Go to the source code of this file.
Macros | |
| #define | DATUM_NO_ERROR 0x0000 |
| #define | DATUM_NOT_INITIALIZED_ERROR 0x0001 |
| #define | DATUM_7PARAM_FILE_OPEN_ERROR 0x0002 |
| #define | DATUM_7PARAM_FILE_PARSING_ERROR 0x0004 |
| #define | DATUM_7PARAM_OVERFLOW_ERROR 0x0008 |
| #define | DATUM_3PARAM_FILE_OPEN_ERROR 0x0010 |
| #define | DATUM_3PARAM_FILE_PARSING_ERROR 0x0020 |
| #define | DATUM_3PARAM_OVERFLOW_ERROR 0x0040 |
| #define | DATUM_INVALID_INDEX_ERROR 0x0080 |
| #define | DATUM_INVALID_SRC_INDEX_ERROR 0x0100 |
| #define | DATUM_INVALID_DEST_INDEX_ERROR 0x0200 |
| #define | DATUM_INVALID_CODE_ERROR 0x0400 |
| #define | DATUM_LAT_ERROR 0x0800 |
| #define | DATUM_LON_ERROR 0x1000 |
| #define | DATUM_SIGMA_ERROR 0x2000 |
| #define | DATUM_DOMAIN_ERROR 0x4000 |
| #define | DATUM_ELLIPSE_ERROR 0x8000 |
Typedefs | |
| typedef enum Datum_Types | Datum_Type |
Enumerations | |
| enum | Datum_Types { Three_Param_Datum, Seven_Param_Datum, WGS84_Datum, WGS72_Datum } |
Functions | |
| long | Initialize_Datums (void) |
| long | Create_Datum (const char *Code, const char *Name, const char *Ellipsoid_Code, double Delta_X, double Delta_Y, double Delta_Z, double Sigma_X, double Sigma_Y, double Sigma_Z, double South_latitude, double North_latitude, double West_longitude, double East_longitude) |
| long | Datum_Count (long *Count) |
| long | Datum_Index (const char *Code, long *Index) |
| long | Datum_Code (const long Index, char *Code) |
| long | Datum_Name (const long Index, char *Name) |
| long | Datum_Ellipsoid_Code (const long Index, char *Code) |
| long | Get_Datum_Type (const long Index, Datum_Type *Type) |
| long | Datum_Seven_Parameters (const long Index, double *Delta_X, double *Delta_Y, double *Delta_Z, double *Rx, double *Ry, double *Rz, double *Scale_Factor) |
| long | Datum_Three_Parameters (const long Index, double *Delta_X, double *Delta_Y, double *Delta_Z) |
| long | Datum_Errors (const long Index, double *Sigma_X, double *Sigma_Y, double *Sigma_Z) |
| long | Datum_Valid_Rectangle (const long Index, double *South_latitude, double *North_latitude, double *West_longitude, double *East_longitude) |
| long | Valid_Datum (const long Index, double latitude, double longitude, long *result) |
| long | Geocentric_Shift_To_WGS84 (const long Index, const double X, const double Y, const double Z, double *X_WGS84, double *Y_WGS84, double *Z_WGS84) |
| long | Geocentric_Shift_From_WGS84 (const double X_WGS84, const double Y_WGS84, const double Z_WGS84, const long Index, double *X, double *Y, double *Z) |
| long | Geocentric_Datum_Shift (const long Index_in, const double X_in, const double Y_in, const double Z_in, const long Index_out, double *X_out, double *Y_out, double *Z_out) |
| long | Geodetic_Shift_To_WGS84 (const long Index, const double Lat_in, const double Lon_in, const double Hgt_in, double *WGS84_Lat, double *WGS84_Lon, double *WGS84_Hgt) |
| long | Geodetic_Shift_From_WGS84 (const double WGS84_Lat, const double WGS84_Lon, const double WGS84_Hgt, const long Index, double *Lat_out, double *Lon_out, double *Hgt_out) |
| long | Geodetic_Datum_Shift (const long Index_in, const double Lat_in, const double Lon_in, const double Hgt_in, const long Index_out, double *Lat_out, double *Lon_out, double *Hgt_out) |
| long | Datum_Shift_Error (const long Index_in, const long Index_out, double latitude, double longitude, double *ce90, double *le90, double *se90) |
| typedef enum Datum_Types Datum_Type |
| enum Datum_Types |
| Enumerator | |
| Three_Param_Datum | |
| Seven_Param_Datum | |
| WGS84_Datum | |
| WGS72_Datum | |
Definition at line 147 of file datum.h.
