Container class for an Engineering Data Element Record. More...
#include <ossimNitfEngrdaTag.h>
Public Attributes | |
| char | m_engLn [ENGLN_SIZE+1] |
| FIELD: ENGLN. More... | |
| std::string | m_engLbl |
| FIELD: ENGLBL. More... | |
| char | m_engMtxC [ENGMTXC_SIZE+1] |
| FIELD: ENGMTXC. More... | |
| char | m_engMtxR [ENGMTXR_SIZE+1] |
| FIELD: ENGMTXR. More... | |
| char | m_engTyp |
| FIELD: ENGTYP. More... | |
| char | m_engDts |
| FIELD: ENGDTS. More... | |
| char | m_engDatU [ENGDATU_SIZE+1] |
| FIELD: ENGDATU. More... | |
| char | m_engDatC [ENGDATC_SIZE+1] |
| FIELD: ENGDATC. More... | |
| std::vector< ossim_uint8 > | m_engDat |
| ENGDATA - data. More... | |
Definition at line 69 of file ossimNitfEngrdaTag.h.
| std::vector<ossim_uint8> ossimNitfEngrdaTag::ossimEngDataElement::m_engDat |
ENGDATA - data.
Definition at line 160 of file ossimNitfEngrdaTag.h.
Referenced by ossimNitfEngrdaTag::parseStream(), and ossimNitfEngrdaTag::printData().
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engDatC[ENGDATC_SIZE+1] |
FIELD: ENGDATC.
TYPE: BCS-N
8 byte field
Engineering Data Count
Definition at line 157 of file ossimNitfEngrdaTag.h.
Referenced by ossimNitfEngrdaTag::parseStream().
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engDatU[ENGDATU_SIZE+1] |
FIELD: ENGDATU.
TYPE: BCS-A
2 byte field
Engineering Data Units
Definition at line 146 of file ossimNitfEngrdaTag.h.
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engDts |
FIELD: ENGDTS.
TYPE: BCS-N
1 byte field
Engineering Data Element Size
Definition at line 135 of file ossimNitfEngrdaTag.h.
| std::string ossimNitfEngrdaTag::ossimEngDataElement::m_engLbl |
FIELD: ENGLBL.
TYPE: BCS-A
Engineering Label - variable length
Definition at line 91 of file ossimNitfEngrdaTag.h.
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engLn[ENGLN_SIZE+1] |
FIELD: ENGLN.
TYPE: BCS-N
2 byte field
Engineering Data Label Length 01 - 99
Definition at line 82 of file ossimNitfEngrdaTag.h.
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engMtxC[ENGMTXC_SIZE+1] |
FIELD: ENGMTXC.
TYPE: BCS-N
4 byte field
Engineering Matrix Data Column Count 0001 - 9999
Definition at line 102 of file ossimNitfEngrdaTag.h.
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engMtxR[ENGMTXR_SIZE+1] |
FIELD: ENGMTXR.
TYPE: BCS-N
4 byte field
Engineering Matrix Data Row Count 0001 - 9999
Definition at line 113 of file ossimNitfEngrdaTag.h.
| char ossimNitfEngrdaTag::ossimEngDataElement::m_engTyp |
FIELD: ENGTYP.
TYPE: BCS
1 byte field
Value Type of Engineering Data Element
Definition at line 124 of file ossimNitfEngrdaTag.h.
