ossimFfRevc.cpp
Go to the documentation of this file.
1 //*******************************************************************
2 //
3 // License: MIT
4 //
5 // Author: Ken Melero ([email protected])
6 // Orginally written by Dave Burken ([email protected])
7 // Description: This class parses an EOSAT Fast Format rev c header.
8 //
9 //********************************************************************
10 // $Id$
11
14 #include <ossim/base/ossimNotify.h>
16 #include <ossim/base/ossimString.h>
17 #include <sstream>
18 #include <iomanip>
19
20 const int LOCATION_OFFSET [4] = { 23,
21  183,
22  343,
23  503 };
24
25 const int PATH_ROW_NUMBER_OFFSET [4] = { 34,
26  194,
27  354,
28  514 };
29
30 const int DATE_OFFSET [4] = { 70,
31  230,
32  390,
33  550 };
34
35 const int SAT_NAME_OFFSET [4] = { 91,
36  251,
37  411,
38  571 };
39
40 const int SENSOR_NAME_OFFSET [4] = { 110,
41  270,
42  430,
43  590 };
44
45 const int SENSOR_MODE_OFFSET [4] = { 134,
46  294,
47  454,
48  614 };
49
50 const int OFF_NADIR_ANGLE_OFFSET [4] = { 153,
51  313,
52  473,
53  633 };
54
55
56 const int BIAS_OFFSET [8] = { 1616,
57  1696,
58  1776,
59  1856,
60  1936,
61  2016,
62  2096,
63  2176 };
64
65 const int GAIN_OFFSET [8] = { 1641,
66  1721,
67  1801,
68  1881,
69  1961,
70  2041,
71  2121,
72  2201 };
73
74 static const int PROJ_PARAM_OFFSET [15] = { 3181,
75  3206,
76  3232,
77  3257,
78  3282,
79  3312,
80  3337,
81  3362,
82  3392,
83  3417,
84  3442,
85  3472,
86  3497,
87  3522,
88  3552 };
89
90 static const char BLANK_STRING[] = " ";
91
92 //***************************************************************************
93 // CONSTRUCTOR
94 //***************************************************************************
96  :
97  theAdminRecord(),
98  theRadiomRecord(),
99  theGeoRecord(),
100  theErrorStatus(OSSIM_OK)
101 { }
102
103 //***************************************************************************
104 // CONSTRUCTOR:
105 // ossimFfRevc::ossimFfRevc(const char* headerFile)
106 //
107 // Takes a filename representing an IRS-1C Fast Format rev C header.
108 //***************************************************************************
109 ossimFfRevc::ossimFfRevc(const char* headerFile)
110  :
111  theErrorStatus(OSSIM_OK)
112 {
113  std::shared_ptr<ossim::istream> is = ossim::StreamFactoryRegistry::instance()->
114  createIstream(ossimString(headerFile), std::ios_base::in);
115
116  if (!is)
117  {
119
120  ossimNotify(ossimNotifyLevel_FATAL) << "FATAL ossimFfRevc::ossimFfRevc(header): "
121  << "Cannot open: " << headerFile << "\n"
122  << "Returning from constructor." << std::endl;
123
124  return;
125  }
126
127  loadFromStream( *is );
128 }
129
130
131 //***************************************************************************
132 // PUBLIC METHOD:
133 // int ossimFfRevc::path(int sceneNbr) const
134 //
135 // Convenience method to parse the path from the path/row string. Returns
136 // zero if stream is not opened. Current loacation field is:
137 // path/row/fraction/subscene in ppp/rrrffss format.
138 //***************************************************************************
139 int ossimFfRevc::path(int sceneNbr) const
140 {
141  char tmpBuff[4];
142  int path = 0;
143
145
146  if (is)
147  {
148  is.get(tmpBuff, 4);
149  path = atoi(tmpBuff);
150  }
151
152  return path;
153 }
154
155
156 //***************************************************************************
157 // PUBLIC METHOD:
158 // int ossimFfRevc::row(int sceneNbr) const
159 //
160 // Convenience method to parse the row from the path/row string. Returns
161 // zero if stream is not opened. Current loacation field is:
162 // path/row/fraction/subscene in ppp/rrrffss format.
163 //***************************************************************************
164 int ossimFfRevc::row(int sceneNbr) const
165 {
166  char tmpBuff[4];
167  int row = 0;
168
170
171  if (is)
172  {
173  is.seekg(4, std::ios_base::beg);
174  is.get(tmpBuff, 4);
175  row = atoi(tmpBuff);
176  }
177
178  return row;
179 }
180
181
182 //***************************************************************************
183 // PUBLIC METHOD:
184 // int ossimFfRevc::fraction(int sceneNbr) const
185 //
186 // Convenience method to parse the fraction from the path/row string. Returns
187 // zero if stream is not opened. Current loacation field is:
188 // path/row/fraction/subscene in ppp/rrrffss format.
189 //***************************************************************************
190 int ossimFfRevc::fraction(int sceneNbr) const
191 {
192  char tmpBuff[3];
193  int fraction = 0;
194
196
197  if (is)
198  {
199  is.seekg(7, std::ios_base::beg);
200  is.get(tmpBuff, 3);
201  fraction = atoi(tmpBuff);
202  }
203
204  return fraction;
205 }
206
207
208 //***************************************************************************
209 // PUBLIC METHOD:
210 // int ossimFfRevc::subScene(int sceneNbr) const
211 //
212 // Convenience method to parse the subScene from the path/row string. Returns
213 // zero if stream is not opened. Current loacation field is:
214 // path/row/fraction/subscene in ppp/rrrffss format.
215 //***************************************************************************
217 {
218  char tmpBuff[3];
220
222
223  if (is)
224  {
225  is.seekg(9, std::ios_base::beg);
226  is.get(tmpBuff, 3);
227  subScene = tmpBuff;
228  }
229
230  return subScene;
231 }
232
233 //***************************************************************************
234 // ossimFfRevc::pathRow(int sceneNbr)
235 //***************************************************************************
237 {
238  ossimString tmp = "p";
239
240  tmp += theAdminRecord.thePathRowNumber[sceneNbr];
241
242  tmp.gsub("/", "r");
243
244  tmp.gsub(" ", "");
245
246  return tmp;
247 }
248
249 //***************************************************************************
250 // PUBLIC METHOD:
251 // void ossimFfRevc::print(ostream& os) const
252 //
253 // Prints data members.
