ossimKeywordNames.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 // Copyright (C) 2000 ImageLinks Inc.
3 //
4 // License: See top level LICENSE.txt file
5 //
6 // Author: Ken Melero ([email protected])
7 //
8 // Description: Common file for global Keywords.
9 //
10 //*************************************************************************
11 // $Id: ossimKeywordNames.cpp 23037 2014-12-11 20:37:51Z okramer $
12
14
15 const char* ossimKeywordNames::AZIMUTH_ANGLE_KW = "azimuth_angle";
16 const char* ossimKeywordNames::BAND_KW = "band";
17 const char* ossimKeywordNames::BANDS_KW = "bands";
18 const char* ossimKeywordNames::BORDER_SIZE_KW = "border_size";
19 const char* ossimKeywordNames::BRUSH_COLOR_KW = "brush_color";
20 const char* ossimKeywordNames::BYTE_ORDER_KW = "byte_order";
21 const char* ossimKeywordNames::CE90_ABSOLUTE_KW = "ce90_absolute";
22 const char* ossimKeywordNames::CE90_RELATIVE_KW = "ce90_relative";
23 const char* ossimKeywordNames::CENTRAL_MERIDIAN_KW = "central_meridian";
24 const char* ossimKeywordNames::CENTRAL_POINT1_LAT_KW = "central_point1_lat";
25 const char* ossimKeywordNames::CENTRAL_POINT1_LON_KW = "central_point1_lon";
26 const char* ossimKeywordNames::CENTRAL_POINT2_LAT_KW = "central_point2_lat";
27 const char* ossimKeywordNames::CENTRAL_POINT2_LON_KW = "central_point2_lon";
28 const char* ossimKeywordNames::CENTER_PIXEL_X_KW = "center_pixel_x";
29 const char* ossimKeywordNames::CENTER_PIXEL_Y_KW = "center_pixel_y";
30 const char* ossimKeywordNames::COMPRESS_KW = "compress";
31 const char* ossimKeywordNames::COMPRESSION_QUALITY_KW = "compression_quality";
32 const char* ossimKeywordNames::COMPRESSION_TYPE_KW = "compression_type";
33 const char* ossimKeywordNames::CONVERGENCE_THRESHOLD_KW = "convergence_threshold";
34 const char* ossimKeywordNames::CREATE_EXTERNAL_GEOMETRY_KW = "create_external_geometry";
35 const char* ossimKeywordNames::CREATE_IMAGE_KW = "create_image";
36 const char* ossimKeywordNames::CREATE_HISTOGRAM_KW = "create_histogram";
37 const char* ossimKeywordNames::CREATE_OVERVIEW_KW = "create_overview";
38 const char* ossimKeywordNames::DATA_FILE_KW = "data_file";
39 const char* ossimKeywordNames::DATE_KW = "date";
40 const char* ossimKeywordNames::DATE_YEAR_KW = "year";
41 const char* ossimKeywordNames::DATE_MONTH_KW = "month";
42 const char* ossimKeywordNames::DATE_DAY_KW = "day";
43 const char* ossimKeywordNames::DATE_HOUR_KW = "hour";
44 const char* ossimKeywordNames::DATE_MIN_KW = "min";
45 const char* ossimKeywordNames::DATE_SEC_KW = "sec";
46 const char* ossimKeywordNames::DATE_FRACT_SEC_KW = "fract_sec";
47 const char* ossimKeywordNames::DATUM_KW = "datum";
48 const char* ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT = "decimal_degrees_per_pixel_lat";
49 const char* ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON = "decimal_degrees_per_pixel_lon";
50 const char* ossimKeywordNames::DESCRIPTION_KW = "description";
51 const char* ossimKeywordNames::ELEVATION_ANGLE_KW = "elevation_angle";
52 const char* ossimKeywordNames::ELEVATION_CELL_KW = "elevation_cell";
53 const char* ossimKeywordNames::ELEVATION_SOURCE_KW = "elevation_source";
