Visitor to update view and then propagate property event to outputs. More...
#include <ossimVisitor.h>
| ossimSourceInitializeVisitor (int visitorType=VISIT_OUTPUTS) | |
| ossimSourceInitializeVisitor (const ossimSourceInitializeVisitor &src) | |
| virtual ossimRefPtr< ossimVisitor > | dup () const |
| virtual void | visit (ossimObject *obj) |
| Calls ossimViewInterface::setView if obj cast to ossimViewInterface*. More... | |
Public Member Functions inherited from ossimVisitor | |
| ossimVisitor (int visitorType=VISIT_NONE) | |
| ossimVisitor (const ossimVisitor &src) | |
| virtual void | reset () |
| virtual void | visit (ossimConnectableObject *obj) |
| VisitorType | getVisitorType () const |
| void | setVisitorType (int vType, bool on=true) |
| void | turnOffVisitorType (int vType) |
| bool | hasVisited (ossimObject *obj) const |
| bool | stopTraversal () const |
Public Types inherited from ossimVisitor | |
| enum | VisitorType { VISIT_NONE = 0, VISIT_CHILDREN = 1, VISIT_INPUTS = 2, VISIT_OUTPUTS = 4, VISIT_ALL = (VISIT_CHILDREN|VISIT_INPUTS|VISIT_OUTPUTS) } |
| Enumeration type can be a mask and will traverse a graph of connectables based on the values. More... | |
| typedef std::set< ossimRefPtr< ossimObject > > | MarkCollectionRef |
| typedef std::set< ossimRefPtr< ossimObject > > | CollectionRef |
| typedef std::vector< ossimRefPtr< ossimObject > > | ListRef |
| typedef std::set< ossimObject * > | Collection |
| typedef std::vector< ossimObject *> | List |
Protected Attributes inherited from ossimVisitor | |
| VisitorType | m_visitorType |
| Collection | m_markNode |
| bool | m_stopTraversalFlag |
Definition at line 209 of file ossimVisitor.h.
| ossimSourceInitializeVisitor::ossimSourceInitializeVisitor | ( | int | visitorType = VISIT_OUTPUTS | ) |
| ossimSourceInitializeVisitor::ossimSourceInitializeVisitor | ( | const ossimSourceInitializeVisitor & | src | ) |
Definition at line 395 of file ossimVisitor.cpp.
Implements ossimVisitor.
Definition at line 400 of file ossimVisitor.cpp.
References ossimSourceInitializeVisitor().
On success a property event is sent to output side so that things like ossimCombiner can reinitialize if needed.
| obj | Object to visit. |
Reimplemented from ossimVisitor.
Definition at line 405 of file ossimVisitor.cpp.
References ossimVisitor::hasVisited(), ossimSource::initialize(), and ossimVisitor::visit().