254 //***************************************************************************
256 {
257  os << std::setiosflags(std::ios_base::left | std::ios_base::fixed)
258  << "Administrative Record:"
259  << std::setw(30) << "\ntheProductOrderNumber:"
261
262  int i;
263  for (i = 0; i < NUMBER_OF_SCENES; i++)
264  {
265  os << "\nScene" << (i + 1) << std::setw(23) << " PathRowNumber:"
267  << "\nScene" << (i + 1) << std::setw(23) << " AcquisitionDate: "
269  << "\nScene" << (i + 1) << std::setw(23) << " SatelliteName: "
271  << "\nScene" << (i + 1) << std::setw(23) << " SensorName: "
273  << "\nScene" << (i + 1) << std::setw(23) << " SensorMode: "
275  << "\nScene" << (i + 1) << std::setw(23) << " OffNadirAngle: "
276  << std::setprecision(2) << theAdminRecord.theOffNadirAngle[i];
277  }
278
279  os << std::setw(30) << "\nProductType:"
281  << std::setw(30) << "\nProductSize:"
283  << std::setw(30) << "\nProcessingType:"
285  << std::setw(30) << "\nResampAlgorithm:"
287  << std::setw(30) << "\nTapeVolumeNumber:"
289  << std::setw(30) << "\nNumberVolumesPerTape:"
291  << std::setw(30) << "\nPixelsPerLine:"
293  << std::setw(30) << "\nLinesPerImage:"
295  << std::setw(30) << "\n1stLineInVolume:"
297  << std::setw(30) << "\nTapeBlockingFactor:"
299  << std::setw(30) << "\nRecordSize:"
301  << std::setw(30) << "\nGsd:"
302  << std::setprecision(2) << theAdminRecord.theGsd
303  << std::setw(30) << "\nOutputBitsPerPixel:"
305  << std::setw(30) << "\nAcquiredBitsPerPixel:"
307  << std::setw(30) << "\nBandsPresentString:"
309  << std::setw(30) << "\nFormatVersion:"
311  << "\n"
312  << std::setw(30) << "Radiometric record:";
313
314  os << std::setprecision(15);
315
316  for (i = 0; i < NUMBER_OF_BANDS; i++)
317  {
318  os << "\nBand" << (i + 1) << std::setw(24) << " bias:"
320  << "\nBand" << (i + 1) << std::setw(24) << " gain:"
321  << theRadiomRecord.theGain[i];
322  }
323
324  os << "\n"
325  << "Geometric Record:"
326  << std::setw(30) << "\nMapProjectionName:"
328  << std::setw(30) << "\nEllipsoid:"
330  << std::setw(30) << "\nDatum:"
332
333  for (i = 0; i < 15; i++)
334  {
335  os << "\nProjectionParams[" << std::setw(2) << i << std::setw(10) << "]: "
337  }
338
339  os << std::setprecision(3)
340  << std::setw(30) << "\nUlLon:"
342  << std::setw(30) << "\nUlLat:"
344  << std::setw(30) << "\nUlEasting:"
346  << std::setw(30) << "\nUlNorthing:"
348  << std::setw(30) << "\nUrLon:"
350  << std::setw(30) << "\nUrLat:"
352  << std::setw(30) << "\nUrEasting:"
354  << std::setw(30) << "\nUrNorthing:"
356  << std::setw(30) << "\nLrLon:"
358  << std::setw(30) << "\nLrLat:"
360  << std::setw(30) << "\nLrEasting:"
362  << std::setw(30) << "\nLrNorthing:"
364  << std::setw(30) << "\nLlLon:"
366  << std::setw(30) << "\nLlLat:"
368  << std::setw(30) << "\nLlEasting:"
370  << std::setw(30) << "\nLlNorthing:"
372  << std::setw(30) << "\nCenterLon:"
374  << std::setw(30) << "\nCenterLat:"
376  << std::setw(30) << "\nCenterEasting:"
378  << std::setw(30) << "\nCenterNorthing:"
380  << std::setw(30) << "\nCenterSample:"
382  << std::setw(30) << "\nCenterLine:"
384  << std::setw(30) << "\nHorizontalOffset:"
386  << std::setprecision(2) << std::setw(30) << "\nOrientationAngle:"
388  << std::setw(30) << "\nSunElevationAngle:"
389  << std::setprecision(1) << theGeoRecord.theSunElevationAngle
390  << std::setw(30) << "\nSunAzimuth:" << theGeoRecord.theSunAzimuth
391  << std::resetiosflags(std::ios_base::left)
392  << "\n\n";
393
394 }
395
396 //***************************************************************************
397 // PUBLIC METHOD:
398 // void ossimFfRevc::write(ostream& os) const
399 //
400 // Writes data members in EOSAT Fast Format Rev C format.
401 //***************************************************************************
403 {
404  const char PRODUCT_ID_DESC [PRODUCT_ORDER_NUMBER_DESC_SIZE + 1]
405  = "PRODUCT ID =";
406
407  const char LOCATION_DESC [LOCATION_DESC_SIZE + 1]
408  = " LOCATION =";
409
410  const char DATE_DESC [DATE_DESC_SIZE + 1]
411  = " ACQUISITION DATE =";
412
413  const char SATELLITE_NAME_DESC [SAT_NAME_DESC_SIZE + 1]
414  = "SATELLITE =";
415
416  const char SENSOR_NAME_DESC [SENSOR_NAME_DESC_SIZE + 1]
417  = " SENSOR =";
418
419  const char SENSOR_MODE_DESC [SENSOR_MODE_DESC_SIZE + 1]
420  = " SENSOR MODE =";
421
422  const char LOOK_ANGLE_DESC [LOOK_ANGLE_DESC_SIZE + 1]
423  = " LOOK ANGLE =";
424
425  const char PRODUCT_TYPE_DESC [PRODUCT_TYPE_DESC_SIZE + 1]
426  = "PRODUCT TYPE =";
427
428  const char PRODUCT_SIZE_DESC [PRODUCT_SIZE_DESC_SIZE + 1]
429  = " PRODUCT SIZE =";
430
431  const char PROCESSING_TYPE_DESC [PROCESSING_TYPE_DESC_SIZE + 1]
432  = "TYPE OF PROCESSING =";
433
434  const char RESAMPLING_ALGO_DESC [RESAMPLING_ALGO_DESC_SIZE + 1]
435  = " RESAMPLING =";
436
437  const char TAPE_VOLUME_NUMBER_DESC [TAPE_VOLUME_NUMBER_DESC_SIZE + 1]
438  = "VOLUME #/# IN SET =";
439
440  const char PIXELS_PER_LINE_DESC [PIXELS_PER_LINE_DESC_SIZE + 1]
441  = " PIXELS PER LINE =";
442
443  const char LINES_PER_IMAGE_DESC [LINES_PER_IMAGE_DESC_SIZE + 1]
444  = " LINES PER BAND =";
445
446  const char FIRST_LINE_DESC [FIRST_LINE_DESC_SIZE + 1]
447  = "START LINE # =";
448
449  const char BLOCKING_FACTOR_DESC [BLOCKING_FACTOR_DESC_SIZE + 1]
450  = " BLOCKING FACTOR =";
451
452  const char RECORD_LENGTH_DESC [RECORD_LENGTH_DESC_SIZE + 1]
