Info factory.
More...
#include <ossimGdalInfoFactory.h>
Info factory.
Definition at line 26 of file ossimGdalInfoFactory.h.
◆ ~ossimGdalInfoFactory()
| ossimGdalInfoFactory::~ossimGdalInfoFactory |
◆ ossimGdalInfoFactory() [1/2]
| ossimGdalInfoFactory::ossimGdalInfoFactory |
private |
◆ ossimGdalInfoFactory() [2/2]
◆ create() [1/2]
create method.
- Parameters
| file | Some file you want info for. |
- Returns
- ossimInfoBase* on success 0 on failure. Caller is responsible for memory.
Implements ossimInfoFactoryInterface.
Definition at line 33 of file ossimGdalInfoFactory.cpp.
36 std::shared_ptr<ossimInfoBase> result;
38 std::shared_ptr<ossimHdfInfo> hdfInfo = std::make_shared<ossimHdfInfo>();
39 if ( hdfInfo->open(file) )
44 std::shared_ptr<ossimOgrInfo> ogrInfo = std::make_shared<ossimOgrInfo>();
45 if ( ogrInfo->open(file) )
◆ create() [2/2]
| std::shared_ptr< ossimInfoBase > ossimGdalInfoFactory::create |
std::shared_ptr< ossim::istream > & |
str, |
const std::string & |
connectionString |
| const |
◆ instance()
◆ operator=()