| long Create_Datum | ( | const char * | Code, |
| const char * | Name, | ||
| const char * | Ellipsoid_Code, | ||
| double | Delta_X, | ||
| double | Delta_Y, | ||
| double | Delta_Z, | ||
| double | Sigma_X, | ||
| double | Sigma_Y, | ||
| double | Sigma_Z, | ||
| double | South_latitude, | ||
| double | North_latitude, | ||
| double | West_longitude, | ||
| double | East_longitude | ||
| long Datum_Code | ( | const long | Index, |
| char * | Code | ||
| long Datum_Count | ( | long * | Count | ) |
| long Datum_Ellipsoid_Code | ( | const long | Index, |
| char * | Code | ||
| long Datum_Errors | ( | const long | Index, |
| double * | Sigma_X, | ||
| double * | Sigma_Y, | ||
| double * | Sigma_Z | ||
| long Datum_Index | ( | const char * | Code, |
| long * | Index | ||
| long Datum_Name | ( | const long | Index, |
| char * | Name | ||
| long Datum_Seven_Parameters | ( | const long | Index, |
| double * | Delta_X, | ||
| double * | Delta_Y, | ||
| double * | Delta_Z, | ||
| double * | Rx, | ||
| double * | Ry, | ||
| double * | Rz, | ||
| double * | Scale_Factor | ||
| long Datum_Shift_Error | ( | const long | Index_in, |
| const long | Index_out, | ||
| double | latitude, | ||
| double | longitude, | ||
| double * | ce90, | ||
| double * | le90, | ||
| double * | se90 | ||
| long Datum_Three_Parameters | ( | const long | Index, |
| double * | Delta_Z | ||
| long Datum_Valid_Rectangle | ( | const long | Index, |
| double * | South_latitude, | ||
| double * | North_latitude, | ||
| double * | West_longitude, | ||
| double * | East_longitude | ||
| long Geocentric_Datum_Shift | ( | const long | Index_in, |
| const double | X_in, | ||
| const double | Y_in, | ||
| const double | Z_in, | ||
| double * | X_out, | ||
| double * | Y_out, | ||
| double * | Z_out | ||
| long Geocentric_Shift_From_WGS84 | ( | const double | X_WGS84, |
| const double | Y_WGS84, | ||
| const double | Z_WGS84, | ||
| const long | Index, | ||
| double * | X, | ||
| double * | Y, | ||
| double * | Z | ||
| long Geocentric_Shift_To_WGS84 | ( | const long | Index, |
| const double | X, | ||
| const double | Y, | ||
| const double | Z, | ||
| double * | X_WGS84, | ||
| double * | Y_WGS84, | ||
| double * | Z_WGS84 | ||
| long Geodetic_Datum_Shift | ( | const long | Index_in, |
| const double | Lat_in, | ||
| const double | Lon_in, | ||
| const double | Hgt_in, | ||
| double * | Lat_out, | ||
| double * | Lon_out, | ||
| double * | Hgt_out | ||
| long Geodetic_Shift_From_WGS84 | ( | const double | WGS84_Lat, |
| const double | WGS84_Lon, | ||
| const double | WGS84_Hgt, | ||
| long Geodetic_Shift_To_WGS84 | ( | const long | Index, |
| double * | WGS84_Lat, | ||
| double * | WGS84_Lon, | ||
| double * | WGS84_Hgt | ||
| long Get_Datum_Type | ( | const long | Index, |
| Datum_Type * | Type | ||
| long Initialize_Datums | ( | void | ) |
| long Valid_Datum | ( | const long | Index, |
| long * | result | ||