54 const char* ossimKeywordNames::ELEVATION_LOOKUP_FLAG_KW = "elevation_lookup_flag";
55 const char* ossimKeywordNames::ELLIPSE_CODE_KW = "ellipse_code";
56 const char* ossimKeywordNames::ELLIPSE_EPSG_CODE_KW = "ellipse_epsg_code";
57 const char* ossimKeywordNames::ELLIPSE_NAME_KW = "ellipse_name";
58 const char* ossimKeywordNames::ENABLED_KW = "enabled";
59 const char* ossimKeywordNames::ENABLE_CACHE_KW = "enable_cache";
60 const char* ossimKeywordNames::EXTRACT_VERTICES_KW = "extract_vertices";
61 const char* ossimKeywordNames::ENTRY_KW = "entry";
62 const char* ossimKeywordNames::FALSE_EASTING_NORTHING_KW = "false_easting_northing";
63 const char* ossimKeywordNames::FALSE_EASTING_NORTHING_UNITS_KW = "false_easting_northing_units";
64 const char* ossimKeywordNames::FALSE_EASTING_KW = "false_easting";
65 const char* ossimKeywordNames::FALSE_NORTHING_KW = "false_northing";
66 const char* ossimKeywordNames::FEATURE_NAME_KW = "feature_name";
67 const char* ossimKeywordNames::FILE_KW = "file";
68 const char* ossimKeywordNames::FILENAME_KW = "filename";
69 const char* ossimKeywordNames::FILEPATH_KW = "filepath";
70 const char* ossimKeywordNames::FILL_FLAG_KW = "fill_flag";
71 const char* ossimKeywordNames::FRAME_INDEX_KW = "frame_index";
72 const char* ossimKeywordNames::GCS_CODE_KW = "gcs_code";
73 const char* ossimKeywordNames::GEOM_FILE_KW = "geom_file";
74 const char* ossimKeywordNames::HEMISPHERE_KW = "hemisphere";
75 const char* ossimKeywordNames::HORIZONTAL_SIZE_KW = "horizontal_size";
76 const char* ossimKeywordNames::HAS_LUT_KW = "has_lut";
77 const char* ossimKeywordNames::ID_KW ="id";
78 const char* ossimKeywordNames::IMAGE_CE90_KW = "estimated_image_ce90";
79 const char* ossimKeywordNames::IMAGE_FILE_KW = "image_file";
80 const char* ossimKeywordNames::IMAGE_ID_KW = "image_id";
81 const char* ossimKeywordNames::IMAGE_MODEL_TRANSFORM_MATRIX_KW = "image_model_transform_matrix";
82 const char* ossimKeywordNames::IMAGE_MODEL_TRANSFORM_UNIT_KW = "image_model_transform_unit";
83 const char* ossimKeywordNames::IMAGE_PATH_KW = "image_path";
84 const char* ossimKeywordNames::IMAGE_TYPE_KW = "image_type";
85 const char* ossimKeywordNames::IMAGE_DATE_KW = "image_date";
86 const char* ossimKeywordNames::IMAGE_FILE_SIZE_KW = "image_file_size";
87 const char* ossimKeywordNames::INPUT_RR_LEVEL_KW = "input_rr_level";
88 const char* ossimKeywordNames::INTERLEAVE_TYPE_KW = "interleave_type";
89 const char* ossimKeywordNames::JULIAN_DAY_KW = "julian_day";
90 const char* ossimKeywordNames::LAT_INCREMENT_KW = "lat_increment";
91 const char* ossimKeywordNames::LL_LAT_KW = "ll_lat";
92 const char* ossimKeywordNames::LL_LON_KW = "ll_lon";
93 const char* ossimKeywordNames::LR_LAT_KW = "lr_lat";
94 const char* ossimKeywordNames::LR_LON_KW = "lr_lon";
95 const char* ossimKeywordNames::LL_X_KW = "ll_x";
96 const char* ossimKeywordNames::LL_Y_KW = "ll_y";
97 const char* ossimKeywordNames::LR_X_KW = "lr_x";
98 const char* ossimKeywordNames::LR_Y_KW = "lr_y";
99 const char* ossimKeywordNames::LON_INCREMENT_KW = "lon_increment";
100 const char* ossimKeywordNames::MAJOR_AXIS_KW = "major_axis";
101 const char* ossimKeywordNames::MAX_VALUE_KW = "max_value";
