#include <ossimCeosData.h>
Public Attributes | |
| struct desc_rec | desc |
| char | ascii_flag [2] |
| char | spare1 [2] |
| char | format_doc [12] |
| char | format_rev [2] |
| char | design_rev [2] |
| char | software_id [12] |
| char | file_num [4] |
| char | file_name [16] |
| char | rec_seq [4] |
| char | seq_loc [8] |
| char | seq_len [4] |
| char | rec_code [4] |
| char | code_loc [8] |
| char | code_len [4] |
| char | rec_len [4] |
| char | rlen_loc [8] |
| char | rlen_len [4] |
| char | spare2 |
| char | spare3 |
| char | spare4 |
| char | spare5 |
| char | spare6 [64] |
| char | n_dataset [6] |
| char | l_dataset [6] |
| char | n_map_proj [6] |
| char | l_map_proj [6] |
| char | n_plat_pos [6] |
| char | l_plat_pos [6] |
| char | n_att_data [6] |
| char | l_att_data [6] |
| char | n_radi_data [6] |
| char | l_radi_data [6] |
| char | n_radi_comp [6] |
| char | l_radi_comp [6] |
| char | n_qual_sum [6] |
| char | l_qual_sum [6] |
| char | n_data_hist [6] |
| char | l_data_hist [6] |
| char | n_rang_spec [6] |
| char | l_rang_spec [6] |
| char | n_dem_desc [6] |
| char | l_dem_desc [6] |
| char | n_radar_par [6] |
| char | l_radar_par [6] |
| char | n_anno_data [6] |
| char | l_anno_data [6] |
| char | n_det_proc [6] |
| char | l_det_proc [6] |
| char | n_cal [6] |
| char | l_cal [6] |
| char | n_gcp [6] |
| char | l_gcp [6] |
| char | spare7 [10][6] |
| char | n_fac_data [6] |
| char | l_fac_data [6] |
| char | spare8 [288] |
Definition at line 105 of file ossimCeosData.h.
| char sar_desc_rec::ascii_flag[2] |
Definition at line 108 of file ossimCeosData.h.
| char sar_desc_rec::code_len[4] |
Definition at line 121 of file ossimCeosData.h.
| char sar_desc_rec::code_loc[8] |
Definition at line 120 of file ossimCeosData.h.
| struct desc_rec sar_desc_rec::desc |
Definition at line 107 of file ossimCeosData.h.
| char sar_desc_rec::design_rev[2] |
Definition at line 112 of file ossimCeosData.h.
| char sar_desc_rec::file_name[16] |
Definition at line 115 of file ossimCeosData.h.
| char sar_desc_rec::file_num[4] |
Definition at line 114 of file ossimCeosData.h.
| char sar_desc_rec::format_doc[12] |
Definition at line 110 of file ossimCeosData.h.
| char sar_desc_rec::format_rev[2] |
Definition at line 111 of file ossimCeosData.h.
| char sar_desc_rec::l_anno_data[6] |
Definition at line 153 of file ossimCeosData.h.
| char sar_desc_rec::l_att_data[6] |
Definition at line 137 of file ossimCeosData.h.
| char sar_desc_rec::l_cal[6] |
Definition at line 157 of file ossimCeosData.h.
| char sar_desc_rec::l_data_hist[6] |
Definition at line 145 of file ossimCeosData.h.
| char sar_desc_rec::l_dataset[6] |
Definition at line 131 of file ossimCeosData.h.
| char sar_desc_rec::l_dem_desc[6] |
Definition at line 149 of file ossimCeosData.h.
| char sar_desc_rec::l_det_proc[6] |
Definition at line 155 of file ossimCeosData.h.
| char sar_desc_rec::l_fac_data[6] |
Definition at line 162 of file ossimCeosData.h.
| char sar_desc_rec::l_gcp[6] |
Definition at line 159 of file ossimCeosData.h.
| char sar_desc_rec::l_map_proj[6] |
Definition at line 133 of file ossimCeosData.h.
