#include <stdio.h>Go to the source code of this file.
Classes | |
| struct | set_type |
Macros | |
| #define | SET_ON(set) memset(set.buf,255,(set.size>>3L)+1L) |
| #define | SET_OFF(set) memset(set.buf,0,(set.size>>3L)+1L) |
Functions | |
| set_type | set_init (long int n) |
| int | set_empty (set_type set) |
| void | set_insert (long int element, set_type set) |
| void | set_delete (long int element, set_type set) |
| int | set_member (long int element, set_type set) |
| long int | set_min (set_type set) |
| long int | set_max (set_type set) |
| long int | num_in_set (set_type set) |
| void | set_on (set_type set) |
| void | set_off (set_type set) |
| int | set_equal (set_type a, set_type b) |
| void | set_assign (set_type *a, set_type b) |
| set_type | set_union (set_type a, set_type b) |
| set_type | set_intersection (set_type a, set_type b) |
| set_type | set_difference (set_type a, set_type b) |
| void | set_nuke (set_type *set) |
| long int num_in_set | ( | set_type | set | ) |
| void set_delete | ( | long int | element, |
| set_type | set | ||
| int set_empty | ( | set_type | set | ) |
| set_type set_init | ( | long int | n | ) |
| void set_insert | ( | long int | element, |
| set_type | set | ||
| long int set_max | ( | set_type | set | ) |
| int set_member | ( | long int | element, |
| set_type | set | ||
| long int set_min | ( | set_type | set | ) |
| void set_nuke | ( | set_type * | set | ) |
| void set_off | ( | set_type | set | ) |
| void set_on | ( | set_type | set | ) |
