#include <ossimKakaduJ2kCodec.h>
| ossimKakaduJ2kCodec () | |
| virtual ossimString | getCodecType () const |
| Will return the identifier used to identify the codec type. More... | |
| virtual bool | encode (const ossimRefPtr< ossimImageData > &in, std::vector< ossim_uint8 > &out) const |
| Encode method. More... | |
| virtual bool | decode (const std::vector< ossim_uint8 > &in, ossimRefPtr< ossimImageData > &out) const |
| Decode method. More... | |
| virtual const std::string & | getExtension () const |
| ossimObject () | |
Protected Attributes | |
| std::string | m_extension |
| ossimString | m_codecType |
Definition at line 5 of file ossimKakaduJ2kCodec.h.
| ossimKakaduJ2kCodec::ossimKakaduJ2kCodec | ( | ) |
Definition at line 3 of file ossimKakaduJ2kCodec.cpp.
Decode method.
| in | Input data to decode. |
| out | Output tile. If the pointer to ossimImageData is null internally it will be created. For code loops it is better to pre initialized to correct size. |
Implements ossimCodecBase.
Definition at line 23 of file ossimKakaduJ2kCodec.cpp.
Encode method.
| in | Input data to encode. |
| out | Encoded output data. |
Definition at line 15 of file ossimKakaduJ2kCodec.cpp.
For example the Jpeg codec will have "jpeg" as the identifier
Definition at line 10 of file ossimKakaduJ2kCodec.cpp.
References m_codecType.
Definition at line 31 of file ossimKakaduJ2kCodec.cpp.
References m_extension.
Definition at line 36 of file ossimKakaduJ2kCodec.cpp.
protected |
Definition at line 54 of file ossimKakaduJ2kCodec.h.
Referenced by getCodecType().
protected |
Definition at line 53 of file ossimKakaduJ2kCodec.h.
Referenced by getExtension().
