Information from the DDR defining one field. More...
#include <ossimIso8211.h>
| ossimDDFFieldDefn () | |
| ~ossimDDFFieldDefn () | |
| int | Create (const char *pszTag, const char *pszFieldName, const char *pszDescription, DDF_data_struct_code eDataStructCode, DDF_data_type_code eDataTypeCode, const char *pszFormat=NULL) |
| void | AddSubfield (ossimDDFSubfieldDefn *poNewSFDefn, int bDontAddToFormat=false) |
| void | AddSubfield (const char *pszName, const char *pszFormat) |
| int | GenerateDDREntry (char **ppachData, int *pnLength) |
| int | Initialize (ossimDDFModule *poModule, const char *pszTag, int nSize, const char *pachRecord) |
| void | Dump (FILE *fp) |
| Write out field definition info to debugging file. More... | |
| const char * | GetName () |
| Fetch a pointer to the field name (tag). More... | |
| const char * | GetDescription () |
| Fetch a longer descriptio of this field. More... | |
| int | GetSubfieldCount () |
| Get the number of subfields. More... | |
| ossimDDFSubfieldDefn * | GetSubfield (int i) |
| Fetch a subfield by index. More... | |
| ossimDDFSubfieldDefn * | FindSubfieldDefn (const char *) |
| Find a subfield definition by it's mnemonic tag. More... | |
| int | GetFixedWidth () |
| Get the width of this field. More... | |
| int | IsRepeating () |
| Fetch repeating flag. More... | |
| void | SetRepeatingFlag (int n) |
| this is just for an S-57 hack for swedish data More... | |
| char * | GetDefaultValue (int *pnSize) |
| Return default data for field instance. More... | |
| static char * | ExpandFormat (const char *) |
Private Member Functions | |
| int | BuildSubfields () |
| int | ApplyFormats () |
Static Private Member Functions | |
| static char * | ExtractSubstring (const char *) |
Private Attributes | |
| ossimDDFModule * | poModule |
| char * | pszTag |
| char * | _fieldName |
| char * | _arrayDescr |
| char * | _formatControls |
| int | bRepeatingSubfields |
| int | nFixedWidth |
| DDF_data_struct_code | _data_struct_code |
| DDF_data_type_code | _data_type_code |
| int | nSubfieldCount |
| ossimDDFSubfieldDefn ** | papoSubfields |
Note that just because a field is defined for a DDFModule doesn't mean that it actually occurs on any records in the module. DDFFieldDefns are normally just significant as containers of the DDFSubfieldDefns.
Definition at line 179 of file ossimIso8211.h.
| ossimDDFFieldDefn::ossimDDFFieldDefn | ( | ) |
Definition at line 47 of file ossimDdffielddefn.cpp.
References _arrayDescr, _fieldName, _formatControls, bRepeatingSubfields, nFixedWidth, nSubfieldCount, papoSubfields, poModule, and pszTag.
| ossimDDFFieldDefn::~ossimDDFFieldDefn | ( | ) |
Definition at line 65 of file ossimDdffielddefn.cpp.
References _arrayDescr, _fieldName, _formatControls, nSubfieldCount, papoSubfields, and pszTag.
| void ossimDDFFieldDefn::AddSubfield | ( | ossimDDFSubfieldDefn * | poNewSFDefn, |
| int | bDontAddToFormat = false |
Definition at line 99 of file ossimDdffielddefn.cpp.
References _arrayDescr, _formatControls, ossimDDFSubfieldDefn::GetFormat(), ossimDDFSubfieldDefn::GetName(), nSubfieldCount, and papoSubfields.
Referenced by AddSubfield(), and BuildSubfields().
| void ossimDDFFieldDefn::AddSubfield | ( | const char * | pszName, |
| const char * | pszFormat | ||
Definition at line 84 of file ossimDdffielddefn.cpp.
