#include <ossimCeosData.h>
Public Attributes | |
| struct desc_rec | desc |
| char | seq_num [4] |
| char | sar_chn [4] |
| char | scene_id [16] |
| char | scene_des [32] |
| char | inp_sctim [32] |
| char | asc_des [16] |
| char | pro_lat [16] |
| char | pro_long [16] |
| char | pro_head [16] |
| char | ellip_des [16] |
| char | ellip_maj [16] |
| char | ellip_min [16] |
| char | earth_mass [16] |
| char | grav_const [16] |
| char | ellip_j [3][16] |
| char | spare1 [16] |
| char | terrain_h [16] |
| char | sc_lin [8] |
| char | sc_pix [8] |
| char | scene_len [16] |
| char | scene_wid [16] |
| char | spare2 [16] |
| char | nchn [4] |
| char | spare3 [4] |
| char | mission_id [16] |
| char | sensor_id [32] |
| char | orbit_num [8] |
| char | plat_lat [8] |
| char | plat_long [8] |
| char | plat_head [8] |
| char | clock_ang [8] |
| char | incident_ang [8] |
| char | spare4 [8] |
| char | wave_length [16] |
| char | motion_comp [2] |
| char | pulse_code [16] |
| char | ampl_coef [5][16] |
| char | phas_coef [5][16] |
| char | chirp_ext_ind [8] |
| char | spare5 [8] |
| char | fr [16] |
| char | rng_gate [16] |
| char | rng_length [16] |
| char | baseband_f [4] |
| char | rngcmp_f [4] |
| char | gn_polar [16] |
| char | gn_cross [16] |
| char | chn_bits [8] |
| char | quant_desc [12] |
| char | i_bias [16] |
| char | q_bias [16] |
| char | iq_ratio [16] |
| char | spare6 [16] |
| char | spare7 [16] |
| char | ele_sight [16] |
| char | mech_sight [16] |
| char | echo_track [4] |
| char | fa [16] |
| char | elev_beam [16] |
| char | azim_beam [16] |
| char | sat_bintim [16] |
| char | sat_clktim [32] |
| char | sat_clkinc [8] |
| char | spare8 [8] |
| char | fac_id [16] |
| char | sys_id [8] |
| char | ver_id [8] |
| char | fac_code [16] |
| char | lev_code [16] |
| char | prod_type [32] |
| char | algor_id [32] |
| char | n_azilok [16] |
| char | n_rnglok [16] |
| char | bnd_azilok [16] |
| char | bnd_rnglok [16] |
| char | bnd_azi [16] |
| char | bnd_rng [16] |
| char | azi_weight [32] |
| char | rng_weight [32] |
| char | data_inpsrc [16] |
| char | rng_res [16] |
| char | azi_res [16] |
| char | radi_stretch [2][16] |
| char | alt_dopcen [3][16] |
| char | spare9 [16] |
| char | crt_dopcen [3][16] |
| char | time_dir_pix [8] |
| char | time_dir_lin [8] |
| char | alt_rate [3][16] |
| char | spare10 [16] |
| char | crt_rate [3][16] |
| char | spare11 [16] |
| char | line_cont [8] |
| char | clutter_lock [4] |
| char | auto_focus [4] |
| char | line_spacing [16] |
| char | pix_spacing [16] |
| char | rngcmp_desg [16] |
| char | spare12 [2362] |
Definition at line 167 of file ossimCeosData.h.
| char dataset_sum_rec::algor_id[32] |
Definition at line 240 of file ossimCeosData.h.
Referenced by ossimCeosData::dumpDataSetSumRec().
| char dataset_sum_rec::alt_dopcen[3][16] |
Definition at line 253 of file ossimCeosData.h.
| char dataset_sum_rec::alt_rate[3][16] |
Definition at line 258 of file ossimCeosData.h.
| char dataset_sum_rec::ampl_coef[5][16] |
Definition at line 206 of file ossimCeosData.h.
| char dataset_sum_rec::asc_des[16] |
Definition at line 175 of file ossimCeosData.h.
| char dataset_sum_rec::auto_focus[4] |
Definition at line 264 of file ossimCeosData.h.
| char dataset_sum_rec::azi_res[16] |
Definition at line 251 of file ossimCeosData.h.
| char dataset_sum_rec::azi_weight[32] |
Definition at line 247 of file ossimCeosData.h.
| char dataset_sum_rec::azim_beam[16] |
Definition at line 229 of file ossimCeosData.h.
| char dataset_sum_rec::baseband_f[4] |
Definition at line 213 of file ossimCeosData.h.
| char dataset_sum_rec::bnd_azi[16] |
Definition at line 245 of file ossimCeosData.h.
| char dataset_sum_rec::bnd_azilok[16] |
Definition at line 243 of file ossimCeosData.h.