453  = " RECORD LENGTH =";
454
455  const char PIXEL_GSD_DESC [PIXEL_GSD_DESC_SIZE + 1]
456  = " PIXEL SIZE =";
457
458  const char BITS_PER_PIXEL_DESC [BITS_PER_PIXEL_DESC_SIZE + 1]
459  = "OUTPUT BITS PER PIXEL =";
460
461  const char AQUIRED_BITS_PER_PIXEL_DESC
462  [AQUIRED_BITS_PER_PIXEL_DESC_SIZE + 1] = " ACQUIRED BITS PER PIXEL =";
463
464  const char BANDS_PRESENT_DESC [BANDS_PRESENT_DESC_SIZE + 1]
465  = "BANDS PRESENT =";
466
467  const char REV_DESC [REV_DESC_SIZE + 1]
468  = "REV ";
469
470  const char BIAS_GAIN_DESC [BIAS_GAIN_DESC_SIZE + 1]
471  = "BIASES AND GAINS IN THE BAND ORDER AS ON THIS TAPE";
472
473  const char GEO_DESC [GEO_DESC_SIZE + 1]
474  = "GEOMETRIC DATA";
475
476  const char MAP_PROJECTION_NAME_DESC [MAP_PROJECTION_NAME_DESC_SIZE + 1]
477  = " MAP PROJECTION =";
478
479  const char ELLIPSOID_DESC [ELLIPSOID_DESC_SIZE + 1]
480  = " ELLIPSOID =";
481
482  const char DATUM_DESC [DATUM_DESC_SIZE + 1]
483  = " DATUM =";
484
485  const char PROJECTION_PARAMETER_DESC [PROJECTION_PARAMETER_DESC_SIZE + 1]
486  = "USGS PROJECTION PARAMETERS =";
487
488  const char UL_DESC [CORNER_DESC_SIZE + 1]
489  = "UL =";
490
491  const char UR_DESC [CORNER_DESC_SIZE + 1]
492  = "UR =";
493
494  const char LR_DESC [CORNER_DESC_SIZE + 1]
495  = "LR =";
496
497  const char LL_DESC [CORNER_DESC_SIZE + 1]
498  = "LL =";
499
500  const char CENTER_DESC [CENTER_DESC_SIZE + 1]
501  = "CENTER =";
502
503  const char HORIZONTAL_OFFSET_DESC [HORIZONTAL_OFFSET_DESC_SIZE + 1]
504  = "OFFSET =";
505
506  const char ORIENTATION_ANGLE_DESC [ORIENTATION_ANGLE_DESC_SIZE + 1]
507  = " ORIENTATION ANGLE =";
508
509  const char SUN_ELEVATION_DESC [SUN_ELEVATION_DESC_SIZE + 1]
510  = "SUN ELEVATION ANGLE =";
511
512  const char SUN_AZIMUTH_DESC [SUN_AZIMUTH_DESC_SIZE + 1]
513  = " SUN AZIMUTH ANGLE =";
514
515  const char SPACE[] = " ";
516
517  //>
518  // NOTE: "seekp's" will be perormed as needed for safety.
519  //<
520
521  //>
522  // Start at beginning of the stream.
523  //<
524  os.seekp(0, std::ios_base::beg);
525
526  //>
527  // Start of administrative record.
528  //<
529
530  os << std::setiosflags(std::ios_base::fixed) // Disable scientific mode.
531
532  << PRODUCT_ID_DESC
533
534  << std::setw(PRODUCT_ORDER_NUMBER_SIZE)
536
537  //>
538  // The admin record can contain info for up to four scenes.
539  //<
540
541  int i;
542  for (i = 0; i < 4; i++)
543  {
544  os.seekp(LOCATION_OFFSET[i], std::ios_base::beg);
545
546  os << LOCATION_DESC
547
548  << std::setw(PATH_ROW_NUMBER_SIZE)
550
551  << DATE_DESC
552
553  << std::setw(DATE_SIZE)
555
556  << std::setw(1) << SPACE << "\n" // End of line.
557
558  << SATELLITE_NAME_DESC // Start of line.
559
560  << std::setw(SAT_NAME_SIZE)
562
563  << SENSOR_NAME_DESC
564
565  << std::setw(SENSOR_NAME_SIZE)
567
568  << SENSOR_MODE_DESC
569
570  << std::setw(SENSOR_MODE_SIZE)
572
573  << LOOK_ANGLE_DESC
574
575  << std::setw(OFF_NADIR_ANGLE_SIZE)
576  << std::setiosflags(std::ios_base::right)
577  << std::setprecision(2)
578  << theAdminRecord.theOffNadirAngle[i] // End of scene.
579  << std::resetiosflags(std::ios_base::right)
580  << "\n"
581  << std::setw(23) << SPACE; // End of line.
582  } // End of scene loop.
583
584  os.seekp(640, std::ios_base::beg); // Start of line.
585
586  os << PRODUCT_TYPE_DESC
587
588  << std::setiosflags(std::ios_base::left)
589
590  << std::setw(PRODUCT_TYPE_SIZE)
592
593  << PRODUCT_SIZE_DESC
594
595  << std::setw(PRODUCT_SIZE_SIZE)
597
598  << std::setw(22) << SPACE << "\n"; // End of line.
599
600  os.seekp(720, std::ios_base::beg);
601
602  os << PROCESSING_TYPE_DESC
603
604  << std::setw(PROCESSING_TYPE_SIZE)
606
607  << RESAMPLING_ALGO_DESC
608
609  << std::setw(RESAMPLING_ALGO_SIZE)
611
612  << std::resetiosflags(std::ios_base::left)
613
614  << std::setw(33) << SPACE << "\n"; // End of line.
615
616  os.seekp(800, std::ios_base::beg); // Start of line.
617
618  os << TAPE_VOLUME_NUMBER_DESC
619
620  << std::setiosflags(std::ios_base::right)
621
622  << std::setw(TAPE_VOLUME_NUMBER_SIZE)
624  << "/" << std::setw(VOLUMES_PER_TAPE_SIZE)
626
627  << PIXELS_PER_LINE_DESC
628
629  << std::setw(PIXELS_PER_LINE_SIZE)
631
632  << LINES_PER_IMAGE_DESC
633
634  << std::setw(LINES_PER_IMAGE_SIZE)
636
637  << "/"
638
639  << std::setw(LINES_PER_IMAGE_SIZE)
641
642  << std::setw(4) << SPACE << "\n"; // End of line.
643
644  os.seekp(880, std::ios_base::beg); // Start of line.
645
646  os << std::setiosflags(std::ios_base::right)
647
648  << FIRST_LINE_DESC
649
650  << std::setw(LINES_PER_IMAGE_SIZE)
652
653  << BLOCKING_FACTOR_DESC
654
655  << std::setw(BLOCKING_FACTOR_SIZE)
657
658  << RECORD_LENGTH_DESC
659
660  << std::setw(RECORD_LENGTH_SIZE)
662
663  << PIXEL_GSD_DESC
664
665
666  << std::setw(PIXEL_GSD_SIZE)
667  << std::setprecision(2)
669
670  << "\n"; // End of line.
671
672  os.seekp(960, std::ios_base::beg); // Start of line.
673
674  os << BITS_PER_PIXEL_DESC
675
676  << std::setw(BITS_PER_PIXEL_SIZE)
678
679  << AQUIRED_BITS_PER_PIXEL_DESC
680
681  << std::setw(BITS_PER_PIXEL_SIZE)
683
684  << std::resetiosflags(std::ios_base::right)
685
686  << std::setw(26) << SPACE << "\n"; // End of line.
687
688  os.seekp(1040, std::ios_base::beg); // Start of line.
689
690  os << BANDS_PRESENT_DESC
691
692  << std::setw(BANDS_PRESENT_SIZE)
694
695  << std::setw(31) << SPACE << "\n" // End of line.
