| | ossimNitfEmbeddedRpfDes () |
| virtual void | parseStream (std::istream &in) |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| | Print method that outputs a key/value type format adding prefix to keys. More...
| | ossimNitfRegisteredTag () |
| | default constructor More...
| | ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) |
| | Constructor that takes name and size. More...
| virtual | ~ossimNitfRegisteredTag () |
| | destructor More...
| virtual std::string | getRegisterTagName () const |
| | This will return the name of the registered tag for this user defined header. More...
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| | Returns the length in bytes of the tag from the CEL or REL field. More...
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| | Set the tag length. More...
| virtual void | parseStream (ossim::istream &in)=0 |
| | This will allow the user defined data to parse the stream. More...
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| | Default interface to populate keyword list with metadata. More...
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| | ossimObject () |
| | Generic print method. More...
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimPropertyInterface () |
Definition at line 20 of file ossimNitfEmbeddedRpfDes.h.