102 const char* ossimKeywordNames::MAX_ITERATIONS_KW = "max_iterations";
103 const char* ossimKeywordNames::MAX_QUADTREE_LEVELS_KW = "max_quadtree_levels";
104 const char* ossimKeywordNames::METADATA_TYPE_KW = "metadata_type";
105 const char* ossimKeywordNames::METERS_PER_PIXEL_KW = "meters_per_pixel";
106 const char* ossimKeywordNames::METERS_PER_PIXEL_X_KW = "meters_per_pixel_x";
107 const char* ossimKeywordNames::METERS_PER_PIXEL_Y_KW = "meters_per_pixel_y";
108 const char* ossimKeywordNames::MINOR_AXIS_KW = "minor_axis";
109 const char* ossimKeywordNames::MIN_VALUE_KW = "min_value";
110 const char* ossimKeywordNames::NULL_VALUE_KW = "null_value";
111 const char* ossimKeywordNames::NUMBER_BANDS_KW = "number_bands";
112 const char* ossimKeywordNames::NUMBER_ENTRIES_KW = "number_entries";
113 const char* ossimKeywordNames::NUMBER_INPUT_BANDS_KW = "number_input_bands";
114 const char* ossimKeywordNames::NUMBER_INPUTS_KW = "number_inputs";
115 const char* ossimKeywordNames::NUMBER_OUTPUTS_KW = "number_outputs";
116 const char* ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW = "number_output_bands";
117 const char* ossimKeywordNames::NUMBER_LINES_KW = "number_lines";
118 const char* ossimKeywordNames::NUMBER_REDUCED_RES_SETS_KW = "number_reduced_res_sets";
119 const char* ossimKeywordNames::NUMBER_SAMPLES_KW = "number_samples";
120 const char* ossimKeywordNames::ORIGIN_X_KW = "origin_x";
121 const char* ossimKeywordNames::ORIGIN_Y_KW = "origin_y";
122 const char* ossimKeywordNames::ORIGIN_LATITUDE_KW = "origin_latitude";
123 const char* ossimKeywordNames::ORIGINAL_MAP_UNITS_KW = "original_map_units";
124 const char* ossimKeywordNames::OUTPUT_FILE_KW = "output_file";
125 const char* ossimKeywordNames::OUTPUT_FILE_PREFIX_KW = "output_file_prefix";
126 const char* ossimKeywordNames::OUTPUT_FILE_EXTENSION_KW = "output_file_extension";
127 const char* ossimKeywordNames::OUTPUT_TILE_SIZE_KW = "output_tile_size";
128 const char* ossimKeywordNames::OVERVIEW_COMPRESSION_QUALITY_KW = "overview_compression_quality";
129 const char* ossimKeywordNames::OVERVIEW_COMPRESSION_TYPE_KW = "overview_compression_type";
130 const char* ossimKeywordNames::OVERVIEW_FILE_KW = "overview_file";
131 const char* ossimKeywordNames::OVERVIEW_STOP_DIMENSION_KW = "overview_stop_dimension";
132 const char* ossimKeywordNames::PCS_CODE_KW = "pcs_code";
133 const char* ossimKeywordNames::PEN_COLOR_KW = "pen_color";
134 const char* ossimKeywordNames::PHOTOMETRIC_KW = "photometric";
135 const char* ossimKeywordNames::PIXEL_SCALE_XY_KW = "pixel_scale_xy";
136 const char* ossimKeywordNames::PIXEL_SCALE_UNITS_KW = "pixel_scale_units";
137 const char* ossimKeywordNames::PIXEL_TYPE_KW = "pixel_type";
138 const char* ossimKeywordNames::PLANAR_CONFIG_KW = "planar_config";
139 const char* ossimKeywordNames::POINT_WIDTH_HEIGHT_KW = "point_width_height";
140 const char* ossimKeywordNames::PROJECTION_KW = "projection";
141 const char* ossimKeywordNames::QUALITY_KW = "quality";
142 const char* ossimKeywordNames::QUERY_KW = "query";
143 const char* ossimKeywordNames::RADIOMETRY_KW = "radiometry";
