#include <ossim/projection/ossimEpsgProjectionDatabase.h>#include <ossim/projection/ossimStatePlaneProjectionInfo.h>#include <ossim/base/ossimKeywordNames.h>#include <ossim/base/ossimCommon.h>#include <ossim/projection/ossimUtmProjection.h>#include <ossim/projection/ossimEquDistCylProjection.h>#include <ossim/projection/ossimTransMercatorProjection.h>#include <ossim/projection/ossimMercatorProjection.h>#include <ossim/projection/ossimOrthoGraphicProjection.h>#include <ossim/projection/ossimNewZealandMapGridProjection.h>#include <ossim/projection/ossimGoogleProjection.h>#include <ossim/projection/ossimLambertConformalConicProjection.h>#include <ossim/projection/ossimCassiniProjection.h>#include <ossim/projection/ossimAlbersProjection.h>#include <ossim/projection/ossimUpsProjection.h>#include <ossim/base/ossimEpsgDatumFactory.h>#include <ossim/base/ossimDatumFactory.h>#include <ossim/base/ossimDatumFactoryRegistry.h>#include <ossim/base/ossimPreferences.h>#include <ossim/projection/ossimMapProjectionFactory.h>#include <ossim/base/ossimException.h>#include <cmath>Go to the source code of this file.
Functions | |
| double | decodeSexagesimalDms (const ossimString &sex_str) |
| Converts sexagesimal DMS to decimal degrees. More... | |
| anonymous enum |
Definition at line 39 of file ossimEpsgProjectionDatabase.cpp.
| anonymous enum |
| Enumerator | |
| B_NAME | |
| B_CODE | |
| B_PROJ_TYPE | |
| B_PARAM1 | |
| B_PARAM2 | |
| B_PARAM3 | |
| B_PARAM4 | |
| B_FALSE_EASTING | |
| B_FALSE_NORTHING | |
| B_UNITS | |
| B_DATUM_CODE | |
| B_NUM_FIELDS | |
Definition at line 87 of file ossimEpsgProjectionDatabase.cpp.
| anonymous enum |
| Enumerator | |
| C_NAME | |
| C_CODE | |
| C_NUM_FIELDS | |
Definition at line 107 of file ossimEpsgProjectionDatabase.cpp.
| double decodeSexagesimalDms | ( | const ossimString & | sex_str | ) |
Definition at line 118 of file ossimEpsgProjectionDatabase.cpp.
References ossimString::chars(), ossimString::contains(), ossimString::insert(), sign(), size, ossimString::split(), and ossimString::toDouble().
Referenced by ossimEpsgProjectionDatabase::createProjFromFormatARecord().