696  << std::setw(79) << SPACE << "\n"
697  << std::setw(79) << SPACE << "\n"
698  << std::setw(79) << SPACE << "\n"
699  << std::setw(79) << SPACE << "\n"
700  << std::setw(79) << SPACE << "\n";
701
702  os.seekp(1520, std::ios_base::beg);
703
704  os << REV_DESC
705
706  << std::setw(FORMAT_VERSION_SIZE)
708
709  //***
710  // End of administrative record(bytes 0 to 1535).
711  //***
712
713  //***
714  // Beginning of radiometric record.
715  //***
716
717  os.seekp(1536, std::ios_base::beg);
718
719  os << BIAS_GAIN_DESC
720
721  << std::setw(29) << SPACE << "\n";
722
723  //***
724  // Loop through the bands and get write out the bias and gain for each
725  // band.
726  //***
727
728  os << std::resetiosflags(std::ios_base::left) << std::setiosflags(std::ios_base::right);
729
730  for (i = 0; i < 8; i++)
731  {
732  os.seekp(BIAS_OFFSET[i], std::ios_base::beg);
733
734  os << std::setprecision(15)
735
736  << std::setw(BIAS_SIZE)
738
739  << SPACE
740
741  << std::setw(GAIN_SIZE)
743
744  << std::setw(30) << SPACE << "\n";
745  } // End of loop through the bands.
746
747  os << std::resetiosflags(std::ios_base::right);
748
749  os.seekp(2256, std::ios_base::beg);
750
751  os << std::setw(79) << SPACE << "\n";
752  os << std::setw(79) << SPACE << "\n";
753  os << std::setw(79) << SPACE << "\n";
754  os << std::setw(79) << SPACE << "\n";
755  os << std::setw(79) << SPACE << "\n";
756  os << std::setw(79) << SPACE << "\n";
757  os << std::setw(79) << SPACE << "\n";
758  os << std::setw(79) << SPACE << "\n";
759  os << std::setw(79) << SPACE << "\n";
760  os << std::setw(79) << SPACE << "\n";
761  os << std::setw(15) << SPACE << "\n";
762
763  //***
764  // End of radiometric record(bytes 1536 to 3071).
765  //***
766
767  //**
768  // Start of geometric record(bytes 3072 to 4607).
769  //***
770
771  os.seekp(3072, std::ios_base::beg); // Start of record.
772
773  os << GEO_DESC
774
775  << MAP_PROJECTION_NAME_DESC
776
777  << std::setiosflags(std::ios_base::left) // Alpha fields left justified.
778
779  << std::setw(MAP_PROJECTION_NAME_SIZE)
781
782  << ELLIPSOID_DESC // Looks like this has changed.
783
784  << std::setw(ELLIPSOID_SIZE)
786
787  << DATUM_DESC
788
789  << std::setw(DATUM_SIZE)
791
792  << std::resetiosflags(std::ios_base::left)
793
794  << "\n" // End of line
795
796  << PROJECTION_PARAMETER_DESC
797  << SPACE;
798
799  os.seekp(PROJ_PARAM_OFFSET[0], std::ios_base::beg);
800  os << std::setprecision(15)
801  << std::setiosflags(std::ios_base::right)
802
803  << std::setw(PROJECTION_PARAMETER_SIZE)
805  << SPACE;
806
807  os.seekp(PROJ_PARAM_OFFSET[1], std::ios_base::beg);
808  os << std::setw(PROJECTION_PARAMETER_SIZE)
810  << std::setw(1) << SPACE << "\n";
811
812  //***
813  // Code is duplicated every three projection parameter four times;
814  // hence, the double loop.
815  //***
816  for (i = 0; i < 4; i++)
817  {
818  for (int j = i * 3 + 2; j < (i * 3) + 5; j++)
819  {
820  os.seekp(PROJ_PARAM_OFFSET[j], std::ios_base::beg);
821
822  os << std::setw(PROJECTION_PARAMETER_SIZE)
824  << std::setw(1) << SPACE;
825
826  os.seekp(PROJ_PARAM_OFFSET[j], std::ios_base::beg);
827  os << std::setw(PROJECTION_PARAMETER_SIZE)
829  << std::setw(1) << SPACE;
830
831  os.seekp(PROJ_PARAM_OFFSET[j], std::ios_base::beg);
832  os << std::setw(PROJECTION_PARAMETER_SIZE)
834  << std::setw(5) << SPACE << "\n";
835  }
836  }
837
838  os.seekp(PROJ_PARAM_OFFSET[14], std::ios_base::beg);
839  os << std::setw(PROJECTION_PARAMETER_SIZE)
841  << std::setw(55) << SPACE << "\n" << std::resetiosflags(std::ios_base::right);
842
843
844  os.seekp(3632, std::ios_base::beg);
845  os << UL_DESC
846
847  << SPACE
848
849  << std::setw(LON_SIZE) << theGeoRecord.theUlLon
850
851  << SPACE
852
853  << std::setw(LAT_SIZE) << theGeoRecord.theUlLat
854
855  << SPACE
856
857  << std::setprecision(3)
858
859  << std::setw(EASTING_SIZE) << std::setiosflags(std::ios_base::right)
861
862  << SPACE
863
864  << std::setw(NORTHING_SIZE)
866
867  << std::setw(20) << SPACE << "\n" << std::resetiosflags(std::ios_base::right);
868
869
870  os.seekp(3712, std::ios_base::beg);
871  os << UR_DESC
872
873  << SPACE
874
875  << std::setw(LON_SIZE) << theGeoRecord.theUrLon
876
877  << SPACE
878
879  << std::setw(LAT_SIZE) << theGeoRecord.theUrLat
880
881  << SPACE
882
883  << std::setw(EASTING_SIZE) << std::setiosflags(std::ios_base::right)
885
886  << SPACE
887
888  << std::setw(NORTHING_SIZE)
890
891  << std::setw(20) << SPACE << "\n" << std::resetiosflags(std::ios_base::right);
892
893
894  os.seekp(3792, std::ios_base::beg);
895  os << LR_DESC
896
897  << SPACE
898
899  << std::setw(LON_SIZE) << theGeoRecord.theLrLon
900
901  << SPACE
902
903  << std::setw(LAT_SIZE) << theGeoRecord.theLrLat
904
905  << SPACE
906
907  << std::setw(EASTING_SIZE) << std::setiosflags(std::ios_base::right)
909
910  << SPACE
911
912  << std::setw(NORTHING_SIZE)
914
915  << std::setw(20) << SPACE << "\n" << std::resetiosflags(std::ios_base::right);
916
917
918  os.seekp(3872, std::ios_base::beg);
919  os << LL_DESC
920
921  << SPACE
922
923  << std::setw(LON_SIZE) << theGeoRecord.theLlLon
924
925  << SPACE
926
927  << std::setw(LAT_SIZE) << theGeoRecord.theLlLat
928
929  << SPACE
930
931  << std::setw(EASTING_SIZE) << std::setiosflags(std::ios_base::right)
933
934  << SPACE
935
936  << std::setw(NORTHING_SIZE)
938
939  << std::setw(20) << SPACE << "\n" << std::resetiosflags(std::ios_base::right);
940
941  os.seekp(3952, std::ios_base::beg);
942  os << CENTER_DESC
943
944  << SPACE
945
946  << std::setw(LON_SIZE)
948
949  << SPACE
950
951  << std::setw(LAT_SIZE)
953
954  << SPACE
955
956  << std::setw(EASTING_SIZE) << std::setiosflags(std::ios_base::right)
958
959  << SPACE
960
961  << std::setw(NORTHING_SIZE)
963
964  << SPACE
965
966  << std::setw(CENTER_SAMPLE_SIZE)
968
969  << SPACE
970
971  << std::setw(CENTER_LINE_SIZE)
973
974  << std::setw(4) << SPACE << "\n";
975
976  os.seekp(4032, std::ios_base::beg);
977  os << HORIZONTAL_OFFSET_DESC
978
979  << std::setw(HORIZONTAL_OFFSET_SIZE)
981
982  << ORIENTATION_ANGLE_DESC
983
984  << std::setw(ORIENTATION_ANGLE_SIZE)
985  << std::setprecision(2)
987
988  << std::setw(39) << SPACE << "\n"; // 41 in spec
989
990  os.seekp(4112, std::ios_base::beg);
991  os << SUN_ELEVATION_DESC
992
993  << std::setw(SUN_ELEVATION_SIZE)
994  << std::setprecision(1)
996
997  << SUN_AZIMUTH_DESC
998
999  << std::setw(SUN_AZIMUTH_SIZE)
1000  << std::setprecision(1)
1001  << theGeoRecord.theSunAzimuth // End of data.
