Info factory.
More...
#include <ossimGeoPdfInfoFactory.h>
Info factory.
Definition at line 26 of file ossimGeoPdfInfoFactory.h.
◆ ~ossimGeoPdfInfoFactory()
| ossimGeoPdfInfoFactory::~ossimGeoPdfInfoFactory |
◆ ossimGeoPdfInfoFactory() [1/2]
| ossimGeoPdfInfoFactory::ossimGeoPdfInfoFactory |
private |
◆ ossimGeoPdfInfoFactory() [2/2]
◆ create() [1/2]
create method.
- Parameters
| file | Some file you want info for. |
- Returns
- ossimInfoBase* on success 0 on failure. Caller is responsible for memory.
Implements ossimInfoFactoryInterface.
Definition at line 41 of file ossimGeoPdfInfoFactory.cpp.
43 std::shared_ptr<ossimInfoBase> result;
45 result = std::make_shared<ossimGeoPdfInfo>();
46 if ( result->open(file) )
◆ create() [2/2]
| std::shared_ptr< ossimInfoBase > ossimGeoPdfInfoFactory::create |
std::shared_ptr< ossim::istream > & |
str, |
const std::string & |
connectionString |
| const |
◆ instance()
◆ operator=()
