#include <ossimGpkgContentsRecord.h>
| ossimGpkgContentsRecord () | |
| ossimGpkgContentsRecord (const ossimGpkgContentsRecord &obj) | |
| const ossimGpkgContentsRecord & | operator= (const ossimGpkgContentsRecord ©_this) |
| virtual | ~ossimGpkgContentsRecord () |
| destructor More... | |
| virtual bool | init (sqlite3_stmt *pStmt) |
| Initialize from database. More... | |
| bool | init (const std::string &tableName, ossim_int32 srs_id, const ossimDpt &minPt, const ossimDpt &maxPt) |
| Initialize from projection. More... | |
| bool | insert (sqlite3 *db) |
| Inserst this record into gpkg_spatial_ref_sys table. More... | |
| virtual void | saveState (ossimKeywordlist &kwl, const std::string &prefix) const |
| Saves the state of object to keyword list. More... | |
Public Member Functions inherited from ossimGpkgDatabaseRecordBase | |
| ossimGpkgDatabaseRecordBase () | |
| virtual | ~ossimGpkgDatabaseRecordBase () |
| virtual destructor. More... | |
| Print method. More... | |
| static const std::string & | getTableName () |
| Get the table name "gpkg_contents". More... | |
| static bool | createTable (sqlite3 *db) |
| Creates table in database. More... | |
Public Attributes | |
| std::string | m_table_name |
| std::string | m_data_type |
| std::string | m_identifier |
| std::string | m_description |
| std::string | m_last_change |
| ossim_float64 | m_min_x |
| ossim_float64 | m_min_y |
| ossim_float64 | m_max_x |
| ossim_float64 | m_max_y |
| ossim_int32 | m_srs_id |
Definition at line 24 of file ossimGpkgContentsRecord.h.
| ossimGpkgContentsRecord::ossimGpkgContentsRecord | ( | ) |
default constructor
Definition at line 25 of file ossimGpkgContentsRecord.cpp.
| ossimGpkgContentsRecord::ossimGpkgContentsRecord | ( | const ossimGpkgContentsRecord & | obj | ) |
Definition at line 41 of file ossimGpkgContentsRecord.cpp.
static |
| db |
Definition at line 219 of file ossimGpkgContentsRecord.cpp.
References status, and ossim_sqlite::tableExists().
Referenced by ossimGpkgWriter::createTables().
static |
Definition at line 80 of file ossimGpkgContentsRecord.cpp.
Referenced by ossim_gpkg::getNewTableRecord().
| pStmt | SQL statement, i.e. result of sqlite3_prepare_v2(...) call. |
Implements ossimGpkgDatabaseRecordBase.
Definition at line 85 of file ossimGpkgContentsRecord.cpp.
References m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, ossimNotify(), ossimNotifyLevel_WARN, and status.
Referenced by ossimGpkgWriter::writeGpkgContentsTable().
| bool ossimGpkgContentsRecord::init | ( | const std::string & | tableName, |
| ossim_int32 | srs_id, | ||
| const ossimDpt & | minPt, | ||
| const ossimDpt & | maxPt | ||
| tableName | e.g. "tiles" |
| srs_id | ID of gpkg_spatial_ref_sys record our projection is relative to. |
| minPt | Minimum bounds in either Easting Northin or lat lon. |
| maxPt | Maximum bounds in either Easting Northin or lat lon. * |
Definition at line 194 of file ossimGpkgContentsRecord.cpp.
References ossim_sqlite::getTime(), ossimDpt::hasNans(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, status, ossimDpt::x, and ossimDpt::y.
| bool ossimGpkgContentsRecord::insert | ( | sqlite3 * | db | ) |
| db |
Definition at line 259 of file ossimGpkgContentsRecord.cpp.
References ossim_sqlite::exec(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, and status.
| const ossimGpkgContentsRecord & ossimGpkgContentsRecord::operator= | ( | const ossimGpkgContentsRecord & | copy_this | ) |
Definition at line 57 of file ossimGpkgContentsRecord.cpp.
References m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, and m_table_name.
| kwl | Initialized by this. |
| prefix | e.g. "image0.". Can be empty. |
Definition at line 287 of file ossimGpkgContentsRecord.cpp.
References ossimKeywordlist::addPair(), m_data_type, m_description, m_identifier, m_last_change, m_max_x, m_max_y, m_min_x, m_min_y, m_srs_id, m_table_name, ossimString::string(), and ossimString::toString().
| std::string ossimGpkgContentsRecord::m_data_type |
Definition at line 89 of file ossimGpkgContentsRecord.h.
Referenced by init(), insert(), operator=(), and saveState().
| std::string ossimGpkgContentsRecord::m_description |
Definition at line 91 of file ossimGpkgContentsRecord.h.
| std::string ossimGpkgContentsRecord::m_identifier |
Definition at line 90 of file ossimGpkgContentsRecord.h.
| std::string ossimGpkgContentsRecord::m_last_change |
Definition at line 92 of file ossimGpkgContentsRecord.h.
| ossim_float64 ossimGpkgContentsRecord::m_max_x |
Definition at line 95 of file ossimGpkgContentsRecord.h.
| ossim_float64 ossimGpkgContentsRecord::m_max_y |
Definition at line 96 of file ossimGpkgContentsRecord.h.
| ossim_float64 ossimGpkgContentsRecord::m_min_x |
Definition at line 93 of file ossimGpkgContentsRecord.h.
| ossim_float64 ossimGpkgContentsRecord::m_min_y |
Definition at line 94 of file ossimGpkgContentsRecord.h.
| ossim_int32 ossimGpkgContentsRecord::m_srs_id |
Definition at line 97 of file ossimGpkgContentsRecord.h.
| std::string ossimGpkgContentsRecord::m_table_name |
Definition at line 88 of file ossimGpkgContentsRecord.h.