References AddSubfield(), ossimDDFSubfieldDefn::SetFormat(), and ossimDDFSubfieldDefn::SetName().
private |
Definition at line 659 of file ossimDdffielddefn.cpp.
References _formatControls, ExpandFormat(), ossimDDFSubfieldDefn::GetWidth(), nFixedWidth, nSubfieldCount, ossimCSLDestroy(), ossimCSLTokenizeStringComplex(), ossimNotify(), ossimNotifyLevel_DEBUG, ossimNotifyLevel_WARN, papoSubfields, and pszTag.
private |
Definition at line 481 of file ossimDdffielddefn.cpp.
References _arrayDescr, AddSubfield(), bRepeatingSubfields, ossimCSLCount(), ossimCSLDestroy(), ossimCSLTokenizeStringComplex(), and ossimDDFSubfieldDefn::SetName().
| int ossimDDFFieldDefn::Create | ( | const char * | pszTag, |
| const char * | pszFieldName, | ||
| const char * | pszDescription, | ||
| DDF_data_struct_code | eDataStructCode, | ||
| DDF_data_type_code | eDataTypeCode, | ||
| const char * | pszFormat = NULL |
Definition at line 158 of file ossimDdffielddefn.cpp.
References _arrayDescr, _data_struct_code, _data_type_code, _fieldName, _formatControls, bRepeatingSubfields, poModule, and pszTag.
| void ossimDDFFieldDefn::Dump | ( | FILE * | fp | ) |
A variety of information about this field definition, and all it's subfields is written to the give debugging file handle.
| fp | The standard io file handle to write to. ie. stderr |
Definition at line 397 of file ossimDdffielddefn.cpp.
References _arrayDescr, _data_struct_code, _data_type_code, _fieldName, _formatControls, dsc_array, dsc_concatenated, dsc_elementary, dsc_vector, dtc_bit_string, dtc_char_bit_string, dtc_char_string, dtc_explicit_point, dtc_explicit_point_scaled, dtc_implicit_point, dtc_mixed_data_type, nSubfieldCount, papoSubfields, and pszTag.
Referenced by ossimDDFModule::Dump().
static |
Definition at line 557 of file ossimDdffielddefn.cpp.
References ExtractSubstring().
Referenced by ApplyFormats().
staticprivate |
| ossimDDFSubfieldDefn * ossimDDFFieldDefn::FindSubfieldDefn | ( | const char * | pszMnemonic | ) |
| pszMnemonic | The name of the field. |
Definition at line 771 of file ossimDdffielddefn.cpp.
References ossimDDFSubfieldDefn::GetName(), nSubfieldCount, and papoSubfields.
Referenced by ossimDDFRecord::GetFloatSubfield(), ossimDDFRecord::GetIntSubfield(), ossimDDFRecord::GetStringSubfield(), ossimAdrgHeader::parse(), ossimDDFRecord::SetFloatSubfield(), ossimDDFRecord::SetIntSubfield(), and ossimDDFRecord::SetStringSubfield().
| int ossimDDFFieldDefn::GenerateDDREntry | ( | char ** | ppachData, |
| int * | pnLength | ||
Definition at line 188 of file ossimDdffielddefn.cpp.
References _arrayDescr, _data_struct_code, _data_type_code, _fieldName, _formatControls, dsc_array, dsc_concatenated, dsc_elementary, dsc_vector, dtc_bit_string, dtc_char_bit_string, dtc_char_string, dtc_explicit_point, dtc_explicit_point_scaled, dtc_implicit_point, dtc_mixed_data_type, OSSIM_DDF_FIELD_TERMINATOR, and OSSIM_DDF_UNIT_TERMINATOR.
Referenced by ossimDDFModule::Create().
| char * ossimDDFFieldDefn::GetDefaultValue | ( | int * | pnSize | ) |
Definition at line 818 of file ossimDdffielddefn.cpp.
References nSubfieldCount, and papoSubfields.
