#include <ossimCadrgProjection.h>
| ossimCadrgProjection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| double | computeXPixConstant (double scale, long zone) const |
| double | computeYPixConstant (double scale) const |
| ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Returns TRUE if principal parameters are within epsilon tolerance. More... | |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getFalseEasting () const |
| virtual double | getFalseNorthing () const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | update () |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
| virtual | ~ossimCadrgProjection () |
| void | computeParameters () |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Static Protected Attributes | |
| static double | theCadrgArcA [8] |
| static double | theOldZoneExtents [10] |
| static double | theNorthLimit = 90.0*M_PI/180.0 |
| static double | theSouthLimit = -90.0*M_PI/180.0 |
Definition at line 15 of file ossimCadrgProjection.h.
| ossimCadrgProjection::ossimCadrgProjection | ( | ) |
Definition at line 27 of file ossimCadrgProjection.cpp.
References computeParameters().
Referenced by dup().
protectedvirtual |
Definition at line 37 of file ossimCadrgProjection.cpp.
protected |
Definition at line 163 of file ossimCadrgProjection.cpp.
References computeXPixConstant(), computeYPixConstant(), theCadrgZone, theHeight, theMapScale, thePixelConstant, theUlLineSample, theWidth, ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), and ossimCadrgProjection().
| double ossimCadrgProjection::computeXPixConstant | ( | double | scale, |
| long | zone | ||
| ) | const |
Definition at line 126 of file ossimCadrgProjection.cpp.
References theCadrgArcA.
Referenced by computeParameters().
| double ossimCadrgProjection::computeYPixConstant | ( | double | scale | ) | const |
Implements ossimProjection.
Definition at line 42 of file ossimCadrgProjection.cpp.
References ossimCadrgProjection().
Definition at line 65 of file ossimCadrgProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), ossimGpt::datum(), and ossimMapProjection::theDatum.
inlinevirtual |
Definition at line 49 of file ossimCadrgProjection.h.
References ossimObject::getClassName().
Definition at line 57 of file ossimCadrgProjection.cpp.
References DEG_PER_RAD, and ossimMapProjection::theDatum.
Definition at line 82 of file ossimCadrgProjection.cpp.
METHOD: lineSampleToWorld() Performs the inverse projection from line, sample to ground (world):
Definition at line 105 of file ossimCadrgProjection.cpp.
References ossimGpt::clampLat(), ossimGpt::clampLon(), ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::theOrigin, thePixelConstant, theUlLineSample, ossimDpt::x, and ossimDpt::y.
Definition at line 267 of file ossimCadrgProjection.cpp.
References computeParameters(), ossimKeywordlist::find(), ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimProjection::loadState(), ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, theCadrgZone, theHeight, theLlGpt, theLrGpt, theMapScale, theUlGpt, theUrGpt, theWidth, ossimString::toDouble(), ossimString::toLong(), ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimKeywordNames::ZONE_KW.
Definition at line 407 of file ossimCadrgProjection.cpp.
References ossim::almostEqual(), theCadrgZone, theHeight, theLlGpt, theLrGpt, theUlGpt, theUrGpt, and theWidth.
Definition at line 188 of file ossimCadrgProjection.cpp.
References ossimKeywordlist::add(), ossimDatum::code(), ossimKeywordNames::DATUM_KW, ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimProjection::saveState(), theCadrgZone, ossimMapProjection::theDatum, theHeight, theLlGpt, theLrGpt, theMapScale, theUlGpt, theUrGpt, theWidth, ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimKeywordNames::ZONE_KW.
Definition at line 48 of file ossimCadrgProjection.cpp.
METHOD: worldToLineSample() Performs the forward projection from ground point to line, sample.
Definition at line 91 of file ossimCadrgProjection.cpp.
References DEG_PER_RAD, ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::theOrigin, thePixelConstant, theUlLineSample, ossimDpt::x, and ossimDpt::y.
staticprotected |
Definition at line 63 of file ossimCadrgProjection.h.
Referenced by computeXPixConstant().
protected |
Definition at line 71 of file ossimCadrgProjection.h.
Referenced by computeParameters(), loadState(), operator==(), and saveState().
protected |
Definition at line 77 of file ossimCadrgProjection.h.
protected |
Definition at line 82 of file ossimCadrgProjection.h.
Referenced by loadState(), operator==(), and saveState().
protected |
Definition at line 83 of file ossimCadrgProjection.h.
protected |
Definition at line 74 of file ossimCadrgProjection.h.
Referenced by computeParameters(), loadState(), and saveState().
staticprotected |
Definition at line 68 of file ossimCadrgProjection.h.
staticprotected |
Definition at line 66 of file ossimCadrgProjection.h.
protected |
Definition at line 73 of file ossimCadrgProjection.h.
Referenced by computeParameters(), lineSampleToWorld(), and worldToLineSample().
staticprotected |
Definition at line 69 of file ossimCadrgProjection.h.
protected |
Definition at line 81 of file ossimCadrgProjection.h.
protected |
Definition at line 79 of file ossimCadrgProjection.h.
protected |
Definition at line 84 of file ossimCadrgProjection.h.
protected |
Definition at line 76 of file ossimCadrgProjection.h.
