#include <ossimNitfCsproaTag.h>
Public Types | |
| enum | { RESERVE1_SIZE = 12, RESERVE2_SIZE = 12, RESERVE3_SIZE = 12, RESERVE4_SIZE = 12, RESERVE5_SIZE = 12, RESERVE6_SIZE = 12, RESERVE7_SIZE = 12, RESERVE8_SIZE = 12, RESERVE9_SIZE = 12, BWC_SIZE = 12 } |
| ossimNitfCsproaTag () | |
| virtual void | parseStream (std::istream &in) |
| virtual void | writeStream (std::ostream &out) |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Pure virtual print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual void | clearFields () |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| destructor More... | |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Protected Attributes | |
| char | m_reserved1 [RESERVE1_SIZE+1] |
| char | m_reserved2 [RESERVE1_SIZE+1] |
| char | m_reserved3 [RESERVE1_SIZE+1] |
| char | m_reserved4 [RESERVE1_SIZE+1] |
| char | m_reserved5 [RESERVE1_SIZE+1] |
| char | m_reserved6 [RESERVE1_SIZE+1] |
| char | m_reserved7 [RESERVE1_SIZE+1] |
| char | m_reserved8 [RESERVE1_SIZE+1] |
| char | m_reserved9 [RESERVE1_SIZE+1] |
| char | m_bwc [BWC_SIZE+1] |
Protected Attributes inherited from ossimNitfRegisteredTag | |
| std::string | m_tagName |
| ossim_uint32 | m_tagLength |
Definition at line 13 of file ossimNitfCsproaTag.h.
| anonymous enum |
| Enumerator | |
| RESERVE1_SIZE | |
| RESERVE2_SIZE | |
| RESERVE3_SIZE | |
| RESERVE4_SIZE | |
| RESERVE5_SIZE | |
| RESERVE6_SIZE | |
| RESERVE7_SIZE | |
| RESERVE8_SIZE | |
| RESERVE9_SIZE | |
| BWC_SIZE | |
Definition at line 16 of file ossimNitfCsproaTag.h.
| ossimNitfCsproaTag::ossimNitfCsproaTag | ( | ) |
Definition at line 5 of file ossimNitfCsproaTag.cpp.
References clearFields().
Definition at line 62 of file ossimNitfCsproaTag.cpp.
References BWC_SIZE, m_bwc, m_reserved1, m_reserved2, m_reserved3, m_reserved4, m_reserved5, m_reserved6, m_reserved7, m_reserved8, m_reserved9, RESERVE1_SIZE, RESERVE2_SIZE, RESERVE3_SIZE, RESERVE4_SIZE, RESERVE5_SIZE, RESERVE6_SIZE, RESERVE7_SIZE, RESERVE8_SIZE, and RESERVE9_SIZE.
Referenced by ossimNitfCsproaTag().
Definition at line 11 of file ossimNitfCsproaTag.cpp.
Reimplemented from ossimNitfRegisteredTag.
Definition at line 39 of file ossimNitfCsproaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), m_bwc, m_reserved1, m_reserved2, m_reserved3, m_reserved4, m_reserved5, m_reserved6, m_reserved7, m_reserved8, and m_reserved9.
Definition at line 25 of file ossimNitfCsproaTag.cpp.
protected |
Definition at line 48 of file ossimNitfCsproaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
Definition at line 39 of file ossimNitfCsproaTag.h.
protected |
Definition at line 40 of file ossimNitfCsproaTag.h.
protected |
Definition at line 41 of file ossimNitfCsproaTag.h.
protected |
Definition at line 42 of file ossimNitfCsproaTag.h.
protected |
Definition at line 43 of file ossimNitfCsproaTag.h.
protected |
Definition at line 44 of file ossimNitfCsproaTag.h.
protected |
Definition at line 45 of file ossimNitfCsproaTag.h.
protected |
Definition at line 46 of file ossimNitfCsproaTag.h.
protected |
Definition at line 47 of file ossimNitfCsproaTag.h.
