#include <ossimCeosData.h>
Public Attributes | |
| struct desc_rec | desc |
| char | rec_seq [4] |
| char | sar_chn [4] |
| char | cali_date [6] |
| char | nchn [4] |
| char | islr [16] |
| char | pslr [16] |
| char | azi_ambig [16] |
| char | rng_ambig [16] |
| char | snr [16] |
| char | ber [16] |
| char | rng_res [16] |
| char | azi_res [16] |
| char | rad_res [16] |
| char | dyn_rng [16] |
| char | rad_unc_db [16] |
| char | rad_unc_deg [16] |
| struct rad_unc_rec | rad_unc [16] |
| char | alt_locerr [16] |
| char | crt_locerr [16] |
| char | alt_scale [16] |
| char | crt_scale [16] |
| char | dis_skew [16] |
| char | ori_err [16] |
| struct misreg_rec | misreg [16] |
| char | nesz [16] |
| char | enl [16] |
| char | tb_update [8] |
| char | spare [238] |
Definition at line 284 of file ossimCeosData.h.
| char qual_sum_rec::alt_locerr[16] |
Definition at line 304 of file ossimCeosData.h.
Referenced by ossimCeosData::dumpQualSumRec().
| char qual_sum_rec::alt_scale[16] |
Definition at line 306 of file ossimCeosData.h.
| char qual_sum_rec::azi_ambig[16] |
Definition at line 293 of file ossimCeosData.h.
| char qual_sum_rec::azi_res[16] |
Definition at line 298 of file ossimCeosData.h.
| char qual_sum_rec::ber[16] |
Definition at line 296 of file ossimCeosData.h.
| char qual_sum_rec::cali_date[6] |
Definition at line 289 of file ossimCeosData.h.
| char qual_sum_rec::crt_locerr[16] |
Definition at line 305 of file ossimCeosData.h.
| char qual_sum_rec::crt_scale[16] |
Definition at line 307 of file ossimCeosData.h.
| struct desc_rec qual_sum_rec::desc |
Definition at line 286 of file ossimCeosData.h.
| char qual_sum_rec::dis_skew[16] |
Definition at line 308 of file ossimCeosData.h.
| char qual_sum_rec::dyn_rng[16] |
Definition at line 300 of file ossimCeosData.h.
| char qual_sum_rec::enl[16] |
Definition at line 312 of file ossimCeosData.h.
| char qual_sum_rec::islr[16] |
Definition at line 291 of file ossimCeosData.h.
| struct misreg_rec qual_sum_rec::misreg[16] |
Definition at line 310 of file ossimCeosData.h.
| char qual_sum_rec::nchn[4] |
Definition at line 290 of file ossimCeosData.h.
| char qual_sum_rec::nesz[16] |
Definition at line 311 of file ossimCeosData.h.
| char qual_sum_rec::ori_err[16] |
Definition at line 309 of file ossimCeosData.h.
| char qual_sum_rec::pslr[16] |
Definition at line 292 of file ossimCeosData.h.
| char qual_sum_rec::rad_res[16] |
Definition at line 299 of file ossimCeosData.h.
| struct rad_unc_rec qual_sum_rec::rad_unc[16] |
Definition at line 303 of file ossimCeosData.h.
| char qual_sum_rec::rad_unc_db[16] |
Definition at line 301 of file ossimCeosData.h.
| char qual_sum_rec::rad_unc_deg[16] |
Definition at line 302 of file ossimCeosData.h.
| char qual_sum_rec::rec_seq[4] |
Definition at line 287 of file ossimCeosData.h.
| char qual_sum_rec::rng_ambig[16] |
Definition at line 294 of file ossimCeosData.h.
| char qual_sum_rec::rng_res[16] |
Definition at line 297 of file ossimCeosData.h.
| char qual_sum_rec::sar_chn[4] |
Definition at line 288 of file ossimCeosData.h.
| char qual_sum_rec::snr[16] |
Definition at line 295 of file ossimCeosData.h.
| char qual_sum_rec::spare[238] |
Definition at line 314 of file ossimCeosData.h.
| char qual_sum_rec::tb_update[8] |
Definition at line 313 of file ossimCeosData.h.
