ossim2dBilinearTransform allows one to specify a set of input points and output points and will fit a bilinear transform to those points. More...
#include <ossim2dBilinearTransform.h>
| ossim2dBilinearTransform () | |
| Initialize to the identity. More... | |
| ossim2dBilinearTransform (const ossimDpt *input, const ossimDpt *output, ossim_uint32 arraySize) | |
| Initialize the transform that best fits the input and output arrays. More... | |
| ossim2dBilinearTransform (const ossimDpt &in1, const ossimDpt &in2, const ossimDpt &in3, const ossimDpt &in4, const ossimDpt &out1, const ossimDpt &out2, const ossimDpt &out3, const ossimDpt &out4) | |
| Mapping 4 corners to an output 4 corners. More... | |
| ossim2dBilinearTransform (const ossim2dBilinearTransform &src) | |
| Copy constructor. More... | |
| Duplication method that duplicates this object. More... | |
| const ossim2dBilinearTransform & | operator= (const ossim2dBilinearTransform &src) |
| Overloaded operator equal that allows for assignment. More... | |
| void | setFromPoints (const ossimDpt &in1, const ossimDpt &in2, const ossimDpt &in3, const ossimDpt &in4, const ossimDpt &out1, const ossimDpt &out2, const ossimDpt &out3, const ossimDpt &out4) |
| void | setFromPoints (const ossimDpt *input, const ossimDpt *output, ossim_uint32 arraySize) |
| virtual void | forward (const ossimDpt &input, ossimDpt &output) const |
| forward transform will transform an input point to the output. More... | |
| virtual void | forward (ossimDpt &modify_this) const |
| forward transform will transform an input point to the output and modify the passed in point to the new value More... | |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) const |
| Inverts the point back to the original input value. More... | |
| virtual void | inverse (ossimDpt &modify_this) const |
| Inverts the point back to the original input value and modifies the passed in point to the new value. More... | |
| Saves the state of this object. More... | |
| loads the state of this object from a keywordlist. More... | |
| prints the contents of this object. More... | |
Public Member Functions inherited from ossim2dTo2dTransform | |
| virtual const ossim2dTo2dTransform & | operator= (const ossim2dTo2dTransform &rhs) |
| virtual ossimDpt | getOrigin () const |
| void | setConvergenceThreshold (const double &new_threshold) |
| void | setMaxIterations (int new_max_iters) |
| void | setDxDy (const ossimDpt &dxdy) |
| ossimObject () | |
Protected Attributes | |
| ossim_float64 | m_coefficientsXTerm [4] |
| ossim_float64 | m_coefficientsYTerm [4] |
| ossim_float64 | m_inverseCoefficientsXTerm [4] |
| ossim_float64 | m_inverseCoefficientsYTerm [4] |
| TYPE_DATA | |
Protected Attributes inherited from ossim2dTo2dTransform | |
| double | theConvergenceThreshold |
| int | theMaxIterations |
| ossimDpt | theDxDy |
Protected Member Functions inherited from ossim2dTo2dTransform | |
| ossim2dTo2dTransform () | |
| virtual | ~ossim2dTo2dTransform () |
Function of the form is solved for each
output dimension.
z(x,y) = a + b*x + c*y + d*x*y
We use the ossimLeastSquareBilin solver to solve for the coefficients.
Definition at line 15 of file ossim2dBilinearTransform.h.
| ossim2dBilinearTransform::ossim2dBilinearTransform | ( | ) |
Definition at line 6 of file ossim2dBilinearTransform.cpp.
References m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, and m_inverseCoefficientsYTerm.
inline |
If the input and output are well dispersed and are 4 points it should fit exactly. Both arrays should be of equal number of points
| input | the list of input points |
| output | the list of output points to transform the input to |
| arraySize | the number of points for the arrays. |
Definition at line 32 of file ossim2dBilinearTransform.h.
inline |
Definition at line 43 of file ossim2dBilinearTransform.h.
| ossim2dBilinearTransform::ossim2dBilinearTransform | ( | const ossim2dBilinearTransform & | src | ) |
Copy constructor.
Definition at line 21 of file ossim2dBilinearTransform.cpp.
inlinevirtual |
Definition at line 57 of file ossim2dBilinearTransform.h.
inlinevirtual |
Implements ossim2dTo2dTransform.
Definition at line 101 of file ossim2dBilinearTransform.h.
References ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Reimplemented from ossim2dTo2dTransform.
Definition at line 118 of file ossim2dBilinearTransform.h.
inlinevirtual |
Definition at line 134 of file ossim2dBilinearTransform.h.
inlinevirtual |
Definition at line 151 of file ossim2dBilinearTransform.h.
Definition at line 102 of file ossim2dBilinearTransform.cpp.
References ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, and ossimString::split().
inline |
| src | the src data to copy into this object. It will call the base classes equal operator. |
Definition at line 65 of file ossim2dBilinearTransform.h.
References m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, and ossim2dTo2dTransform::operator=().
inlinevirtual |
Will also cal the base classes print method.
Definition at line 180 of file ossim2dBilinearTransform.h.
References ossim2dTo2dTransform::print().
Definition at line 75 of file ossim2dBilinearTransform.cpp.
References ossimKeywordlist::add(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, ossim2dTo2dTransform::saveState(), and ossimString::toString().
| void ossim2dBilinearTransform::setFromPoints | ( | const ossimDpt & | in1, |
| const ossimDpt & | in2, | ||
| const ossimDpt & | in3, | ||
| const ossimDpt & | in4, | ||
| const ossimDpt & | out1, | ||
| const ossimDpt & | out2, | ||
| const ossimDpt & | out3, | ||
| const ossimDpt & | out4 | ||
Will use the ossimLeastSquareBilin class to solve the bilinear coefficients that maps the given input points to the output points.
Definition at line 30 of file ossim2dBilinearTransform.cpp.
| void ossim2dBilinearTransform::setFromPoints | ( | const ossimDpt * | input, |
| const ossimDpt * | output, | ||
| ossim_uint32 | arraySize | ||
Definition at line 49 of file ossim2dBilinearTransform.cpp.
References ossimLeastSquaresBilin::addSample(), ossimLeastSquaresBilin::getLSParms(), m_coefficientsXTerm, m_coefficientsYTerm, m_inverseCoefficientsXTerm, m_inverseCoefficientsYTerm, ossimLeastSquaresBilin::solveLS(), x, and y.
protected |
Definition at line 197 of file ossim2dBilinearTransform.h.
Referenced by loadState(), operator=(), ossim2dBilinearTransform(), saveState(), and setFromPoints().
protected |
Definition at line 198 of file ossim2dBilinearTransform.h.
protected |
Definition at line 200 of file ossim2dBilinearTransform.h.
protected |
Definition at line 201 of file ossim2dBilinearTransform.h.
protected |
Definition at line 202 of file ossim2dBilinearTransform.h.
