#include <ossimNitfCsdidaTag.h>
| ossimNitfCsdidaTag () | |
| virtual | ~ossimNitfCsdidaTag () |
| destructor More... | |
| virtual void | parseStream (std::istream &in) |
| Method to parse data from stream. More... | |
| virtual void | writeStream (std::ostream &out) |
| Method to write data to stream. More... | |
| virtual void | clearFields () |
| Method to clear all fields including null terminating. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Protected Attributes | |
| char | theDay [3] |
| FIELD: DAY. More... | |
| char | theMonth [4] |
| FIELD: MONTH. More... | |
| char | theYear [5] |
| FIELD: YEAR. More... | |
| char | thePlatformCode [3] |
| FIELD: PLATFORM CODE. More... | |
| char | theVehicleId [3] |
| FIELD: VEHICLE ID. More... | |
| char | thePass [3] |
| FIELD: PASS. More... | |
| char | theOperation [4] |
| FIELD: OPERATION. More... | |
| char | theSensorId [3] |
| FIELD: SENSOR_ID. More... | |
| char | theProductId [3] |
| FIELD: PRODUCT_ID. More... | |
| char | theReservedField1 [5] |
| FIELD: Reserved. More... | |
| char | theTime [15] |
| FIELD: TIME. More... | |
| char | theProcessTime [15] |
| FIELD: PROCESS_TIME. More... | |
| char | theReservedField2 [3] |
| char | theReservedField3 [3] |
| char | theReservedField4 [1] |
| char | theReservedField5 [1] |
| char | theSoftwareVersionNumber [11] |
| FIELD: SOFTWARE_VERSION_NUMBER. More... | |
Protected Attributes inherited from ossimNitfRegisteredTag | |
| std::string | m_tagName |
| ossim_uint32 | m_tagLength |
Definition at line 22 of file ossimNitfCsdidaTag.h.
| ossimNitfCsdidaTag::ossimNitfCsdidaTag | ( | ) |
default constructor
Definition at line 28 of file ossimNitfCsdidaTag.cpp.
References clearFields().
Definition at line 82 of file ossimNitfCsdidaTag.cpp.
References theDay, theMonth, theOperation, thePass, thePlatformCode, theProcessTime, theProductId, theReservedField1, theReservedField2, theReservedField3, theReservedField4, theReservedField5, theSensorId, theSoftwareVersionNumber, theTime, theVehicleId, and theYear.
Referenced by ossimNitfCsdidaTag(), and parseStream().
Definition at line 38 of file ossimNitfCsdidaTag.cpp.
References clearFields(), theDay, theMonth, theOperation, thePass, thePlatformCode, theProcessTime, theProductId, theReservedField1, theReservedField2, theReservedField3, theReservedField4, theReservedField5, theSensorId, theSoftwareVersionNumber, theTime, theVehicleId, and theYear.
| out | Stream to output to. |
| prefix | Prefix added to key like "image0."; |
Reimplemented from ossimNitfRegisteredTag.
Definition at line 123 of file ossimNitfCsdidaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theDay, theMonth, theOperation, thePass, thePlatformCode, theProcessTime, theProductId, theSensorId, theSoftwareVersionNumber, theTime, theVehicleId, and theYear.
Definition at line 61 of file ossimNitfCsdidaTag.cpp.
protected |
FIELD: DAY.
2 byte field BCS-N
01 TO 31 (UTC)
Definition at line 58 of file ossimNitfCsdidaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
FIELD: MONTH.
3 byte field BCS-A
JAN to DEC (UTC)
Definition at line 67 of file ossimNitfCsdidaTag.h.
protected |
FIELD: OPERATION.
3 byte field BCS-N
001 to 999
Definition at line 113 of file ossimNitfCsdidaTag.h.
protected |
FIELD: PASS.
2 byte field BCS-N
01 to 99
Definition at line 104 of file ossimNitfCsdidaTag.h.
protected |
2 byte field BCS-A
QB, IK, OV, WV ...
Definition at line 86 of file ossimNitfCsdidaTag.h.
protected |
14 byte field BCS-N
Image start time (UTC) YYYYMMDDhhmmss
Definition at line 160 of file ossimNitfCsdidaTag.h.
protected |
FIELD: PRODUCT_ID.
2 byte field BCS-A
See table 2.1-7
Definition at line 132 of file ossimNitfCsdidaTag.h.
protected |
FIELD: Reserved.
4 bytes BCS-A
fill "00 "
Definition at line 141 of file ossimNitfCsdidaTag.h.
Referenced by clearFields(), parseStream(), and writeStream().
protected |
FIELD: Reserved.
2 bytes BCS-N
Fill "00"
Definition at line 168 of file ossimNitfCsdidaTag.h.
protected |
FIELD: Reserved.
2 bytes BCS-N
Fill "01"
Definition at line 177 of file ossimNitfCsdidaTag.h.
protected |
FIELD: Reserved.
1 byte BCS-A
Fill "N"
Definition at line 186 of file ossimNitfCsdidaTag.h.
protected |
FIELD: Reserved.
1 byte BCS-A
BCS-A "N"
Definition at line 195 of file ossimNitfCsdidaTag.h.
protected |
FIELD: SENSOR_ID.
2 byte field BCS-A
AA = pan only, GA = multispectral and pan sharpened only, NA = panchroomatic & multispectral together.
Definition at line 123 of file ossimNitfCsdidaTag.h.
protected |
10 byte field BCS-A
Software version used.
Definition at line 204 of file ossimNitfCsdidaTag.h.
protected |
FIELD: TIME.
14 byte field BCS-N
Image start time (UTC) YYYYMMDDhhmmss Corresponds to ACQUISITION_DATE in STDI-0002
Definition at line 151 of file ossimNitfCsdidaTag.h.
protected |
FIELD: VEHICLE ID.
2 byte field BCS-N
00 TO 99
Definition at line 95 of file ossimNitfCsdidaTag.h.
protected |
FIELD: YEAR.
4 byte field BCS-N
0000 to 9999 (UTC)
Definition at line 77 of file ossimNitfCsdidaTag.h.