1002
1003  << std::setw(29) << SPACE << "\n"
1004  << std::setw(79) << SPACE << "\n"
1005  << std::setw(79) << SPACE << "\n"
1006  << std::setw(79) << SPACE << "\n"
1007  << std::setw(79) << SPACE << "\n"
1008  << std::setw(79) << SPACE << "\n"
1009  << std::setw(15) << SPACE << "\n" << std::flush; // ? size
1010
1011  //***
1012  // End of geometric record(bytes 3072 to 4607).
1013  //***
1014
1015 }
1016
1017
1018 //***************************************************************************
1019 // PRIVATE METHOD:
1020 // ossimFfRevc::loadFromStream(istream& is)
1021 //***************************************************************************
1023 {
1024  //***
1025  // See .h for enumerations for field sizes and offsets.
1026  //***
1027
1028  //***
1029  // NOTE: Because of header inconsistencies all seeks will be relative to
1030  // the beginning of the stream.
1031  //***
1032
1033  //***
1034  // Temporary buffer for fields that need to be converted to integers or
1035  // floats.
1036  //***
1037
1038  char tmpBuff[25];
1039
1040  //***
1041  // Start of administrative record.
1042  //***
1043
1044  is.seekg(PRODUCT_ORDER_NUMBER_OFFSET, std::ios_base::beg);
1045
1048  ' ');
1049
1050  if (checkStream(is)) return;
1051
1052  //***
1053  // Loop through the four scenes and get the data.
1054  //***
1055
1056  int i;
1057  for (i = 0; i < NUMBER_OF_SCENES; i++)
1058  {
1059
1060  is.seekg(PATH_ROW_NUMBER_OFFSET[i], std::ios_base::beg);
1061
1063
1064  if (checkStream(is)) return;
1065
1066  is.seekg(DATE_OFFSET[i], std::ios_base::beg);
1067
1069
1070  if (checkStream(is)) return;
1071
1072  is.seekg(SAT_NAME_OFFSET[i], std::ios_base::beg);
1073
1074  is.get(theAdminRecord.theSatName[i], SAT_NAME_SIZE + 1);
1075
1076  if (checkStream(is)) return;
1077
1078  is.seekg(SENSOR_NAME_OFFSET[i], std::ios_base::beg);
1079
1081
1082  if (checkStream(is)) return;
1083
1084  is.seekg(SENSOR_MODE_OFFSET[i], std::ios_base::beg);
1085
1087
1088  if (checkStream(is)) return;
1089
1090  is.seekg(OFF_NADIR_ANGLE_OFFSET[i], std::ios_base::beg);
1091
1092  is.get(tmpBuff, OFF_NADIR_ANGLE_SIZE + 1);
1093
1094  if (checkStream(is)) return;
1095
1096  theAdminRecord.theOffNadirAngle[i] = atof(tmpBuff);
1097
1098  } // End of scene loop.
1099
1100  is.seekg(PRODUCT_TYPE_OFFSET, std::ios_base::beg);
1101
1103
1104  if (checkStream(is)) return;
1105
1106  is.seekg(PRODUCT_SIZE_OFFSET, std::ios_base::beg);
1107
1109
1110  if (checkStream(is)) return;
1111
1112  is.seekg(PROCESSING_TYPE_OFFSET, std::ios_base::beg);
1113
1115
1116  if (checkStream(is)) return;
1117
1118  is.seekg(RESAMPLING_ALGO_OFFSET, std::ios_base::beg);
1119
1121
1122  if (checkStream(is)) return;
1123
1124  is.seekg(TAPE_VOLUME_NUMBER_OFFSET, std::ios_base::beg);
1125
1126  is.get(tmpBuff, TAPE_VOLUME_NUMBER_SIZE + 1, '/');
1127
1128  if (checkStream(is)) return;
1129
1130  theAdminRecord.theTapeVolumeNumber = atoi(tmpBuff);
1131
1132  is.seekg(VOLUMES_PER_TAPE_OFFSET, std::ios_base::beg);
1133
1134  is.get(tmpBuff, VOLUMES_PER_TAPE_SIZE + 1);
1135
1136  if (checkStream(is)) return;
1137
1138  theAdminRecord.theNumberVolumesPerTape = atoi(tmpBuff);
1139
1140  is.seekg(PIXELS_PER_LINE_OFFSET, std::ios_base::beg);
1141
1142  is.get(tmpBuff, PIXELS_PER_LINE_SIZE + 1);
1143
1144  if (checkStream(is)) return;
1145
1146  theAdminRecord.thePixelsPerLine = atoi(tmpBuff);
1147
1148  is.seekg(LINES_PER_IMAGE_OFFSET, std::ios_base::beg);
1149
1150  is.get(tmpBuff, LINES_PER_IMAGE_SIZE + 1);
1151
1152  if (checkStream(is)) return;
1153
1154  theAdminRecord.theLinesPerImage = atoi(tmpBuff);
1155
1156  is.seekg(FIRST_LINE_IN_VOLUME_OFFSET, std::ios_base::beg);
1157
1158  is.get(tmpBuff, FIRST_LINE_IN_VOLUME_SIZE + 1);
1159
1160  if (checkStream(is)) return;
1161
1162  theAdminRecord.the1stLineInVolume = atoi(tmpBuff);
1163
1164  is.seekg(BLOCKING_FACTOR_OFFSET, std::ios_base::beg);
1165
1166  is.get(tmpBuff, BLOCKING_FACTOR_SIZE + 1);
1167
1168  if (checkStream(is)) return;
1169
1170  theAdminRecord.theTapeBlockingFactor = atoi(tmpBuff);
1171
1172  is.seekg(RECORD_LENGTH_OFFSET, std::ios_base::beg);
1173
1174  is.get(tmpBuff, RECORD_LENGTH_SIZE + 1);
1175
1176  if (checkStream(is)) return;
1177
1178  theAdminRecord.theRecordSize = atoi(tmpBuff);
1179
1180  is.seekg(PIXEL_GSD_OFFSET, std::ios_base::beg);
1181
1182  is.get(tmpBuff, PIXEL_GSD_SIZE + 1);
1183
1184  if (checkStream(is)) return;
1185
1186  theAdminRecord.theGsd = atof(tmpBuff);
1187
1188  is.seekg(BITS_PER_PIXEL_OFFSET, std::ios_base::beg);
1189
1190  is.get(tmpBuff, BITS_PER_PIXEL_SIZE + 1);
1191
1192  if (checkStream(is)) return;
1193
1194  theAdminRecord.theOutputBitsPerPixel = atoi(tmpBuff);
1195
1196  is.seekg(ACQUIRED_BITS_PER_PIXEL_OFFSET, std::ios_base::beg);
1197
1198  is.get(tmpBuff, BITS_PER_PIXEL_SIZE + 1);
1199
1200  if (checkStream(is)) return;
1201
1202  theAdminRecord.theAcquiredBitsPerPixel = atoi(tmpBuff);
1203
1204  is.seekg(BANDS_PRESENT_OFFSET, std::ios_base::beg);
1205
1207
1208  if (checkStream(is)) return;
1209
1210  is.seekg(FORMAT_VERSION_OFFSET, std::ios_base::beg);
1211
1213
1214  if (checkStream(is)) return;
1215  //***
1216  // End of administrative record.
