#include <ossimCeosData.h>
Definition at line 426 of file ossimCeosData.h.
| char proc_parm_rec::act_ing_start[21] |
Definition at line 436 of file ossimCeosData.h.
Referenced by ossimCeosData::dumpProcParmRec().
| char proc_parm_rec::act_ing_stop[21] |
Definition at line 437 of file ossimCeosData.h.
| char proc_parm_rec::adc_samp_rate[5] |
Definition at line 466 of file ossimCeosData.h.
| char proc_parm_rec::angle_first[16] |
Definition at line 513 of file ossimCeosData.h.
| char proc_parm_rec::angle_last[16] |
Definition at line 514 of file ossimCeosData.h.
| char proc_parm_rec::appl_type[12] |
Definition at line 499 of file ossimCeosData.h.
| char proc_parm_rec::apply_dtm[3] |
Definition at line 521 of file ossimCeosData.h.
| char proc_parm_rec::beam_edge_conf[16] |
Definition at line 474 of file ossimCeosData.h.
| char proc_parm_rec::beam_edge_rqd[3] |
Definition at line 473 of file ossimCeosData.h.
| struct beam_info_rec proc_parm_rec::beam_info[4] |
Definition at line 477 of file ossimCeosData.h.
| char proc_parm_rec::bit_err_rate[16] |
Definition at line 445 of file ossimCeosData.h.
| char proc_parm_rec::centre_lat[22] |
Definition at line 517 of file ossimCeosData.h.
| char proc_parm_rec::centre_long[22] |
Definition at line 518 of file ossimCeosData.h.
| char proc_parm_rec::complete_msg[3] |
Definition at line 509 of file ossimCeosData.h.
| char proc_parm_rec::date_incons[8] |
Definition at line 447 of file ossimCeosData.h.
| char proc_parm_rec::delay_changes[8] |
Definition at line 449 of file ossimCeosData.h.
| char proc_parm_rec::density_in[4] |
Definition at line 511 of file ossimCeosData.h.
| char proc_parm_rec::density_out[4] |
Definition at line 522 of file ossimCeosData.h.
| struct desc_rec proc_parm_rec::desc |
Definition at line 428 of file ossimCeosData.h.
| char proc_parm_rec::dop_amb_err[4] |
Definition at line 496 of file ossimCeosData.h.
| char proc_parm_rec::dopamb_conf[16] |
Definition at line 497 of file ossimCeosData.h.
| struct dopcen_est_rec proc_parm_rec::dopcen_est[20] |
Definition at line 495 of file ossimCeosData.h.
| char proc_parm_rec::dopcen_inc[16] |
Definition at line 493 of file ossimCeosData.h.
| char proc_parm_rec::eph_orb_data[7][16] |
Definition at line 498 of file ossimCeosData.h.
| char proc_parm_rec::err_amp_coef[4][16] |
Definition at line 463 of file ossimCeosData.h.
| char proc_parm_rec::err_phas_coef[4][16] |
Definition at line 464 of file ossimCeosData.h.
| char proc_parm_rec::exp_ing_start[21] |
Definition at line 434 of file ossimCeosData.h.
| char proc_parm_rec::exp_ing_stop[21] |
Definition at line 435 of file ossimCeosData.h.
| char proc_parm_rec::fm_crc_err[16] |
Definition at line 446 of file ossimCeosData.h.
| char proc_parm_rec::gics_reqd[3] |
Definition at line 504 of file ossimCeosData.h.
| char proc_parm_rec::gn_corctn_fctr[16] |
Definition at line 468 of file ossimCeosData.h.
| char proc_parm_rec::img_cumu_dist[3][16] |
Definition at line 490 of file ossimCeosData.h.
| char proc_parm_rec::img_hist_mean[16] |
Definition at line 489 of file ossimCeosData.h.
| char proc_parm_rec::inp_media[3] |
Definition at line 431 of file ossimCeosData.h.
| char proc_parm_rec::large_gap[8] |
Definition at line 444 of file ossimCeosData.h.
| char proc_parm_rec::map_system[16] |
Definition at line 516 of file ossimCeosData.h.
| char proc_parm_rec::media_id[8] |
Definition at line 512 of file ossimCeosData.h.
| char proc_parm_rec::miss_ln[8] |
Definition at line 442 of file ossimCeosData.h.
| char proc_parm_rec::mn_sig_lev[10][16] |
Definition at line 440 of file ossimCeosData.h.
| char proc_parm_rec::n_beams[4] |
Definition at line 476 of file ossimCeosData.h.
| char proc_parm_rec::n_dopcen[4] |
Definition at line 494 of file ossimCeosData.h.
| char proc_parm_rec::n_image_pix[8] |
Definition at line 486 of file ossimCeosData.h.
| char proc_parm_rec::n_pix_updates[4] |
Definition at line 478 of file ossimCeosData.h.
| char proc_parm_rec::n_srgr[4] |
Definition at line 501 of file ossimCeosData.h.
| char proc_parm_rec::n_tape_id[4] |
Definition at line 432 of file ossimCeosData.h.
| char proc_parm_rec::n_temp_set[4] |
Definition at line 484 of file ossimCeosData.h.
| char proc_parm_rec::num_state_vectors[4] |
Definition at line 524 of file ossimCeosData.h.
| char proc_parm_rec::orb_data_src[11] |
Definition at line 470 of file ossimCeosData.h.
| struct pix_count_rec proc_parm_rec::pix_count[20] |
Definition at line 479 of file ossimCeosData.h.
