#include <ossimDiscrete3x3HatFilter.h>
| ossimDiscrete3x3HatFilter () | |
| virtual void | convolve (const float *data, double &result, float nullPixel=OSSIM_DEFAULT_NULL_PIX_FLOAT) const |
| virtual void | convolveSubImage (const float *data, long dataWidth, double &result, float nullPixel=OSSIM_DEFAULT_NULL_PIX_FLOAT) const |
| virtual void | convolve (const unsigned char *data, double &result, ossim_uint8 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT8) const |
| virtual void | convolveSubImage (const unsigned char *data, long dataWidth, double &result, ossim_uint8 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT8) const |
| virtual void | buildConvolution (double widthPercent, double heightPercent) |
Public Member Functions inherited from ossimDiscreteConvolutionKernel | |
| ossimDiscreteConvolutionKernel (long width, long height, bool doWeightedAverage=true) | |
| ossimDiscreteConvolutionKernel (const NEWMAT::Matrix &kernel, bool doWeightedAverage=true) | |
| virtual | ~ossimDiscreteConvolutionKernel () |
| virtual void | setKernel (const NEWMAT::Matrix &kernel) |
| virtual void | convolve (const double *data, double &result, double nullPixel=OSSIM_DEFAULT_NULL_PIX_DOUBLE) const |
| virtual void | convolveSubImage (const double *data, long dataWidth, double &result, double nullPixel=OSSIM_DEFAULT_NULL_PIX_DOUBLE) const |
| virtual void | convolve (const short *data, double &result, ossim_sint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_SINT16) const |
| virtual void | convolveSubImage (const short *data, long dataWidth, double &result, ossim_sint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_SINT16) const |
| virtual void | convolve (const unsigned short *data, double &result, ossim_uint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT16) const |
| virtual void | convolveSubImage (const unsigned short *data, long dataWidth, double &result, ossim_uint16 nullPixel=OSSIM_DEFAULT_NULL_PIX_UINT16) const |
| virtual long | getWidth () const |
| virtual long | getHeight () const |
| const NEWMAT::Matrix & | getKernel () const |
Static Public Member Functions inherited from ossimDiscreteConvolutionKernel | |
| static void | buildSymmetric (const std::vector< float > &coefficients, NEWMAT::Matrix &result) |
| static void | buildSymmetric (float *coefficients, long size, NEWMAT::Matrix &result) |
Protected Attributes inherited from ossimDiscreteConvolutionKernel | |
| NEWMAT::Matrix * | theKernel |
| long | theWidth |
| long | theHeight |
| bool | theComputeWeightedAverageFlag |
Definition at line 14 of file ossimDiscrete3x3HatFilter.h.
| ossimDiscrete3x3HatFilter::ossimDiscrete3x3HatFilter | ( | ) |
Definition at line 12 of file ossimDiscrete3x3HatFilter.cpp.
This is used to allow me to continually adjust a convolution kernel based on where it center lies on a pixel. The xLocation and yLocation are all from the center of pixel. If I am convolving at full resolution then xLocation and yLocation should both be 0. Let's pretend that we contract an image by .5 scale factor or zooming out by a factor of 2. Then we actually of it .5 off from cneter of pixel in both the x and y direction. This information can be used to allow a kernel to adjust it's waits accordingly.
Typically if the xLocation and yLocation is directly on the center indicated by 0 vor both then the kernel defaults to 1 in the middle and all other weights are zero.
Reimplemented from ossimDiscreteConvolutionKernel.
Definition at line 274 of file ossimDiscrete3x3HatFilter.cpp.
References abs.
Will expect a data buffer of size width*height and is row ordered.
Definition at line 29 of file ossimDiscrete3x3HatFilter.cpp.
Definition at line 151 of file ossimDiscrete3x3HatFilter.cpp.
Definition at line 87 of file ossimDiscrete3x3HatFilter.cpp.
this allows you to pass a subImage to the convolution engine. It needs to know the width of the buffer so it can increment to the next element.
Definition at line 210 of file ossimDiscrete3x3HatFilter.cpp.