144 const char* ossimKeywordNames::REDUCED_RES_LEVEL_KW = "reduced_res_level";
145 const char* ossimKeywordNames::REF_GPT_LAT_KW = "ref_point_lat";
146 const char* ossimKeywordNames::REF_GPT_LON_KW = "ref_point_lon";
147 const char* ossimKeywordNames::REF_GPT_HGT_KW = "ref_point_hgt";
148 const char* ossimKeywordNames::REF_IPT_LINE_KW = "ref_point_line";
149 const char* ossimKeywordNames::REF_IPT_SAMP_KW = "ref_point_samp";
150 const char* ossimKeywordNames::ROTATION_KW = "rotation";
151 const char* ossimKeywordNames::SCALE_PER_PIXEL_X_KW = "scale_per_pixel_x";
152 const char* ossimKeywordNames::SCALE_PER_PIXEL_Y_KW = "scale_per_pixel_y";
153 const char* ossimKeywordNames::SCALAR_TYPE_KW = "scalar_type";
154 const char* ossimKeywordNames::SCALE_FACTOR_KW = "scale_factor";
155 const char* ossimKeywordNames::SCALE_FACTOR_X_KW = "scale_factor_x";
156 const char* ossimKeywordNames::SCALE_FACTOR_Y_KW = "scale_factor_y";
157 const char* ossimKeywordNames::SCALE_X_KW = "scale_x";
158 const char* ossimKeywordNames::SCALE_Y_KW = "scale_y";
159 const char* ossimKeywordNames::SENSOR_ID_KW = "sensor";
160 const char* ossimKeywordNames::SRS_NAME_KW = "srs_name";
161 const char* ossimKeywordNames::STD_PARALLEL_1_KW = "std_parallel_1";
162 const char* ossimKeywordNames::STD_PARALLEL_2_KW = "std_parallel_2";
163 const char* ossimKeywordNames::THICKNESS_KW = "thickness";
164 const char* ossimKeywordNames::THREADS_KW = "threads";
165 const char* ossimKeywordNames::TIE_POINT_EASTING_KW = "tie_point_easting"; // ????
166 const char* ossimKeywordNames::TIE_POINT_NORTHING_KW = "tie_point_northing"; // ????
167 const char* ossimKeywordNames::TIE_POINT_XY_KW = "tie_point_xy"; // ????
168 const char* ossimKeywordNames::TIE_POINT_UNITS_KW = "tie_point_units";
169 const char* ossimKeywordNames::TIE_POINT_LAT_KW = "tie_point_lat";
170 const char* ossimKeywordNames::TIE_POINT_LON_KW = "tie_point_lon";
171 const char* ossimKeywordNames::TILE_SIZE_X_KW = "tile_size_x";
172 const char* ossimKeywordNames::TILE_SIZE_Y_KW = "tile_size_y";
173 const char* ossimKeywordNames::TILE_SOURCE_KW = "tile_source";
174 const char* ossimKeywordNames::TILE_TYPE_KW = "tile_type";
175 const char* ossimKeywordNames::TRANSLATION_X_KW = "translation_x";
176 const char* ossimKeywordNames::TRANSLATION_Y_KW = "translation_y";
177 const char* ossimKeywordNames::TYPE_KW = "type";
178 const char* ossimKeywordNames::UL_LAT_KW = "ul_lat";
179 const char* ossimKeywordNames::UL_LON_KW = "ul_lon";
180 const char* ossimKeywordNames::UNITS_KW = "units";
181 const char* ossimKeywordNames::UR_LAT_KW = "ur_lat";
182 const char* ossimKeywordNames::UR_LON_KW = "ur_lon";
183 const char* ossimKeywordNames::UL_X_KW = "ul_x";
184 const char* ossimKeywordNames::UL_Y_KW = "ul_y";
185 const char* ossimKeywordNames::UR_X_KW = "ur_x";
186 const char* ossimKeywordNames::UR_Y_KW = "ur_y";
187 const char* ossimKeywordNames::VALID_VERTICES_KW = "valid_vertices_file";
188 const char* ossimKeywordNames::VERTICAL_SIZE_KW = "vertical_size";
189 const char* ossimKeywordNames::ZONE_KW = "zone";
190
192 {}
193
195 {}
196
198 {
199  return *this;
200 }
static const char * DATE_HOUR_KW
static const char * REF_GPT_LON_KW
