The layout of RPC00B is the same as RPC00A. More...
#include <ossimNitfRpcBTag.h>
| ossimNitfRpcBTag () | |
Public Member Functions inherited from ossimNitfRpcBase | |
| ossimNitfRpcBase () | |
| virtual void | parseStream (std::istream &in) |
| Parse method. More... | |
| virtual void | writeStream (std::ostream &out) |
| Write method. More... | |
| virtual void | clearFields () |
| Clears all string fields within the record to some default nothingness. More... | |
| virtual void | setRpcModelParams (ossimRefPtr< ossimRpcModel > rpc) |
| For generating the RPC tag from existing RPC Model. More... | |
| bool | getSuccess () const |
| void | setSuccess (bool success) |
| ossimString | getErrorBias () const |
| void | setErrorBias (const ossim_float64 &errorBias) |
| void | setErrorBias (const ossimString &errorBias) |
| ossimString | getErrorRand () const |
| void | setErrorRand (const ossim_float64 &errorRand) |
| void | setErrorRand (const ossimString &errorRand) |
| ossimString | getLineOffset () const |
| void | setLineOffset (ossim_uint32 lineOffset) |
| void | setLineOffset (const ossimString &lineOffset) |
| ossimString | getSampleOffset () const |
| void | setSampleOffset (ossim_uint32 sampleOffset) |
| void | setSampleOffset (const ossimString &sampleOffset) |
| ossimString | getGeodeticLatOffset () const |
| void | setGeodeticLatOffset (const ossim_float64 &geodeticLatOffset) |
| void | setGeodeticLatOffset (const ossimString &geodeticLatOffset) |
| ossimString | getGeodeticLonOffset () const |
| void | setGeodeticLonOffset (const ossim_float64 &geodeticLonOffset) |
| void | setGeodeticLonOffset (const ossimString &geodeticLonOffset) |
| ossimString | getGeodeticHeightOffset () const |
| void | setGeodeticHeightOffset (ossim_int32 geodeticHeightOffset) |
| void | setGeodeticHeightOffset (const ossimString &geodeticHeightOffset) |
| ossimString | getLineScale () const |
| void | setLineScale (ossim_uint32 lineScale) |
| void | setLineScale (const ossimString &lineScale) |
| ossimString | getSampleScale () const |
| void | setSampleScale (ossim_uint32 sampleScale) |
| void | setSampleScale (const ossimString &sampleScale) |
| ossimString | getGeodeticLatScale () const |
| void | setGeodeticLatScale (const ossim_float64 &geodeticLatScale) |
| void | setGeodeticLatScale (const ossimString &geodeticLatScale) |
| ossimString | getGeodeticLonScale () const |
| void | setGeodeticLonScale (const ossim_float64 &geodeticLonScale) |
| void | setGeodeticLonScale (const ossimString &geodeticLonScale) |
| ossimString | getGeodeticHeightScale () const |
| void | setGeodeticHeightScale (ossim_int32 geodeticHeightScale) |
| void | setGeodeticHeightScale (const ossimString &geodeticHeightScale) |
| ossimString | getLineNumeratorCoeff (ossim_uint32 idx) const |
| void | setLineNumeratorCoeff (const std::vector< ossim_float64 > &coeff) |
| void | setLineNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff) |
| ossimString | getLineDenominatorCoeff (ossim_uint32 idx) const |
| void | setLineDenominatorCoeff (const std::vector< ossim_float64 > &coeff) |
| void | setLineDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff) |
| ossimString | getSampleNumeratorCoeff (ossim_uint32 idx) const |
| void | setSampleNumeratorCoeff (const std::vector< ossim_float64 > &coeff) |
| void | setSampleNumeratorCoeff (ossim_uint32 idx, const ossimString &coeff) |
| ossimString | getSampleDenominatorCoeff (ossim_uint32 idx) const |
| void | setSampleDenominatorCoeff (const std::vector< ossim_float64 > &coeff) |
| void | setSampleDenominatorCoeff (ossim_uint32 idx, const ossimString &coeff) |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
| bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| destructor More... | |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
The difference is how the coefficients are used; hence, all the code is in the ossimNitfRpcBase class.
Definition at line 22 of file ossimNitfRpcBTag.h.
| ossimNitfRpcBTag::ossimNitfRpcBTag | ( | ) |
Definition at line 17 of file ossimNitfRpcBTag.cpp.
References ossimNitfRegisteredTag::setTagName().