1217  //***
1218
1219  //***
1220  // Start of radiometric record.
1221  //***
1222
1223  for (i = 0; i < NUMBER_OF_BANDS; i++)
1224  {
1225  is.seekg(BIAS_OFFSET[i], std::ios_base::beg);
1226
1227  is.get(tmpBuff, BIAS_SIZE + 1);
1228
1229  if (checkStream(is)) return;
1230
1231  theRadiomRecord.theBias[i] = atof(tmpBuff);
1232
1233  is.seekg(GAIN_OFFSET[i], std::ios_base::beg);
1234
1235  is.get(tmpBuff, GAIN_SIZE + 1);
1236
1237  if (checkStream(is)) return;
1238
1239  theRadiomRecord.theGain[i] = atof(tmpBuff);
1240  }
1241  //***
1242  // End of radiometric record.
1243  //***
1244
1245  //***
1246  // Start of geometric record.
1247  //***
1248
1249  is.seekg(MAP_PROJECTION_NAME_OFFSET, std::ios_base::beg);
1250
1252
1253  if (checkStream(is)) return;
1254
1255  is.seekg(ELLIPSOID_OFFSET, std::ios_base::beg);
1256
1258
1259  if (checkStream(is)) return;
1260
1261  is.seekg(DATUM_OFFSET, std::ios_base::beg);
1262
1263  is.get(theGeoRecord.theDatum, DATUM_SIZE + 1, ' ');
1264
1265  if (checkStream(is)) return;
1266
1267  //***
1268  // Get the fifteen projection parameters.
1269  //***
1270
1271  for(i = 0; i < 15; i++)
1272  {
1273  is.seekg(PROJ_PARAM_OFFSET[i], std::ios_base::beg);
1274
1275  is.get(tmpBuff, PROJECTION_PARAMETER_SIZE + 1);
1276
1277  if (checkStream(is)) return;
1278
1279  theGeoRecord.theProjectionParams[i] = atof(tmpBuff);
1280  }
1281
1282  //***
1283  // Start of upper left data: longitude, latitude, easting, and northing.
1284  //***
1285  is.seekg(UL_LON_OFFSET, std::ios_base::beg);
1286
1287  is.get(theGeoRecord.theUlLon, LON_SIZE + 1);
1288
1289  if (checkStream(is)) return;
1290
1291  is.seekg(UL_LAT_OFFSET, std::ios_base::beg);
1292
1293  is.get(theGeoRecord.theUlLat, LAT_SIZE + 1);
1294
1295  if (checkStream(is)) return;
1296
1297  is.seekg(UL_EASTING_OFFSET, std::ios_base::beg);
1298
1299  is.get(tmpBuff, EASTING_SIZE + 1);
1300
1301  if (checkStream(is)) return;
1302
1303  theGeoRecord.theUlEasting = atof(tmpBuff);
1304
1305  is.seekg(UL_NORTHING_OFFSET, std::ios_base::beg);
1306
1307  is.get(tmpBuff, NORTHING_SIZE + 1);
1308
1309  if (checkStream(is)) return;
1310
1311  theGeoRecord.theUlNorthing = atof(tmpBuff);
1312
1313  //***
1314  // End of upper left data.
1315  //***
1316
1317  //***
1318  // Start of upper right data: longitude, latitude, easting, and northing.
1319  //***
1320  is.seekg(UR_LON_OFFSET, std::ios_base::beg);
1321
1322  is.get(theGeoRecord.theUrLon, LON_SIZE + 1);
1323
1324  if (checkStream(is)) return;
1325
1326  is.seekg(UR_LAT_OFFSET, std::ios_base::beg);
1327
1328  is.get(theGeoRecord.theUrLat, LAT_SIZE + 1);
1329
1330  if (checkStream(is)) return;
1331
1332  is.seekg(UR_EASTING_OFFSET, std::ios_base::beg);
1333
1334  is.get(tmpBuff, EASTING_SIZE + 1);
1335
1336  if (checkStream(is)) return;
1337
1338  theGeoRecord.theUrEasting = atof(tmpBuff);
1339
1340  is.seekg(UR_NORTHING_OFFSET, std::ios_base::beg);
1341
1342  is.get(tmpBuff, NORTHING_SIZE + 1);
1343
1344  if (checkStream(is)) return;
1345
1346  theGeoRecord.theUrNorthing = atof(tmpBuff);
1347
1348  //***
1349  // End of upper right data.
1350  //***
1351
1352  //***
1353  // Start of lower right data: longitude, latitude, easting, and northing.
1354  //***
1355  is.seekg(LR_LON_OFFSET, std::ios_base::beg);
1356
1357  is.get(theGeoRecord.theLrLon, LON_SIZE + 1);
1358
1359  if (checkStream(is)) return;
1360
1361  is.seekg(LR_LAT_OFFSET, std::ios_base::beg);
1362
1363  is.get(theGeoRecord.theLrLat, LAT_SIZE + 1);
1364
1365  if (checkStream(is)) return;
1366
1367  is.seekg(LR_EASTING_OFFSET, std::ios_base::beg);
1368
1369  is.get(tmpBuff, EASTING_SIZE + 1);
1370
1371  if (checkStream(is)) return;
1372
1373  theGeoRecord.theLrEasting = atof(tmpBuff);
1374
1375  is.seekg(LR_NORTHING_OFFSET, std::ios_base::beg);
1376
1377  is.get(tmpBuff, NORTHING_SIZE + 1);
1378
1379  if (checkStream(is)) return;
1380
1381  theGeoRecord.theLrNorthing = atof(tmpBuff);
1382
1383  //***
1384  // End of lower right data.
1385  //***
1386
1387  //***
1388  // Start of lower left data: longitude, latitude, easting, and northing.