| char dataset_sum_rec::bnd_rng[16] |
Definition at line 246 of file ossimCeosData.h.
| char dataset_sum_rec::bnd_rnglok[16] |
Definition at line 244 of file ossimCeosData.h.
| char dataset_sum_rec::chirp_ext_ind[8] |
Definition at line 208 of file ossimCeosData.h.
| char dataset_sum_rec::chn_bits[8] |
Definition at line 217 of file ossimCeosData.h.
| char dataset_sum_rec::clock_ang[8] |
Definition at line 200 of file ossimCeosData.h.
| char dataset_sum_rec::clutter_lock[4] |
Definition at line 263 of file ossimCeosData.h.
| char dataset_sum_rec::crt_dopcen[3][16] |
Definition at line 255 of file ossimCeosData.h.
| char dataset_sum_rec::crt_rate[3][16] |
Definition at line 260 of file ossimCeosData.h.
| char dataset_sum_rec::data_inpsrc[16] |
Definition at line 249 of file ossimCeosData.h.
| struct desc_rec dataset_sum_rec::desc |
Definition at line 169 of file ossimCeosData.h.
| char dataset_sum_rec::earth_mass[16] |
Definition at line 182 of file ossimCeosData.h.
| char dataset_sum_rec::echo_track[4] |
Definition at line 226 of file ossimCeosData.h.
| char dataset_sum_rec::ele_sight[16] |
Definition at line 224 of file ossimCeosData.h.
| char dataset_sum_rec::elev_beam[16] |
Definition at line 228 of file ossimCeosData.h.
| char dataset_sum_rec::ellip_des[16] |
Definition at line 179 of file ossimCeosData.h.
| char dataset_sum_rec::ellip_j[3][16] |
Definition at line 184 of file ossimCeosData.h.
| char dataset_sum_rec::ellip_maj[16] |
Definition at line 180 of file ossimCeosData.h.
| char dataset_sum_rec::ellip_min[16] |
Definition at line 181 of file ossimCeosData.h.
| char dataset_sum_rec::fa[16] |
Definition at line 227 of file ossimCeosData.h.
| char dataset_sum_rec::fac_code[16] |
Definition at line 237 of file ossimCeosData.h.
| char dataset_sum_rec::fac_id[16] |
Definition at line 234 of file ossimCeosData.h.
| char dataset_sum_rec::fr[16] |
Definition at line 210 of file ossimCeosData.h.
| char dataset_sum_rec::gn_cross[16] |
Definition at line 216 of file ossimCeosData.h.
| char dataset_sum_rec::gn_polar[16] |
Definition at line 215 of file ossimCeosData.h.
| char dataset_sum_rec::grav_const[16] |
Definition at line 183 of file ossimCeosData.h.
| char dataset_sum_rec::i_bias[16] |
Definition at line 219 of file ossimCeosData.h.
| char dataset_sum_rec::incident_ang[8] |
Definition at line 201 of file ossimCeosData.h.
| char dataset_sum_rec::inp_sctim[32] |
Definition at line 174 of file ossimCeosData.h.
| char dataset_sum_rec::iq_ratio[16] |
Definition at line 221 of file ossimCeosData.h.
| char dataset_sum_rec::lev_code[16] |
Definition at line 238 of file ossimCeosData.h.
| char dataset_sum_rec::line_cont[8] |
Definition at line 262 of file ossimCeosData.h.
| char dataset_sum_rec::line_spacing[16] |
Definition at line 265 of file ossimCeosData.h.
| char dataset_sum_rec::mech_sight[16] |
Definition at line 225 of file ossimCeosData.h.
| char dataset_sum_rec::mission_id[16] |
Definition at line 194 of file ossimCeosData.h.
| char dataset_sum_rec::motion_comp[2] |
Definition at line 204 of file ossimCeosData.h.
| char dataset_sum_rec::n_azilok[16] |
Definition at line 241 of file ossimCeosData.h.
| char dataset_sum_rec::n_rnglok[16] |
Definition at line 242 of file ossimCeosData.h.
| char dataset_sum_rec::nchn[4] |
Definition at line 192 of file ossimCeosData.h.
| char dataset_sum_rec::orbit_num[8] |
Definition at line 196 of file ossimCeosData.h.
| char dataset_sum_rec::phas_coef[5][16] |
Definition at line 207 of file ossimCeosData.h.
| char dataset_sum_rec::pix_spacing[16] |
Definition at line 266 of file ossimCeosData.h.
| char dataset_sum_rec::plat_head[8] |
Definition at line 199 of file ossimCeosData.h.
| char dataset_sum_rec::plat_lat[8] |
Definition at line 197 of file ossimCeosData.h.
| char dataset_sum_rec::plat_long[8] |
Definition at line 198 of file ossimCeosData.h.
