#include <ossimNitfMstgtaTag.h>
Public Types | |
| enum | { TGT_NUM_SIZE = 5, TGT_ID_SIZE = 12, TGT_BE_SIZE = 15, TGT_PRI_SIZE = 3, TGT_REQ_SIZE = 12, TGT_LTIOV_SIZE = 12, TGT_TYPE_SIZE = 1, TGT_COLL_SIZE = 1, TGT_CAT_SIZE = 5, TGT_UTC_SIZE = 7, TGT_ELEV_SIZE = 6, TGT_ELEV_UNIT_SIZE = 1, TGT_LOC_SIZE = 21 } |
| ossimNitfMstgtaTag () | |
| virtual | ~ossimNitfMstgtaTag () |
| destructor More... | |
| virtual void | parseStream (std::istream &in) |
| Method to parse data from stream. More... | |
| virtual void | writeStream (std::ostream &out) |
| Method to write data to stream. More... | |
| virtual void | clearFields () |
| Method to clear all fields including null terminating. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Protected Attributes | |
| char | theTgtNum [TGT_NUM_SIZE+1] |
| Type R = Required Type <R> = BCS spaces allowed for entire field. More... | |
| char | theTgtId [TGT_ID_SIZE+1] |
| FIELD: TGT_ID. More... | |
| char | theTgtBe [TGT_BE_SIZE+1] |
| FIELD: TGT_BE. More... | |
| char | theTgtPri [TGT_PRI_SIZE+1] |
| FIELD: TGT_PRI. More... | |
| char | theTgtReq [TGT_REQ_SIZE+1] |
| FIELD: TGT_REQ. More... | |
| char | theTgtLtiov [TGT_LTIOV_SIZE+1] |
| FIELD: TGT_LTIOV. More... | |
| char | theTgtType [TGT_TYPE_SIZE+1] |
| FIELD: TGT_TYPE. More... | |
| char | theTgtColl [TGT_COLL_SIZE+1] |
| FIELD: TGT_COLL. More... | |
| char | theTgtCat [TGT_CAT_SIZE+1] |
| FIELD: TGT_CAT. More... | |
| char | theTgtUtc [TGT_UTC_SIZE+1] |
| FIELD: TGT_UTC. More... | |
| char | theTgtElev [TGT_ELEV_SIZE+1] |
| FIELD: TGT_ELEV. More... | |
| char | theTgtElevUnit [TGT_ELEV_UNIT_SIZE+1] |
| FIELD: TGT_ELEV_UNIT. More... | |
| char | theTgtLoc [TGT_LOC_SIZE+1] |
| FIELD: TGT_LOC. More... | |
Protected Attributes inherited from ossimNitfRegisteredTag | |
| std::string | m_tagName |
| ossim_uint32 | m_tagLength |
Definition at line 22 of file ossimNitfMstgtaTag.h.
| anonymous enum |
| Enumerator | |
| TGT_NUM_SIZE | |
| TGT_ID_SIZE | |
| TGT_BE_SIZE | |
| TGT_PRI_SIZE | |
| TGT_REQ_SIZE | |
| TGT_LTIOV_SIZE | |
| TGT_TYPE_SIZE | |
| TGT_COLL_SIZE | |
| TGT_CAT_SIZE | |
| TGT_UTC_SIZE | |
| TGT_ELEV_SIZE | |
| TGT_ELEV_UNIT_SIZE | |
| TGT_LOC_SIZE | |
Definition at line 26 of file ossimNitfMstgtaTag.h.
| ossimNitfMstgtaTag::ossimNitfMstgtaTag | ( | ) |
default constructor
Definition at line 27 of file ossimNitfMstgtaTag.cpp.
References clearFields().
Definition at line 73 of file ossimNitfMstgtaTag.cpp.
References TGT_BE_SIZE, TGT_CAT_SIZE, TGT_COLL_SIZE, TGT_ELEV_SIZE, TGT_ELEV_UNIT_SIZE, TGT_ID_SIZE, TGT_LOC_SIZE, TGT_LTIOV_SIZE, TGT_NUM_SIZE, TGT_PRI_SIZE, TGT_REQ_SIZE, TGT_TYPE_SIZE, TGT_UTC_SIZE, theTgtBe, theTgtCat, theTgtColl, theTgtElev, theTgtElevUnit, theTgtId, theTgtLoc, theTgtLtiov, theTgtNum, theTgtPri, theTgtReq, theTgtType, and theTgtUtc.
Referenced by ossimNitfMstgtaTag(), and parseStream().
Definition at line 37 of file ossimNitfMstgtaTag.cpp.
References clearFields(), TGT_BE_SIZE, TGT_CAT_SIZE, TGT_COLL_SIZE, TGT_ELEV_SIZE, TGT_ELEV_UNIT_SIZE, TGT_ID_SIZE, TGT_LOC_SIZE, TGT_LTIOV_SIZE, TGT_NUM_SIZE, TGT_PRI_SIZE, TGT_REQ_SIZE, TGT_TYPE_SIZE, TGT_UTC_SIZE, theTgtBe, theTgtCat, theTgtColl, theTgtElev, theTgtElevUnit, theTgtId, theTgtLoc, theTgtLtiov, theTgtNum, theTgtPri, theTgtReq, theTgtType, and theTgtUtc.
| out | Stream to output to. |
| prefix | Prefix added to key like "image0."; |
Reimplemented from ossimNitfRegisteredTag.
Definition at line 108 of file ossimNitfMstgtaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theTgtBe, theTgtCat, theTgtColl, theTgtElev, theTgtElevUnit, theTgtId, theTgtLoc, theTgtLtiov, theTgtNum, theTgtPri, theTgtReq, theTgtType, and theTgtUtc.
Definition at line 56 of file ossimNitfMstgtaTag.cpp.
protected |
FIELD: TGT_BE.
TYPE: <R>
15 byte field
alphnumeric
Definition at line 102 of file ossimNitfMstgtaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
FIELD: TGT_CAT.
TYPE: <R>
5 byte field
Target Functional Category Code 10000 to 99999
Definition at line 168 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_COLL.
TYPE: R
1 byte field
Pre-Planned Collection Technique: 0 to 9
Definition at line 157 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_ELEV.
TYPE: <R>
6 byte field
Target Elevation -01000 to +30000 feet or meters
Definition at line 190 of file ossimNitfMstgtaTag.h.
protected |
TYPE: <R>
1 byte field
Unit of Target Elevation, f = feet, m = meters
Definition at line 201 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_ID.
TYPE: <R>
12 byte field
Disignator of Target, alphnumeric.
Definition at line 91 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_LOC.
TYPE: R
21 byte field
Target Location
Definition at line 212 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_LTIOV.
TYPE: <R>
12 byte field
Latest Time Information of Value CCYYMMDDhhmm
Definition at line 135 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_NUM
TYPE: R
5 byte field
00001 ti 99999
Definition at line 80 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_PRI.
TYPE: <R>
3 byte field
Target priority, 1 = top, 2 = 2nd... 001 to 999
Definition at line 113 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_REQ.
TYPE: <R>
12 byte field
Target requester. alphnumeric
Definition at line 124 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_TYPE.
TYPE: <R>
1 byte field
Pre-Planned Target Type: 0 = point, 1 = strip, 2 = area, 0 to 9.
Definition at line 146 of file ossimNitfMstgtaTag.h.
protected |
FIELD: TGT_UTC.
TYPE: <R>
7 byte field
Planned Time at Target hhmmssZ
Definition at line 179 of file ossimNitfMstgtaTag.h.