1389  //***
1390  is.seekg(LL_LON_OFFSET, std::ios_base::beg);
1391
1392  is.get(theGeoRecord.theLlLon, LON_SIZE + 1);
1393
1394  if (checkStream(is)) return;
1395
1396  is.seekg(LL_LAT_OFFSET, std::ios_base::beg);
1397
1398  is.get(theGeoRecord.theLlLat, LAT_SIZE + 1);
1399
1400  if (checkStream(is)) return;
1401
1402  is.seekg(LL_EASTING_OFFSET, std::ios_base::beg);
1403
1404  is.get(tmpBuff, EASTING_SIZE + 1);
1405
1406  if (checkStream(is)) return;
1407
1408  theGeoRecord.theLlEasting = atof(tmpBuff);
1409
1410  is.seekg(LL_NORTHING_OFFSET, std::ios_base::beg);
1411
1412  is.get(tmpBuff, NORTHING_SIZE + 1);
1413
1414  if (checkStream(is)) return;
1415
1416  theGeoRecord.theLlNorthing = atof(tmpBuff);
1417
1418  //***
1419  // End of lower left data.
1420  //***
1421
1422  //***
1423  // Start of scene center data: longitude, latitude, easting, northing,
1424  // sample, line.
1425  //***
1426  is.seekg(CENTER_LON_OFFSET, std::ios_base::beg);
1427
1428  is.get(theGeoRecord.theCenterLon, LON_SIZE + 1);
1429
1430  if (checkStream(is)) return;
1431
1432  is.seekg(CENTER_LAT_OFFSET, std::ios_base::beg);
1433
1434  is.get(theGeoRecord.theCenterLat, LAT_SIZE + 1);
1435
1436  if (checkStream(is)) return;
1437
1438  is.seekg(CENTER_EASTING_OFFSET, std::ios_base::beg);
1439
1440  is.get(tmpBuff, EASTING_SIZE + 1);
1441
1442  if (checkStream(is)) return;
1443
1444  theGeoRecord.theCenterEasting = atof(tmpBuff);
1445
1446  is.seekg(CENTER_NORTHING_OFFSET, std::ios_base::beg);
1447
1448  is.get(tmpBuff, NORTHING_SIZE + 1);
1449
1450  if (checkStream(is)) return;
1451
1452  theGeoRecord.theCenterNorthing = atof(tmpBuff);
1453
1454  is.seekg(CENTER_SAMPLE_OFFSET, std::ios_base::beg);
1455
1456  is.get(tmpBuff, CENTER_SAMPLE_SIZE + 1);
1457
1458  if (checkStream(is)) return;
1459
1460  theGeoRecord.theCenterSample = atoi(tmpBuff);
1461
1462  is.seekg(CENTER_LINE_OFFSET, std::ios_base::beg);
1463
1464  is.get(tmpBuff, CENTER_LINE_SIZE + 1);
1465
1466  if (checkStream(is)) return;
1467
1468  theGeoRecord.theCenterLine = atoi(tmpBuff);
1469
1470  //***
1471  // End of scene center data.
1472  //***
1473
1474  is.seekg(HORIZONTAL_OFFSET_OFFSET, std::ios_base::beg);
1475
1476  is.get(tmpBuff, HORIZONTAL_OFFSET_SIZE + 1);
1477
1478  if (checkStream(is)) return;
1479
1480  theGeoRecord.theHorizontalOffset = atoi(tmpBuff);
1481
1482  is.seekg(ORIENTATION_ANGLE_OFFSET, std::ios_base::beg);
1483
1484  is.get(tmpBuff, ORIENTATION_ANGLE_SIZE + 1);
1485
1486  if (checkStream(is)) return;
1487
1488  theGeoRecord.theOrientationAngle = atof(tmpBuff);
1489
1490  is.seekg(SUN_ELEVATION_OFFSET, std::ios_base::beg);
1491
1492  is.get(tmpBuff, SUN_ELEVATION_SIZE + 1);
1493
1494  if (checkStream(is)) return;
1495
1496  theGeoRecord.theSunElevationAngle = atof(tmpBuff);
1497
1498  is.seekg(SUN_AZIMUTH_OFFSET, std::ios_base::beg);
1499
1500  is.get(tmpBuff, SUN_AZIMUTH_SIZE + 1);
1501
1502  if (checkStream(is)) return;
1503
1504  theGeoRecord.theSunAzimuth = atof(tmpBuff);
1505
1506  //***
1507  // End of geometric record.
1508  //***
1509
1510 }
1511
1512 //***************************************************************************
1513 // PRIVATE METHOD:
1514 // ossimFfRevc::checkStream(istream& is)
1515 //
1516 // Checks the stream. If an error has occurred it sets theErrorStatus.
1517 // Returns: theErrorStatus ( 0 = OK, 1 = ERROR )
1518 //***************************************************************************
1520 {
1521  //***
1522  // istreams set fault bits and the operator! is overloaded to return
1523  // true if an error has occurred.
1524  //***
1525
1526  if (!is)
1527  {
1529
1530  ossimNotify(ossimNotifyLevel_FATAL) << "FATAL ossimFfRevc::checkStream: "
1531  << "Stream corrupted. Returning from method."
1532  << std::endl;
1533  }
1534
1535  return theErrorStatus;
1536 }
1537
1538 //***************************************************************************
1539 // Function:
1540 // ostream& operator<<(ostream& os, const ossimFfRevc& head)
1541 //***************************************************************************
1543 {
1544  head.print(os);
1545
1546  return os;
1547 }
1548
1549 //***************************************************************************
1550 // CONSTRUCTOR:
1551 // ossimFfRevc::AdminRecord::AdminRecord()
1552 //
1553 // Default constructor for AdminRecord nested class:
1554 //***************************************************************************
1556  :
1557  theTapeVolumeNumber(1),
1558  theNumberVolumesPerTape(1),
1559  thePixelsPerLine(0),
1560  theLinesPerImage(0),
1561  the1stLineInVolume(1),
1562  theTapeBlockingFactor(1),
1563  theRecordSize(0),
1564  theGsd(0.0),
1565  theOutputBitsPerPixel(8),
1566  theAcquiredBitsPerPixel(6)
1567 {
1568  const char tmpBuff[] = "";
1569
1570  strcpy(theProductOrderNumber, tmpBuff);
1571
1572  //>
1573  // There can be four scenes.
