Singleton class maintaining parameters affecting the automatic tie point generation. More...
#include <ossimDemToolConfig.h>
| virtual | ~ossimDemToolConfig () |
| Destructor. More... | |
| bool | readConfig (const std::string &configName="") |
| bool | diagnosticLevel (unsigned int level) const |
| Convenience method returns TRUE if the currently set diagnostic level is <= level. More... | |
Public Member Functions inherited from ossim::JsonConfig | |
| JsonConfig () | |
| Default Ctor loads all default .json files in the share/ossim system dir. More... | |
| JsonConfig (const ossimFilename &configFile) | |
| virtual | ~JsonConfig () |
| bool | open (const ossimFilename &configFile) |
| Opens and parses JSON file. The "parameters" keyword is expected in the root node. More... | |
| virtual void | loadJSON (const Json::Value ¶ms_json_node) |
| Reads the params controlling the process from the JSON node named "parameters". More... | |
| virtual void | saveJSON (Json::Value ¶ms_json_node) const |
| JsonParam & | getParameter (const char *paramName) |
| Returns a parameter (might be a null parameter if paramName not found in the configuration. More... | |
| void | setParameter (const JsonParam &p) |
| Adds parameter to the configuration. More... | |
| bool | paramExists (const char *paramName) const |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
| static ossimDemToolConfig & | instance () |
| Singleton implementation. More... | |
Private Member Functions | |
| ossimDemToolConfig () | |
| ossimDemToolConfig (const ossimDemToolConfig &) | |
Protected Member Functions inherited from ossim::JsonConfig | |
| JsonConfig (const JsonConfig &) | |
| bool | getBoolValue (bool &rtn_val, const std::string &json_value) const |
Protected Attributes inherited from ossim::JsonConfig | |
| std::map< std::string, JsonParam > | m_paramsMap |
Static Protected Attributes inherited from ossim::JsonConfig | |
| static JsonParam | s_nullParam |
The state is imported and exported via JSON. There are default configuration files that must be part of the install, that are accessed by this class. Custom settings can also be st
Definition at line 22 of file ossimDemToolConfig.h.
Destructor.
Definition at line 33 of file ossimDemToolConfig.cpp.
private |
Definition at line 25 of file ossimDemToolConfig.cpp.
inlineprivate |
Definition at line 38 of file ossimDemToolConfig.h.
| bool ossimDemToolConfig::diagnosticLevel | ( | unsigned int | level | ) | const |
static |
Definition at line 19 of file ossimDemToolConfig.cpp.
Referenced by ossimDemTool::getParameters(), and ossimDemTool::loadJSON().
| bool ossimDemToolConfig::readConfig | ( | const std::string & | configName = "" | ) |
Definition at line 38 of file ossimDemToolConfig.cpp.
References ossimPreferences::instance(), ossimFilename::isDir(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::setPath(), and ossimException::what().