| char dataset_sum_rec::pro_head[16] |
Definition at line 178 of file ossimCeosData.h.
| char dataset_sum_rec::pro_lat[16] |
Definition at line 176 of file ossimCeosData.h.
| char dataset_sum_rec::pro_long[16] |
Definition at line 177 of file ossimCeosData.h.
| char dataset_sum_rec::prod_type[32] |
Definition at line 239 of file ossimCeosData.h.
| char dataset_sum_rec::pulse_code[16] |
Definition at line 205 of file ossimCeosData.h.
| char dataset_sum_rec::q_bias[16] |
Definition at line 220 of file ossimCeosData.h.
| char dataset_sum_rec::quant_desc[12] |
Definition at line 218 of file ossimCeosData.h.
| char dataset_sum_rec::radi_stretch[2][16] |
Definition at line 252 of file ossimCeosData.h.
| char dataset_sum_rec::rng_gate[16] |
Definition at line 211 of file ossimCeosData.h.
| char dataset_sum_rec::rng_length[16] |
Definition at line 212 of file ossimCeosData.h.
| char dataset_sum_rec::rng_res[16] |
Definition at line 250 of file ossimCeosData.h.
| char dataset_sum_rec::rng_weight[32] |
Definition at line 248 of file ossimCeosData.h.
| char dataset_sum_rec::rngcmp_desg[16] |
Definition at line 267 of file ossimCeosData.h.
| char dataset_sum_rec::rngcmp_f[4] |
Definition at line 214 of file ossimCeosData.h.
| char dataset_sum_rec::sar_chn[4] |
Definition at line 171 of file ossimCeosData.h.
| char dataset_sum_rec::sat_bintim[16] |
Definition at line 230 of file ossimCeosData.h.
| char dataset_sum_rec::sat_clkinc[8] |
Definition at line 232 of file ossimCeosData.h.
| char dataset_sum_rec::sat_clktim[32] |
Definition at line 231 of file ossimCeosData.h.
| char dataset_sum_rec::sc_lin[8] |
Definition at line 187 of file ossimCeosData.h.
| char dataset_sum_rec::sc_pix[8] |
Definition at line 188 of file ossimCeosData.h.
| char dataset_sum_rec::scene_des[32] |
Definition at line 173 of file ossimCeosData.h.
| char dataset_sum_rec::scene_id[16] |
Definition at line 172 of file ossimCeosData.h.
| char dataset_sum_rec::scene_len[16] |
Definition at line 189 of file ossimCeosData.h.
| char dataset_sum_rec::scene_wid[16] |
Definition at line 190 of file ossimCeosData.h.
| char dataset_sum_rec::sensor_id[32] |
Definition at line 195 of file ossimCeosData.h.
| char dataset_sum_rec::seq_num[4] |
Definition at line 170 of file ossimCeosData.h.
| char dataset_sum_rec::spare1[16] |
Definition at line 185 of file ossimCeosData.h.
| char dataset_sum_rec::spare10[16] |
Definition at line 259 of file ossimCeosData.h.
| char dataset_sum_rec::spare11[16] |
Definition at line 261 of file ossimCeosData.h.
| char dataset_sum_rec::spare12[2362] |
Definition at line 268 of file ossimCeosData.h.
| char dataset_sum_rec::spare2[16] |
Definition at line 191 of file ossimCeosData.h.
| char dataset_sum_rec::spare3[4] |
Definition at line 193 of file ossimCeosData.h.
| char dataset_sum_rec::spare4[8] |
Definition at line 202 of file ossimCeosData.h.
| char dataset_sum_rec::spare5[8] |
Definition at line 209 of file ossimCeosData.h.
| char dataset_sum_rec::spare6[16] |
Definition at line 222 of file ossimCeosData.h.
| char dataset_sum_rec::spare7[16] |
Definition at line 223 of file ossimCeosData.h.
| char dataset_sum_rec::spare8[8] |
Definition at line 233 of file ossimCeosData.h.
| char dataset_sum_rec::spare9[16] |
Definition at line 254 of file ossimCeosData.h.
| char dataset_sum_rec::sys_id[8] |
Definition at line 235 of file ossimCeosData.h.
| char dataset_sum_rec::terrain_h[16] |
Definition at line 186 of file ossimCeosData.h.
| char dataset_sum_rec::time_dir_lin[8] |
Definition at line 257 of file ossimCeosData.h.
| char dataset_sum_rec::time_dir_pix[8] |
Definition at line 256 of file ossimCeosData.h.
| char dataset_sum_rec::ver_id[8] |
Definition at line 236 of file ossimCeosData.h.
| char dataset_sum_rec::wave_length[16] |
Definition at line 203 of file ossimCeosData.h.