1574  //<
1575
1576  for (int i = 0; i < 4; i++)
1577  {
1578  strcpy(thePathRowNumber[i], tmpBuff);
1579  strcpy(theAcquisitionDate[i], tmpBuff);
1580  strcpy(theSatName[i], tmpBuff);
1581  strcpy(theSensorName[i], tmpBuff);
1582  strcpy(theSensorMode[i], tmpBuff);
1583  theOffNadirAngle[i] = 0.0;
1584  }
1585  strcpy(theProductType, "MAP ORIENTED");
1586  strcpy(theProductSize, tmpBuff);
1587  strcpy(theProcessingType, "SYSTEMATIC");
1588  strcpy(theResampAlgorithm, "CC");
1589  strcpy(theBandsPresentString, "P");
1590  strcpy(theFormatVersion, "C");
1591 }
1592
1593 //***************************************************************************
1594 // CONSTRUCTOR:
1595 // ossimFfRevc::RadiomRecord::RadiomRecord()
1596 //
1597 // Default constructor for RadiomRecord nested class:
1598 //***************************************************************************
1600 {
1601  for (int i = 0; i < 8; i++)
1602  {
1603  theBias[i] = 0.0;
1604  theGain[i] = 0.0;
1605  }
1606 }
1607
1608 //***************************************************************************
1609 // CONSTRUCTOR:
1610 // ossimFfRevc::GeoRecord::GeomRecord()
1611 //
1612 // Default constructor for GeoRecord nested class:
1613 //***************************************************************************
1615  :
1616  theUlEasting(0.0),
1617  theUlNorthing(0.0),
1618  theUrEasting(0.0),
1619  theUrNorthing(0.0),
1620  theLrEasting(0.0),
1621  theLrNorthing(0.0),
1622  theLlEasting(0.0),
1623  theLlNorthing(0.0),
1624  theCenterEasting(0.0),
1625  theCenterNorthing(0.0),
1626  theCenterSample(0),
1627  theCenterLine(0),
1628  theHorizontalOffset(0),
1629  theOrientationAngle(0.0),
1630  theSunElevationAngle(0.0),
1631  theSunAzimuth(0.0)
1632 {
1633  for (int i = 0; i < 15; i++)
1634  {
1635  theProjectionParams[i] = 0.0;
1636  }
1637
1638  const char tmpBuff[] = "";
1639
1640  strcpy(theMapProjectionName, "UTM");
1641  strcpy(theEllipsoid, tmpBuff);
1642  strcpy(theDatum, tmpBuff);
1643  strcpy(theUlLon, tmpBuff);
1644  strcpy(theUlLat, tmpBuff);
1645  strcpy(theUrLon, tmpBuff);
1646  strcpy(theUrLat, tmpBuff);
1647  strcpy(theLrLon, tmpBuff);
1648  strcpy(theLrLat, tmpBuff);
1649  strcpy(theLlLon, tmpBuff);
1650  strcpy(theLlLat, tmpBuff);
1651  strcpy(theCenterLon, tmpBuff);
1652  strcpy(theCenterLat, tmpBuff);
1653 }
double theProjectionParams[15]
Definition: ossimFfRevc.h:263
void print(std::ostream &os) const
std::ostream & operator<<(std::ostream &os, const ossimFfRevc &head)
const int OFF_NADIR_ANGLE_OFFSET[4]
Definition: ossimFfRevc.cpp:50
char theProductOrderNumber[PRODUCT_ORDER_NUMBER_SIZE+1]
Definition: ossimFfRevc.h:208
RadiomRecord theRadiomRecord
Definition: ossimFfRevc.h:299
char theProductType[PRODUCT_TYPE_SIZE+1]
Definition: ossimFfRevc.h:223
char theLrLon[LON_SIZE+1]
Definition: ossimFfRevc.h:275
ossimString subScene(int sceneNbr=0) const
char theUlLat[LAT_SIZE+1]
Definition: ossimFfRevc.h:266
void loadFromStream(ossim::istream &is)
static StreamFactoryRegistry * instance()
char theUrLat[LAT_SIZE+1]
Definition: ossimFfRevc.h:271
int checkStream(ossim::istream &is)
#define SPACE
Definition: vpfio.h:25
char theMapProjectionName[MAP_PROJECTION_NAME_SIZE+1]
Definition: ossimFfRevc.h:260
AdminRecord theAdminRecord
Definition: ossimFfRevc.h:298
const int SENSOR_MODE_OFFSET[4]
Definition: ossimFfRevc.cpp:45
int row(int sceneNbr=0) const
int path(int sceneNbr=0) const
void write(std::ostream &os) const
const int DATE_OFFSET[4]
Definition: ossimFfRevc.cpp:30
const int LOCATION_OFFSET[4]
Definition: ossimFfRevc.cpp:20
char theProcessingType[PROCESSING_TYPE_SIZE+1]
Definition: ossimFfRevc.h:227
const int SENSOR_NAME_OFFSET[4]
Definition: ossimFfRevc.cpp:40
ErrorStatus theErrorStatus
Definition: ossimFfRevc.h:343
char theProductSize[PRODUCT_SIZE_SIZE+1]
Definition: ossimFfRevc.h:224
char theResampAlgorithm[RESAMPLING_ALGO_SIZE+1]
Definition: ossimFfRevc.h:228
char theLlLon[LON_SIZE+1]
Definition: ossimFfRevc.h:280
char thePathRowNumber[NUMBER_OF_SCENES][PATH_ROW_NUMBER_SIZE+1]
Definition: ossimFfRevc.h:210
char theDatum[DATUM_SIZE+1]
Definition: ossimFfRevc.h:262
double theOffNadirAngle[NUMBER_OF_SCENES]
Definition: ossimFfRevc.h:221
char theUlLon[LON_SIZE+1]
Definition: ossimFfRevc.h:265
char theCenterLon[LON_SIZE+1]
Definition: ossimFfRevc.h:285
char theEllipsoid[ELLIPSOID_SIZE+1]
Definition: ossimFfRevc.h:261
char theLlLat[LAT_SIZE+1]
Definition: ossimFfRevc.h:281
std::basic_istream< char > istream
Base class for char input streams.
Definition: ossimIosFwd.h:20
char theUrLon[LON_SIZE+1]
Definition: ossimFfRevc.h:270
char theLrLat[LAT_SIZE+1]
Definition: ossimFfRevc.h:276
const int PATH_ROW_NUMBER_OFFSET[4]
Definition: ossimFfRevc.cpp:25
const int GAIN_OFFSET[8]
Definition: ossimFfRevc.cpp:65
char theSatName[NUMBER_OF_SCENES][SAT_NAME_SIZE+1]
Definition: ossimFfRevc.h:214
ossimString pathRow(int sceneNbr=0) const
int fraction(int sceneNbr=0) const
GeoRecord theGeoRecord
Definition: ossimFfRevc.h:300
ossimString & gsub(const ossimString &searchKey, const ossimString &replacementValue, bool replaceAll=false)
Substitutes searchKey string with replacementValue and returns a reference to *this.
std::basic_istringstream< char > istringstream
Class for char input memory streams.
Definition: ossimIosFwd.h:32
char theSensorName[NUMBER_OF_SCENES][SENSOR_NAME_SIZE+1]
Definition: ossimFfRevc.h:217
const int SAT_NAME_OFFSET[4]
Definition: ossimFfRevc.cpp:35
const int BIAS_OFFSET[8]
Definition: ossimFfRevc.cpp:56
char theFormatVersion[FORMAT_VERSION_SIZE+1]
Definition: ossimFfRevc.h:240
char theCenterLat[LAT_SIZE+1]
Definition: ossimFfRevc.h:286
char theAcquisitionDate[NUMBER_OF_SCENES][DATE_SIZE+1]
Definition: ossimFfRevc.h:211
std::basic_ostream< char > ostream
Base class for char output streams.
Definition: ossimIosFwd.h:23
char theBandsPresentString[BANDS_PRESENT_SIZE+1]
Definition: ossimFfRevc.h:239
char theSensorMode[NUMBER_OF_SCENES][SENSOR_MODE_SIZE+1]
Definition: ossimFfRevc.h:220
