#include <ossimAnnotationObjectFactory.h>
| virtual ossimAnnotationObject * | create (const ossimString &spec) const |
| virtual ossimAnnotationObject * | create (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual list< ossimString > | getList () const |
Public Member Functions inherited from ossimFactoryBase< ossimAnnotationObject > | |
| void | registerFactory (ossimFactoryBase< ossimAnnotationObject > *new_factory) |
| static ossimAnnotationObjectFactory * | instance () |
| ossimAnnotationObjectFactory () | |
Protected Member Functions inherited from ossimFactoryBase< ossimAnnotationObject > | |
| ossimFactoryBase () | |
| virtual | ~ossimFactoryBase () |
Static Protected Attributes | |
| static ossimAnnotationObjectFactory * | theInstance =NULL |
Protected Attributes inherited from ossimFactoryBase< ossimAnnotationObject > | |
| std::list< ossimFactoryBase< ossimAnnotationObject > *> | theRegistry |
Definition at line 14 of file ossimAnnotationObjectFactory.h.
protected |
Definition at line 19 of file ossimAnnotationObjectFactory.cpp.
Referenced by instance().
METHOD: create() Attempts to create an instance of the Product given a Specifier or keywordlist. Returns successfully constructed product or NULL.
Implements ossimFactoryBase< ossimAnnotationObject >.
Definition at line 24 of file ossimAnnotationObjectFactory.cpp.
References STATIC_TYPE_NAME.
Referenced by create().
Definition at line 47 of file ossimAnnotationObjectFactory.cpp.
References create(), ossimKeywordlist::find(), ossimAnnotationObject::loadState(), ossimNotify(), and ossimNotifyLevel_WARN.
METHOD: getList() Returns name list of all products represented by this factory:
Definition at line 87 of file ossimAnnotationObjectFactory.cpp.
References ossimFactoryBase< ossimAnnotationObject >::theRegistry.
static |
METHOD: instance() For accessing static instance of concrete factory.
Definition at line 73 of file ossimAnnotationObjectFactory.cpp.
References ossimAnnotationObjectFactory(), and theInstance.
Referenced by ossimAnnotationSource::loadState().
staticprotected |
Definition at line 40 of file ossimAnnotationObjectFactory.h.