Referenced by ossimDDFRecord::CreateDefaultFieldInstance().
inline |
Definition at line 208 of file ossimIso8211.h.
References _fieldName.
inline |
This function isn't normally used by applications.
Definition at line 223 of file ossimIso8211.h.
References nFixedWidth.
Referenced by ossimDDFField::GetRepeatCount(), and ossimDDFField::GetSubfieldData().
inline |
Definition at line 203 of file ossimIso8211.h.
References pszTag.
Referenced by ossimDDFRecord::CloneOn(), ossimDDFField::Dump(), ossimDDFRecord::FindField(), ossimDDFModule::FindFieldDefn(), and ossimDDFRecord::ResetDirectory().
| ossimDDFSubfieldDefn * ossimDDFFieldDefn::GetSubfield | ( | int | i | ) |
| i | The index subfield index. (Between 0 and GetSubfieldCount()-1) |
Definition at line 798 of file ossimDdffielddefn.cpp.
Referenced by ossimDDFField::Dump(), ossimDDFField::GetInstanceData(), ossimDDFField::GetRepeatCount(), and ossimDDFField::GetSubfieldData().
inline |
Definition at line 211 of file ossimIso8211.h.
References nSubfieldCount.
| int ossimDDFFieldDefn::Initialize | ( | ossimDDFModule * | poModule, |
| const char * | pszTag, | ||
| int | nSize, | ||
| const char * | pachRecord | ||
Definition at line 253 of file ossimDdffielddefn.cpp.
References _data_struct_code, dsc_array, dsc_concatenated, dsc_elementary, dsc_vector, ossimDDFModule::GetFieldControlLength(), poModule, and pszTag.
inline |
Definition at line 230 of file ossimIso8211.h.
References bRepeatingSubfields.
Referenced by ossimDDFField::GetRepeatCount(), and ossimDDFRecord::SetFieldRaw().
inline |
Definition at line 235 of file ossimIso8211.h.
References bRepeatingSubfields, and n.
private |
Definition at line 247 of file ossimIso8211.h.
Referenced by AddSubfield(), BuildSubfields(), Create(), Dump(), GenerateDDREntry(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
private |
Definition at line 256 of file ossimIso8211.h.
Referenced by Create(), Dump(), GenerateDDREntry(), and Initialize().
private |
Definition at line 258 of file ossimIso8211.h.
Referenced by Create(), Dump(), and GenerateDDREntry().
private |
Definition at line 246 of file ossimIso8211.h.
Referenced by Create(), Dump(), GenerateDDREntry(), GetDescription(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
private |
Definition at line 248 of file ossimIso8211.h.
Referenced by AddSubfield(), ApplyFormats(), Create(), Dump(), GenerateDDREntry(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
private |
Definition at line 250 of file ossimIso8211.h.
Referenced by BuildSubfields(), Create(), IsRepeating(), ossimDDFFieldDefn(), and SetRepeatingFlag().
private |
Definition at line 251 of file ossimIso8211.h.
Referenced by ApplyFormats(), GetFixedWidth(), and ossimDDFFieldDefn().
private |
Definition at line 260 of file ossimIso8211.h.
Referenced by AddSubfield(), ApplyFormats(), Dump(), FindSubfieldDefn(), GetDefaultValue(), GetSubfield(), GetSubfieldCount(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
private |
Definition at line 261 of file ossimIso8211.h.
Referenced by AddSubfield(), ApplyFormats(), Dump(), FindSubfieldDefn(), GetDefaultValue(), GetSubfield(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
private |
Definition at line 243 of file ossimIso8211.h.
Referenced by Create(), Initialize(), and ossimDDFFieldDefn().
private |
Definition at line 244 of file ossimIso8211.h.
Referenced by ApplyFormats(), Create(), Dump(), GetName(), Initialize(), ossimDDFFieldDefn(), and ~ossimDDFFieldDefn().
