This is the state registry for all image handler states that will be supported. More...
#include <ImageHandlerStateRegistry.h>
| ImageHandlerStateRegistry () | |
| std::shared_ptr< ossim::ImageHandlerState > | createState (const ossimKeywordlist &kwl, const ossimString &prefix="") const |
| std::shared_ptr< ossim::ImageHandlerState > | createState (const ossimString &typeName) const |
Public Member Functions inherited from ossim::FactoryListBase< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > > | |
| FactoryListBase () | |
| void | addFactory (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory, std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| static std::shared_ptr< ImageHandlerStateRegistry > | instance () |
Public Types inherited from ossim::FactoryListBase< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > > | |
| typedef std::vector< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > > | FactoryListType |
| typedef std::vector< ossimString > | TypeNameList |
Protected Member Functions inherited from ossim::FactoryListBase< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > > | |
| bool | findFactory (std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > factory) const |
| Utility to find a factory in the list. More... | |
Protected Attributes inherited from ossim::FactoryListBase< std::shared_ptr< ossim::StateFactoryBase< std::shared_ptr< ossim::ImageHandlerState > > > > | |
| ossim::RWLock | m_rwlock |
| FactoryListType | m_factoryList |
Definition at line 20 of file ImageHandlerStateRegistry.h.
| ossim::ImageHandlerStateRegistry::ImageHandlerStateRegistry | ( | ) |
Definition at line 5 of file ImageHandlerStateRegistry.cpp.
| std::shared_ptr< ossim::ImageHandlerState > ossim::ImageHandlerStateRegistry::createState | ( | const ossimKeywordlist & | kwl, |
| const ossimString & | prefix = "" |
| ) | const |
Definition at line 17 of file ImageHandlerStateRegistry.cpp.
| std::shared_ptr< ossim::ImageHandlerState > ossim::ImageHandlerStateRegistry::createState | ( | const ossimString & | typeName | ) | const |
Definition at line 31 of file ImageHandlerStateRegistry.cpp.
static |
Definition at line 9 of file ImageHandlerStateRegistry.cpp.
Referenced by ossimInit::initializeDefaultFactories(), ossimInfo::openImageFromState(), and ossimInfo::openImageHandler().
