writeStream().
protected |
FIELD: OPNUM.
Definition at line 128 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getOpNum(), parseStream(), print(), setOpNum(), and writeStream().
protected |
FIELD: PASS.
Definition at line 123 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getPass(), parseStream(), print(), setPass(), and writeStream().
protected |
FIELD: REPLAYREGEN.
Definition at line 143 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getReplayRegen(), parseStream(), print(), setReplayRegen(), and writeStream().
protected |
FIELD: REPRONUM.
Definition at line 138 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getReproNum(), parseStream(), print(), setReproNum(), and writeStream().
protected |
FIELD: STARTCOLUMN.
Definition at line 153 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getStartColumn(), parseStream(), print(), setStartColumn(), and writeStream().
protected |
FIELD: STARTROW.
Definition at line 158 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getStartRow(), parseStream(), print(), setStartRow(), and writeStream().
protected |
FIELD: STARTSEGMENT.
Definition at line 133 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getStartSegment(), parseStream(), print(), setStartSegment(), and writeStream().
protected |
FIELD: WAC.
Definition at line 183 of file ossimNitfStdidcTag.h.
Referenced by clearFields(), getWac(), parseStream(), print(), setWac(), and writeStream().
