Codec factory. More...
#include <ossimKakaduCodecFactory.h>
| virtual | ~ossimKakaduCodecFactory () |
| virtual ossimCodecBase * | createCodec (const ossimString &type) const |
| createCodec takes a type and will return a new codec to encode decode image buffers More... | |
| virtual ossimCodecBase * | createCodec (const ossimKeywordlist &kwl, const char *prefix=0) const |
| createCodec takes a type in the keywordlist and will return a new codec to encode decode image buffers More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeNames) const |
Public Member Functions inherited from ossimCodecFactoryInterface | |
| ossimCodecFactoryInterface () | |
| virtual | ~ossimCodecFactoryInterface () |
| virtual ossimObject * | createObject (const ossimString &type) const |
| This is a bridge to the generic factory list interface that trys to call createObject. More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| static ossimKakaduCodecFactory * | instance () |
Private Member Functions | |
| ossimKakaduCodecFactory () | |
| hidden from use default constructor More... | |
| ossimKakaduCodecFactory (const ossimKakaduCodecFactory &obj) | |
| hidden from use copy constructor More... | |
| const ossimKakaduCodecFactory & | operator= (const ossimKakaduCodecFactory &rhs) |
| hidden from use operator = More... | |
Static Private Attributes | |
| static ossimKakaduCodecFactory * | theInstance = 0 |
| The single instance of this class. More... | |
Codec factory.
Definition at line 25 of file ossimKakaduCodecFactory.h.
private |
Definition at line 72 of file ossimKakaduCodecFactory.cpp.
Referenced by instance().
private |
| in | type. Type identifer used to allocate the proper codec. |
Implements ossimCodecFactoryInterface.
Definition at line 39 of file ossimKakaduCodecFactory.cpp.
References ossimString::downcase(), and ossimRefPtr< T >::release().
Referenced by createCodec().
| in | kwl. Type identifer used to allocate the proper codec. |
| in | prefix. prefix used to prefix keywords during the construction of the codec |
Definition at line 51 of file ossimKakaduCodecFactory.cpp.
References createCodec(), ossimString::empty(), ossimKeywordlist::find(), ossimObject::loadState(), and ossimKeywordNames::TYPE_KW.
Definition at line 67 of file ossimKakaduCodecFactory.cpp.
static |
Definition at line 31 of file ossimKakaduCodecFactory.cpp.
References ossimKakaduCodecFactory(), and theInstance.
Referenced by ossimSharedLibraryInitialize().
private |
Definition at line 78 of file ossimKakaduCodecFactory.cpp.
staticprivate |
Definition at line 70 of file ossimKakaduCodecFactory.h.