| char proc_parm_rec::pix_overlap[4] |
Definition at line 475 of file ossimCeosData.h.
| char proc_parm_rec::pixel_spacing[16] |
Definition at line 503 of file ossimCeosData.h.
| char proc_parm_rec::post_img_gn[16] |
Definition at line 492 of file ossimCeosData.h.
| char proc_parm_rec::prc_satur_pix[16] |
Definition at line 488 of file ossimCeosData.h.
| char proc_parm_rec::prc_zero_pix[16] |
Definition at line 487 of file ossimCeosData.h.
| char proc_parm_rec::pre_img_gn[16] |
Definition at line 491 of file ossimCeosData.h.
| char proc_parm_rec::prf_changes[8] |
Definition at line 448 of file ossimCeosData.h.
| char proc_parm_rec::proc_start[21] |
Definition at line 438 of file ossimCeosData.h.
| char proc_parm_rec::proc_stop[21] |
Definition at line 439 of file ossimCeosData.h.
| char proc_parm_rec::prod_type[3] |
Definition at line 515 of file ossimCeosData.h.
| char proc_parm_rec::pulse_bandw[4] |
Definition at line 465 of file ossimCeosData.h.
| char proc_parm_rec::pulse_cnt_1[4] |
Definition at line 471 of file ossimCeosData.h.
| char proc_parm_rec::pulse_cnt_2[4] |
Definition at line 472 of file ossimCeosData.h.
| char proc_parm_rec::pwin_end[16] |
Definition at line 481 of file ossimCeosData.h.
| char proc_parm_rec::pwin_start[16] |
Definition at line 480 of file ossimCeosData.h.
| char proc_parm_rec::rec_seq[4] |
Definition at line 429 of file ossimCeosData.h.
| char proc_parm_rec::recd_type[9] |
Definition at line 482 of file ossimCeosData.h.
| char proc_parm_rec::rej_bf_start[8] |
Definition at line 451 of file ossimCeosData.h.
| char proc_parm_rec::rej_few_fram[8] |
Definition at line 452 of file ossimCeosData.h.
| char proc_parm_rec::rej_ln[8] |
Definition at line 443 of file ossimCeosData.h.
| char proc_parm_rec::rej_many_fram[8] |
Definition at line 453 of file ossimCeosData.h.
| char proc_parm_rec::rej_mchn_err[8] |
Definition at line 454 of file ossimCeosData.h.
| char proc_parm_rec::rej_rec_type[8] |
Definition at line 456 of file ossimCeosData.h.
| char proc_parm_rec::rej_vchn_err[8] |
Definition at line 455 of file ossimCeosData.h.
| char proc_parm_rec::rep_agc_attn[16] |
Definition at line 467 of file ossimCeosData.h.
| char proc_parm_rec::rep_energy_gn[16] |
Definition at line 469 of file ossimCeosData.h.
| char proc_parm_rec::rng_amp_coef[4][16] |
Definition at line 461 of file ossimCeosData.h.
| char proc_parm_rec::rng_phas_coef[4][16] |
Definition at line 462 of file ossimCeosData.h.
| char proc_parm_rec::rng_ref_src[12] |
Definition at line 460 of file ossimCeosData.h.
| char proc_parm_rec::satellite_id[10] |
Definition at line 507 of file ossimCeosData.h.
| char proc_parm_rec::scene_id[15] |
Definition at line 510 of file ossimCeosData.h.
| char proc_parm_rec::scr_data_ind[4] |
Definition at line 441 of file ossimCeosData.h.
| char proc_parm_rec::sens_config[10] |
Definition at line 457 of file ossimCeosData.h.
| char proc_parm_rec::sens_orient[9] |
Definition at line 458 of file ossimCeosData.h.
| char proc_parm_rec::skipd_frams[8] |
Definition at line 450 of file ossimCeosData.h.
| char proc_parm_rec::slow_time_coef[5][22] |
Definition at line 500 of file ossimCeosData.h.
| char proc_parm_rec::span_x[22] |
Definition at line 519 of file ossimCeosData.h.
| char proc_parm_rec::span_y[22] |
Definition at line 520 of file ossimCeosData.h.
| char proc_parm_rec::spare1[4] |
Definition at line 430 of file ossimCeosData.h.
| char proc_parm_rec::spare2[206] |
Definition at line 526 of file ossimCeosData.h.
| struct srgr_coefset_rec proc_parm_rec::srgr_coefset[20] |
Definition at line 502 of file ossimCeosData.h.
| char proc_parm_rec::state_time[21] |
Definition at line 523 of file ossimCeosData.h.
| char proc_parm_rec::state_time_inc[16] |
Definition at line 525 of file ossimCeosData.h.
| char proc_parm_rec::sych_marker[8] |
Definition at line 459 of file ossimCeosData.h.
| char proc_parm_rec::tape_id[10][8] |
Definition at line 433 of file ossimCeosData.h.
| struct temp_rec proc_parm_rec::temp[20] |
Definition at line 485 of file ossimCeosData.h.
| char proc_parm_rec::temp_set_inc[16] |
Definition at line 483 of file ossimCeosData.h.
| char proc_parm_rec::user_id[20] |
Definition at line 508 of file ossimCeosData.h.
| char proc_parm_rec::wo_date[20] |
Definition at line 506 of file ossimCeosData.h.
| char proc_parm_rec::wo_number[8] |
Definition at line 505 of file ossimCeosData.h.