static const char * IMAGE_PATH_KW
static const char * BYTE_ORDER_KW
static const char * MIN_VALUE_KW
static const char * ORIGIN_Y_KW
static const char * OVERVIEW_FILE_KW
static const char * PHOTOMETRIC_KW
static const char * MINOR_AXIS_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LAT
static const char * PROJECTION_KW
static const char * BRUSH_COLOR_KW
static const char * VALID_VERTICES_KW
static const char * FILE_KW
static const char * DATUM_KW
static const char * CENTER_PIXEL_X_KW
static const char * OUTPUT_FILE_KW
static const char * REF_GPT_LAT_KW
static const char * FALSE_EASTING_NORTHING_UNITS_KW
static const char * IMAGE_DATE_KW
static const char * ELEVATION_CELL_KW
static const char * CENTRAL_MERIDIAN_KW
static const char * CENTRAL_POINT2_LON_KW
static const char * CREATE_HISTOGRAM_KW
static const char * UL_LAT_KW
static const char * LR_X_KW
static const char * OUTPUT_TILE_SIZE_KW
static const char * OUTPUT_FILE_EXTENSION_KW
static const char * ORIGINAL_MAP_UNITS_KW
static const char * IMAGE_MODEL_TRANSFORM_MATRIX_KW
static const char * OVERVIEW_COMPRESSION_TYPE_KW
static const char * MAX_VALUE_KW
static const char * SCALE_X_KW
static const char * NULL_VALUE_KW
static const char * HORIZONTAL_SIZE_KW
static const char * SCALE_FACTOR_Y_KW
static const char * NUMBER_LINES_KW
static const char * TIE_POINT_LON_KW
static const char * METADATA_TYPE_KW
static const char * NUMBER_INPUT_BANDS_KW
const ossimKeywordNames & operator=(const ossimKeywordNames &rhs)
static const char * TILE_SOURCE_KW
static const char * LR_LON_KW
static const char * NUMBER_ENTRIES_KW
static const char * ROTATION_KW
static const char * FILEPATH_KW
static const char * JULIAN_DAY_KW
static const char * TILE_SIZE_Y_KW
static const char * FRAME_INDEX_KW
static const char * DATE_FRACT_SEC_KW
static const char * SCALE_FACTOR_X_KW
static const char * IMAGE_ID_KW
static const char * METERS_PER_PIXEL_Y_KW
static const char * TYPE_KW
static const char * SCALE_Y_KW
static const char * REF_GPT_HGT_KW
static const char * PLANAR_CONFIG_KW
static const char * GCS_CODE_KW
static const char * NUMBER_INPUTS_KW
static const char * DATE_MONTH_KW
static const char * MAX_QUADTREE_LEVELS_KW
static const char * PIXEL_SCALE_XY_KW
static const char * ELEVATION_LOOKUP_FLAG_KW
static const char * TIE_POINT_NORTHING_KW
static const char * FEATURE_NAME_KW
static const char * RADIOMETRY_KW
static const char * SCALE_PER_PIXEL_X_KW
static const char * ZONE_KW
static const char * UR_Y_KW
static const char * LR_Y_KW
static const char * SENSOR_ID_KW
static const char * LR_LAT_KW
static const char * UL_X_KW
static const char * ELLIPSE_CODE_KW
static const char * DATE_YEAR_KW
static const char * CE90_ABSOLUTE_KW
static const char * TRANSLATION_X_KW
static const char * DATE_DAY_KW
static const char * TIE_POINT_XY_KW
static const char * TIE_POINT_EASTING_KW
static const char * UR_X_KW
static const char * FALSE_NORTHING_KW
static const char * LL_LON_KW
static const char * REF_IPT_LINE_KW
static const char * QUERY_KW
static const char * CREATE_OVERVIEW_KW
static const char * MAJOR_AXIS_KW
static const char * COMPRESSION_TYPE_KW
static const char * IMAGE_CE90_KW