| char sar_desc_rec::l_plat_pos[6] |
Definition at line 135 of file ossimCeosData.h.
| char sar_desc_rec::l_qual_sum[6] |
Definition at line 143 of file ossimCeosData.h.
| char sar_desc_rec::l_radar_par[6] |
Definition at line 151 of file ossimCeosData.h.
| char sar_desc_rec::l_radi_comp[6] |
Definition at line 141 of file ossimCeosData.h.
| char sar_desc_rec::l_radi_data[6] |
Definition at line 139 of file ossimCeosData.h.
| char sar_desc_rec::l_rang_spec[6] |
Definition at line 147 of file ossimCeosData.h.
| char sar_desc_rec::n_anno_data[6] |
Definition at line 152 of file ossimCeosData.h.
| char sar_desc_rec::n_att_data[6] |
Definition at line 136 of file ossimCeosData.h.
| char sar_desc_rec::n_cal[6] |
Definition at line 156 of file ossimCeosData.h.
| char sar_desc_rec::n_data_hist[6] |
Definition at line 144 of file ossimCeosData.h.
| char sar_desc_rec::n_dataset[6] |
Definition at line 130 of file ossimCeosData.h.
| char sar_desc_rec::n_dem_desc[6] |
Definition at line 148 of file ossimCeosData.h.
| char sar_desc_rec::n_det_proc[6] |
Definition at line 154 of file ossimCeosData.h.
| char sar_desc_rec::n_fac_data[6] |
Definition at line 161 of file ossimCeosData.h.
| char sar_desc_rec::n_gcp[6] |
Definition at line 158 of file ossimCeosData.h.
| char sar_desc_rec::n_map_proj[6] |
Definition at line 132 of file ossimCeosData.h.
| char sar_desc_rec::n_plat_pos[6] |
Definition at line 134 of file ossimCeosData.h.
| char sar_desc_rec::n_qual_sum[6] |
Definition at line 142 of file ossimCeosData.h.
| char sar_desc_rec::n_radar_par[6] |
Definition at line 150 of file ossimCeosData.h.
| char sar_desc_rec::n_radi_comp[6] |
Definition at line 140 of file ossimCeosData.h.
| char sar_desc_rec::n_radi_data[6] |
Definition at line 138 of file ossimCeosData.h.
| char sar_desc_rec::n_rang_spec[6] |
Definition at line 146 of file ossimCeosData.h.
| char sar_desc_rec::rec_code[4] |
Definition at line 119 of file ossimCeosData.h.
| char sar_desc_rec::rec_len[4] |
Definition at line 122 of file ossimCeosData.h.
| char sar_desc_rec::rec_seq[4] |
Definition at line 116 of file ossimCeosData.h.
| char sar_desc_rec::rlen_len[4] |
Definition at line 124 of file ossimCeosData.h.
| char sar_desc_rec::rlen_loc[8] |
Definition at line 123 of file ossimCeosData.h.
| char sar_desc_rec::seq_len[4] |
Definition at line 118 of file ossimCeosData.h.
| char sar_desc_rec::seq_loc[8] |
Definition at line 117 of file ossimCeosData.h.
| char sar_desc_rec::software_id[12] |
Definition at line 113 of file ossimCeosData.h.
| char sar_desc_rec::spare1[2] |
Definition at line 109 of file ossimCeosData.h.
| char sar_desc_rec::spare2 |
Definition at line 125 of file ossimCeosData.h.
| char sar_desc_rec::spare3 |
Definition at line 126 of file ossimCeosData.h.
| char sar_desc_rec::spare4 |
Definition at line 127 of file ossimCeosData.h.
| char sar_desc_rec::spare5 |
Definition at line 128 of file ossimCeosData.h.
| char sar_desc_rec::spare6[64] |
Definition at line 129 of file ossimCeosData.h.
| char sar_desc_rec::spare7[10][6] |
Definition at line 160 of file ossimCeosData.h.
| char sar_desc_rec::spare8[288] |
Definition at line 163 of file ossimCeosData.h.
