#include <ossimNitfCscrnaTag.h>
| ossimNitfCscrnaTag () | |
| virtual | ~ossimNitfCscrnaTag () |
| destructor More... | |
| virtual void | parseStream (std::istream &in) |
| Method to parse data from stream. More... | |
| virtual void | writeStream (std::ostream &out) |
| Method to write data to stream. More... | |
| virtual void | clearFields () |
| Method to clear all fields including null terminating. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
Public Member Functions inherited from ossimNitfRegisteredTag | |
| ossimNitfRegisteredTag () | |
| ossimNitfRegisteredTag (const std::string &tagName, ossim_uint32 tagLength) | |
| Constructor that takes name and size. More... | |
| virtual | ~ossimNitfRegisteredTag () |
| virtual std::string | getRegisterTagName () const |
| This will return the name of the registered tag for this user defined header. More... | |
| virtual const std::string & | getTagName () const |
| virtual void | setTagName (const std::string &tagName) |
| virtual ossim_uint32 | getSizeInBytes () const |
| Returns the length in bytes of the tag from the CEL or REL field. More... | |
| virtual ossim_uint32 | getTagLength () const |
| virtual void | setTagLength (ossim_uint32 length) |
| Set the tag length. More... | |
| virtual void | parseStream (ossim::istream &in)=0 |
| This will allow the user defined data to parse the stream. More... | |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Default interface to populate keyword list with metadata. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix) const |
| ossimObject () | |
Protected Attributes | |
| char | thePredictedCornerFlag [2] |
| FIELD: PREDICT_CORNERS. More... | |
| char | theUlLat [10] |
| FIELD: ULCRN_LAT. More... | |
| char | theUlLon [11] |
| FIELD: ULCRN_LON. More... | |
| char | theUlHt [9] |
| FIELD: ULCRN_HT. More... | |
| char | theUrLat [10] |
| FIELD: URCRN_LAT. More... | |
| char | theUrLon [11] |
| FIELD: URCRN_LON. More... | |
| char | theUrHt [9] |
| FIELD: URCRN_HT. More... | |
| char | theLrLat [10] |
| FIELD: LRCRN_LAT. More... | |
| char | theLrLon [11] |
| FIELD: LRCRN_LON. More... | |
| char | theLrHt [9] |
| FIELD: LRCRN_HT. More... | |
| char | theLlLat [10] |
| FIELD: LLCRN_LAT. More... | |
| char | theLlLon [11] |
| FIELD: LLCRN_LON. More... | |
| char | theLlHt [9] |
| FIELD: LLCRN_HT. More... | |
Protected Attributes inherited from ossimNitfRegisteredTag | |
| std::string | m_tagName |
| ossim_uint32 | m_tagLength |
Definition at line 22 of file ossimNitfCscrnaTag.h.
| ossimNitfCscrnaTag::ossimNitfCscrnaTag | ( | ) |
default constructor
Definition at line 28 of file ossimNitfCscrnaTag.cpp.
References clearFields().
Definition at line 82 of file ossimNitfCscrnaTag.cpp.
References theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
Referenced by ossimNitfCscrnaTag(), and parseStream().
Definition at line 38 of file ossimNitfCscrnaTag.cpp.
References clearFields(), theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
| out | Stream to output to. |
| prefix | Prefix added to key like "image0."; |
Reimplemented from ossimNitfRegisteredTag.
Definition at line 122 of file ossimNitfCscrnaTag.cpp.
References ossimNitfRegisteredTag::getTagLength(), ossimNitfRegisteredTag::getTagName(), theLlHt, theLlLat, theLlLon, theLrHt, theLrLat, theLrLon, thePredictedCornerFlag, theUlHt, theUlLat, theUlLon, theUrHt, theUrLat, and theUrLon.
Definition at line 61 of file ossimNitfCscrnaTag.cpp.
protected |
FIELD: LLCRN_HT.
8 byte field BCS-N Meters
Height referenced to the reference ellipsoid.
-00610.0 to +10668.0
Definition at line 179 of file ossimNitfCscrnaTag.h.
Referenced by clearFields(), parseStream(), print(), and writeStream().
protected |
FIELD: LLCRN_LAT.
9 byte field BCS-N Degrees
-90.000000 ti +90.000000
Definition at line 159 of file ossimNitfCscrnaTag.h.
protected |
FIELD: LLCRN_LON.
10 byte field BCS-N Degrees
-179.999999 ti +180.000000
Definition at line 168 of file ossimNitfCscrnaTag.h.
protected |
FIELD: LRCRN_HT.
Definition at line 150 of file ossimNitfCscrnaTag.h.
protected |
FIELD: LRCRN_LAT.
Definition at line 130 of file ossimNitfCscrnaTag.h.
protected |
FIELD: LRCRN_LON.
Definition at line 139 of file ossimNitfCscrnaTag.h.
protected |
1 byte field BCS-A
Y = predicted, N = actual
Definition at line 63 of file ossimNitfCscrnaTag.h.
protected |
FIELD: ULCRN_HT.
Definition at line 92 of file ossimNitfCscrnaTag.h.
protected |
FIELD: ULCRN_LAT.
Definition at line 72 of file ossimNitfCscrnaTag.h.
protected |
FIELD: ULCRN_LON.
Definition at line 81 of file ossimNitfCscrnaTag.h.
protected |
FIELD: URCRN_HT.
Definition at line 121 of file ossimNitfCscrnaTag.h.
protected |
FIELD: URCRN_LAT.
Definition at line 101 of file ossimNitfCscrnaTag.h.
protected |
FIELD: URCRN_LON.
Definition at line 110 of file ossimNitfCscrnaTag.h.