static const char * HAS_LUT_KW
static const char * TILE_TYPE_KW
static const char * INPUT_RR_LEVEL_KW
static const char * FILL_FLAG_KW
static const char * VERTICAL_SIZE_KW
static const char * NUMBER_OUTPUT_BANDS_KW
static const char * COMPRESS_KW
static const char * BORDER_SIZE_KW
static const char * CE90_RELATIVE_KW
static const char * EXTRACT_VERTICES_KW
static const char * STD_PARALLEL_1_KW
static const char * IMAGE_FILE_SIZE_KW
static const char * FALSE_EASTING_KW
static const char * DECIMAL_DEGREES_PER_PIXEL_LON
static const char * LL_LAT_KW
static const char * REDUCED_RES_LEVEL_KW
static const char * NUMBER_BANDS_KW
static const char * MAX_ITERATIONS_KW
static const char * GEOM_FILE_KW
static const char * IMAGE_MODEL_TRANSFORM_UNIT_KW
static const char * LON_INCREMENT_KW
static const char * UL_Y_KW
static const char * FALSE_EASTING_NORTHING_KW
static const char * REF_IPT_SAMP_KW
static const char * AZIMUTH_ANGLE_KW
static const char * BANDS_KW
static const char * ENABLED_KW
static const char * TRANSLATION_Y_KW
static const char * CREATE_EXTERNAL_GEOMETRY_KW
static const char * BAND_KW
static const char * DATE_MIN_KW
static const char * DATE_SEC_KW
static const char * ORIGIN_LATITUDE_KW
static const char * ENTRY_KW
static const char * UNITS_KW
static const char * CENTRAL_POINT2_LAT_KW
static const char * THREADS_KW
static const char * DATE_KW
static const char * ELLIPSE_NAME_KW
static const char * PCS_CODE_KW
static const char * LL_X_KW
static const char * INTERLEAVE_TYPE_KW
static const char * ENABLE_CACHE_KW
static const char * CENTER_PIXEL_Y_KW
static const char * CREATE_IMAGE_KW
static const char * DESCRIPTION_KW
static const char * LAT_INCREMENT_KW
static const char * TILE_SIZE_X_KW
static const char * CENTRAL_POINT1_LON_KW
static const char * PIXEL_TYPE_KW
static const char * LL_Y_KW
static const char * COMPRESSION_QUALITY_KW
static const char * METERS_PER_PIXEL_KW
static const char * HEMISPHERE_KW
static const char * UL_LON_KW
static const char * UR_LAT_KW
static const char * UR_LON_KW
static const char * SCALAR_TYPE_KW
static const char * ID_KW
static const char * PEN_COLOR_KW
static const char * DATA_FILE_KW
static const char * ELLIPSE_EPSG_CODE_KW
static const char * TIE_POINT_LAT_KW
static const char * CONVERGENCE_THRESHOLD_KW
static const char * SCALE_FACTOR_KW
static const char * NUMBER_REDUCED_RES_SETS_KW
static const char * ELEVATION_ANGLE_KW
static const char * POINT_WIDTH_HEIGHT_KW
static const char * IMAGE_TYPE_KW
static const char * OVERVIEW_COMPRESSION_QUALITY_KW
static const char * STD_PARALLEL_2_KW
static const char * SCALE_PER_PIXEL_Y_KW
static const char * CENTRAL_POINT1_LAT_KW
static const char * OVERVIEW_STOP_DIMENSION_KW
static const char * IMAGE_FILE_KW
static const char * ELEVATION_SOURCE_KW
static const char * QUALITY_KW
static const char * FILENAME_KW
static const char * THICKNESS_KW
static const char * NUMBER_OUTPUTS_KW
static const char * ORIGIN_X_KW
static const char * METERS_PER_PIXEL_X_KW
static const char * NUMBER_SAMPLES_KW
static const char * SRS_NAME_KW
static const char * PIXEL_SCALE_UNITS_KW
static const char * TIE_POINT_UNITS_KW
static const char * OUTPUT_FILE_PREFIX_KW
